[PATCH 1/5] building: Add support for an RTEMS version number
chrisj at rtems.org chrisj at rtems.org
Wed Aug 3 04:32:57 UTC 2022
- Support using a version number for RTEMS documentation
Updates #4695
 README.txt            | 31 +++++++++++++++++++++
 common/conf.py        | 12 +++-----
 common/rtemsdomain.py | 64 +++++++++++++++++++++++++++++++------------
 common/version.py     |  5 +++-
 4 files changed, 85 insertions(+), 27 deletions(-)
diff --git a/README.txt b/README.txt
index 828c9e7..07bae0d 100644
--- a/README.txt
+++ b/README.txt
@@ -504,6 +504,9 @@ existing documentation for an example and if unsure ask.
    identifed by the standard shell prompt characters where '$' is a
    user prompt and '#' is a 'root' prompt.
+   Do not embed the version or version major number in the literal
+   commands or examples. Use the replacements listed in 10.
 6. Use the directives for 'note', 'warning', and 'topic'. Do not add 'TIP',
    'Important' or 'Warning' to the text. Let the mark-up language handle
    this. The supported directives are:
@@ -582,3 +585,31 @@ existing documentation for an example and if unsure ask.
      bugs         : https://devel.rtems.org/wiki/Bugs/
      gsoc         : https://devel.rtems.org/wiki/GSoC/
      socis        : https://devel.rtems.org/wiki/SOCIS/
+10. Use the following to embed the version number in any part of the
+    documentation source:
+     1. @rtems-version@
+        The complete version string of the documentation.
+     2. @rtems-ver-major@
+        The version major number.
+     2. @rtems-ver-minor@
+        The version minor number.
+     2. @rtems-ver-revision@
+        The version revision number.
+    The replacement happens during the source read phase of the build
+    and is not context specific. The subsituation will happen in code
+    blocks and other normally quoated area.
+    It is a requirement these be used then embedded commands or
+    related text in the documentation to let the documentatoin track
+    the release. For example `microblaze-rtems6-gdb` should be written
+    as `microblaze-rtems at rtems-ver-major@-gdb`.
diff --git a/common/conf.py b/common/conf.py
index a652e2a..565e06d 100644
--- a/common/conf.py
+++ b/common/conf.py
@@ -1,4 +1,4 @@
-import version as rtems_version
+import datetime
 extensions = [
 	"sphinx.ext.autodoc",
@@ -30,21 +30,17 @@ master_doc = 'index'
 # General information about the project.
 project = u'RTEMS Documentation Project'
-copyright = u'1988, 2020 RTEMS Project and contributors'
+copyright = u'1988, ' + str(datetime.datetime.now().year) + ' RTEMS Project and contributors'
 # The version info for the project you're documenting, acts as replacement for
 # |version| and |release|, also used in various other places throughout the
 # built documents.
 # The short X.Y version.
-version = rtems_version.version()
+#version = rtems_version.version()
 # The full version, including alpha/beta/rc tags.
-release = rtems_version.string()
-major = rtems_version.major()
-minor = rtems_version.minor()
-revision = rtems_version.revision()
+#release = rtems_version.string()
