[PATCH] rtems-tools-6.cfg: Bump hash
Mon Aug 1 00:22:47 UTC 2022
OK
Thanks
On 30/7/2022 1:47 am, Ryan Long wrote:
>  rtems/config/tools/rtems-tools-6.cfg | 4 ++--
>  1 file changed, 2 insertions(+), 2 deletions(-)
> diff --git a/rtems/config/tools/rtems-tools-6.cfg b/rtems/config/tools/rtems-tools-6.cfg
> index c032bd4..a667175 100644
> --- a/rtems/config/tools/rtems-tools-6.cfg
> +++ b/rtems/config/tools/rtems-tools-6.cfg
> @@ -10,14 +10,14 @@
>   %define rtems_tools_source rtems-tools-%{rtems_tools_version}
>   %define rtems_tools_ext xz
>  %else
> - %define rtems_tools_version f199d42e47e2e19175427e95797ca2f829f6aaa9
> + %define rtems_tools_version ace7db96d4561665b07ba15c2fe5f9349f4d3d8c
>   %define rtems_tools_ext bz2
>  %endif
>  %source set rtems-tools https://git.rtems.org/rtems-tools/snapshot/%{rtems_tools_source}.tar.%{rtems_tools_ext}
>  %hash   sha512 rtems-tools-%{rtems_tools_version}.tar.bz2 \
> -         VGmVZ8xUGYlnc7C6QGiwBbLp8e2e8/i1drFA0/y2gkoSIIcKMTIaS8gV+Qi6RuoBjJhg3HiNJ3pXIPsBCUi3Hw==
> +         zYlopSJV6AEgEWqy3Y0c60BCy6cXWt1ej+F0OvFFzZf6PQ38avoKxlOkkDY1hzlfOjhR4AFaFM89k5vcYClreA==
>  # Optionally enable/disable building the RTEMS Tools via the command line.
