[PATCH v2 00/12] Enable PPS API in RTEMS6
Gabriel Moyano
gabriel.moyano at dlr.de
Fri Apr 29 07:20:39 UTC 2022
Second version of patches for enabling PPS API in RTEMS6. They have the following improvements:
- Add function _Timecounter_Get_frequency()
- Move hardpps to the _ namespace
- Add a test (sptest/sppps01) for testing basic behaviour of struct pps_state
- Add definition of atomic_load_int() as a relaxed atomic load
- Remove the option for PPS_SYNC and add the #define
Gabriel Moyano (12):
kern_ntptime.c: Disable freebsd features
kern_ntptime.c: Add lmax() qmin() definitions
timepps.h: Add missing include for atomic type
kern_tc.c: Add definition of atomic_load_int() required by PPS API
kern_tc.c: Replace FREEBSD event mechanism by adding pointers to
function
timecounter.h: Rename tc_getfrequency() to
kern_tc.c: Add definitions required by PPS API
kern_tc.c: Enable PPS API support
kern_ntptime: Add define in order to remove warning
timepps.h: PPS_SYNC defined by default
timepps.h: Move hardpps to the _ namespace
testsuites/sptests: Add sppps01 test
cpukit/include/rtems/score/timecounter.h | 7 +
cpukit/include/sys/timepps.h | 15 ++
cpukit/include/sys/timetc.h | 3 +
cpukit/score/src/kern_ntptime.c | 19 ++-
cpukit/score/src/kern_tc.c | 41 +++++-
spec/build/testsuites/sptests/grp.yml | 2 +
spec/build/testsuites/sptests/sppps01.yml | 19 +++
testsuites/sptests/sppps01/init.c | 160 ++++++++++++++++++++++
8 files changed, 251 insertions(+), 15 deletions(-)
create mode 100644 spec/build/testsuites/sptests/sppps01.yml
create mode 100644 testsuites/sptests/sppps01/init.c
2.25.1