 # The language for content autogenerated by Sphinx. Refer to documentation
 # for a list of supported languages.
diff --git a/common/rtemsdomain.py b/common/rtemsdomain.py
index 9b092a3..630f1e3 100644
--- a/common/rtemsdomain.py
+++ b/common/rtemsdomain.py
@@ -8,6 +8,8 @@ from sphinx.domains import Domain, ObjType, Index
 from sphinx.util.nodes import make_refnode
 from sphinx.util.docfields import Field, TypedField
+import version as rtems_version
 :r:bsp:`sparc/sis`
@@ -30,28 +32,28 @@ role_name = {
 role_url = {
-	"trac": 			("Trac",				"https://devel.rtems.org"),
-	"devel": 			("Developer Site",		"https://devel.rtems.org"),
-	"www":				("RTEMS Home",			"https://www.rtems.org/"),
-	"buildbot":			("Buildbot Instance",	"https://buildbot.rtems.org/"),
-	"builder":			("Builder Site",		"https://builder.rtems.org/"),
-	"docs":				("Documentation Site",	"https://docs.rtems.org/"),
-	"lists":			("Mailing Lists",		"https://lists.rtems.org/"),
-	"git":				("Git Repositories",	"https://git.rtems.org/"),
-	"ftp":				("FTP File Server",	"https://ftp.rtems.org/"),
-	"review":			("Gerrit Code Review",	"https://review.rtems.org/"),
-	"bugs":				("Bugs Database",		"https://devel.rtems.org/wiki/Bugs/"),
-	"gsoc":				("Google Summer of Code", "https://devel.rtems.org/wiki/GSoC/"),
-	"socis":			("ESA SOCIS",			"https://devel.rtems.org/wiki/SOCIS/")
+	"trac": 	("Trac",			"https://devel.rtems.org"),
+	"devel": 	("Developer Site",		"https://devel.rtems.org"),
+	"www":		("RTEMS Home",			"https://www.rtems.org/"),
+	"buildbot":	("Buildbot Instance",		"https://buildbot.rtems.org/"),
+	"builder":	("Builder Site",		"https://builder.rtems.org/"),
+	"docs":		("Documentation Site",		"https://docs.rtems.org/"),
+	"lists":	("Mailing Lists",		"https://lists.rtems.org/"),
+	"git":		("Git Repositories",		"https://git.rtems.org/"),
+	"ftp":		("FTP File Server",		"https://ftp.rtems.org/"),
+	"review":	("Gerrit Code Review",		"https://review.rtems.org/"),
+	"bugs":		("Bugs Database",		"https://devel.rtems.org/wiki/Bugs/"),
+	"gsoc":		("Google Summer of Code", 	"https://devel.rtems.org/wiki/GSoC/"),
+	"socis":	("ESA SOCIS",			"https://devel.rtems.org/wiki/SOCIS/")
 role_list = {
-	"announce":	("Announce Mailing List",			"https://lists.rtems.org/mailman/listinfo/announce/"),
-	"bugs":		("Bugs Mailing List",				"https://lists.rtems.org/mailman/listinfo/bugs/"),
-	"devel":	("Developers Mailing List",			"https://lists.rtems.org/mailman/listinfo/devel/"),
-	"build":	("Build Logs",					"https://lists.rtems.org/mailman/listinfo/build"),
-	"users":	("Users Mailing List",				"https://lists.rtems.org/mailman/listinfo/users/"),
+	"announce":	("Announce Mailing List",		"https://lists.rtems.org/mailman/listinfo/announce/"),
+	"bugs":		("Bugs Mailing List",			"https://lists.rtems.org/mailman/listinfo/bugs/"),
+	"devel":	("Developers Mailing List",		"https://lists.rtems.org/mailman/listinfo/devel/"),
+	"build":	("Build Logs",				"https://lists.rtems.org/mailman/listinfo/build"),
+	"users":	("Users Mailing List",			"https://lists.rtems.org/mailman/listinfo/users/"),
 	"vc":		("Version Control Mailing List",	"https://lists.rtems.org/mailman/listinfo/vc/"),
@@ -119,7 +121,33 @@ class RTEMSDomain(Domain):
 		pass # XXX is this needed?
+def rtems_replace(app, docname, source):
+	dump = False
+	line = source[0]
+	for key in app.config.replacements:
+		line = line.replace(key, app.config.replacements[key])
+	source[0] = line
+replacements = {
 def setup(app):
+	app.add_config_value('rtems_major', str(app.config.overrides['rtems_major']), True)
+	app.add_config_value('rtems_minor', str(app.config.overrides['rtems_minor']), True)
+	app.add_config_value('rtems_revision', str(app.config.overrides['rtems_revision']), True)
+	major = str(app.config.overrides['rtems_major'])
+	minor = str(app.config.overrides['rtems_minor'])
+	revision = str(app.config.overrides['rtems_revision'])
+	if revision.isdigit():
+		majminrev = major + '.' + minor + '.' + revision
+	else:
+		majminrev = major + '.' + revision
+	replacements["@rtems-version@"] = str(app.config.overrides['version'])
+	replacements["@rtems-ver-major@"] = major
+	replacements["@rtems-ver-minor@"] = minor
+	replacements["@rtems-ver-revision@"] = revision
+	replacements["@rtems-ver-majminrev@"] = majminrev
+	app.add_config_value('replacements', replacements, True)
+	app.connect('source-read', rtems_replace)
 	app.add_domain(RTEMSDomain)
 	return {'version': "1.0", 'parallel_read_safe': True}
diff --git a/common/version.py b/common/version.py
index 281c880..bfe0e1b 100644
--- a/common/version.py
+++ b/common/version.py
@@ -111,6 +111,9 @@ def _pretty_day(ctx, date):
 def get(ctx, rtems_major_version):
     global _version
+    global _major
+    global _minor
+    global _revision
     global _date
     global _released
     version = _version
@@ -184,7 +187,7 @@ def minor():
     return _minor
 def revision():
-    return revision
+    return _revision
 def date():
     return _date
2.24.1
