[PATCH 3/5] versions: Update arm
chrisj at rtems.org
chrisj at rtems.org
Wed Aug 3 04:32:59 UTC 2022
Updates #4695
user/bsps/arm/altera-cyclone-v.rst | 2 +-
user/bsps/arm/beagle.rst | 11 +++----
user/bsps/arm/imx.rst | 6 ++--
user/bsps/arm/imxrt.rst | 33 +++++++++++----------
user/bsps/arm/raspberrypi.rst | 24 ++++++++--------
user/bsps/arm/xen.rst | 4 +--
user/bsps/bsps-arm.rst | 46 ++++++++++++++++--------------
7 files changed, 67 insertions(+), 59 deletions(-)
diff --git a/user/bsps/arm/altera-cyclone-v.rst b/user/bsps/arm/altera-cyclone-v.rst
index 14c026c..eaa02e3 100644
--- a/user/bsps/arm/altera-cyclone-v.rst
+++ b/user/bsps/arm/altera-cyclone-v.rst
@@ -27,7 +27,7 @@ image. Use the following commands:
.. code-block:: none
- arm-rtems5-objcopy -O binary app.exe app.bin
+ arm-rtems at rtems-ver-major@-objcopy -O binary app.exe app.bin
gzip -9 -f -c app.bin > app.bin.gz
mkimage -A arm -O linux -T kernel -a 0x00300000 -e 0x00300000 -n RTEMS -d app.bin.gz app.img
diff --git a/user/bsps/arm/beagle.rst b/user/bsps/arm/beagle.rst
index 696b89d..3a5c06f 100644
--- a/user/bsps/arm/beagle.rst
+++ b/user/bsps/arm/beagle.rst
@@ -32,7 +32,7 @@ To boot via uboot, the ELF must be converted to a U-Boot image like below:
- arm-rtems5-objcopy hello.exe -O binary app.bin
+ arm-rtems at rtems-ver-major@-objcopy hello.exe -O binary app.bin
gzip -9 app.bin
mkimage -A arm -O linux -T kernel -a 0x80000000 -e 0x80000000 -n RTEMS -d app.bin.gz rtems-app.img
@@ -77,7 +77,8 @@ overlay has to be provided. The overlay must add an additional attribute
For example,
-.. code-block::
+.. code-block:: none
/dts-v1/;
@@ -109,7 +110,7 @@ For registering with a custom path, the ``bsp_register_spi()`` can be used.
The function prototype is given below:
-.. code-block:: C
+.. code-block:: c
rtems_status_code bsp_register_spi(
const char *bus_path,
@@ -153,7 +154,7 @@ The modification is:
The resulting wiring is:
-.. code-block::
1 === /--=== 2
3 === | === 4
@@ -198,7 +199,7 @@ Cortex M only debuggers (like the Segger J-Link Edu Mini) won't work.
If the debugger offers a gdb server (like OpenOCD or Segger J-Link) the
following gdb start script can be used:
-.. code-block::
define reset
echo -- Reset target and wait for U-Boot to start kernel.\n
diff --git a/user/bsps/arm/imx.rst b/user/bsps/arm/imx.rst
index e2fd7f2..f0ac928 100644
--- a/user/bsps/arm/imx.rst
+++ b/user/bsps/arm/imx.rst
@@ -15,7 +15,9 @@ U-Boot or barebox.
Build Configuration Options
-The following options are available at the configure command line.
+The following options can be used in the BSP section of the waf
+configuration INI file. The waf defaults can be used to inspect the
+values.
``BSP_PRESS_KEY_FOR_RESET``
If defined to a non-zero value, then print a message and wait until pressed
@@ -73,7 +75,7 @@ image. Use the following commands:
mkimage -A arm -O linux -T kernel -a 0x80200000 -e 0x80200000 -n RTEMS -d app.bin.gz app.img
diff --git a/user/bsps/arm/imxrt.rst b/user/bsps/arm/imxrt.rst
index 6dacfd9..e185823 100644
--- a/user/bsps/arm/imxrt.rst
+++ b/user/bsps/arm/imxrt.rst
@@ -39,7 +39,7 @@ For programming the HyperFlash in case 1, you can use the on board debugger
integrated into the IMXRT1050-EVKB. You can generate a flash image out of a
compiled RTEMS application with for example::
- arm-rtems6-objcopy -O binary build/arm/imxrt1052/testsuites/samples/hello.exe hello.bin
+ arm-rtems at rtems-ver-major@-objcopy -O binary build/arm/imxrt1052/testsuites/samples/hello.exe hello.bin
Then just copy the generated binary to the mass storage provided by the
debugger. Wait a bit till the mass storage vanishes and re-appears. After that,
@@ -91,25 +91,26 @@ The BSP uses a FDT based initialization. The FDT is linked into the application.
You can find the default FDT used in the BSP in
`bsps/arm/imxrt/dts/imxrt1050-evkb.dts`. The FDT is split up into two parts. The
core part is put into an `dtsi` file and is installed together with normal
-headers into `${PREFIX}/arm-rtems6/imxrt1052/lib/include`. You can use that to
-create your own device tree based on that. Basically use something like::
+headers into `${PREFIX}/arm-rtems at rtems-ver-major@/imxrt1052/lib/include`. You
+can use that to create your own device tree based on that. Basically use
+something like::
/dts-v1/;
#include <imxrt/imxrt1050-pinfunc.h>
#include <imxrt/imxrt1050.dtsi>
&lpuart1 {
pinctrl-0 = <&pinctrl_lpuart1>;
status = "okay";
&chosen {
stdout-path = &lpuart1;
/* put your further devices here */
&iomuxc {
pinctrl_lpuart1: lpuart1grp {
fsl,pins = <
@@ -117,17 +118,19 @@ create your own device tree based on that. Basically use something like::
IMXRT_PAD_GPIO_AD_B0_13__LPUART1_RX 0x13000
/* put your further pinctrl groups here */
You can then convert your FDT into a C file with (replace `YOUR.dts` and similar
-with your FDT source names)::
+with your FDT source names):
- sh> arm-rtems6-cpp -P -x assembler-with-cpp \
- -I ${PREFIX}/arm-rtems6/imxrt1052/lib/include \
- -include "YOUR.dts" /dev/null | \
- dtc -O dtb -o "YOUR.dtb" -b 0 -p 64
+ sh> arm-rtems at rtems-ver-major@-cpp -P -x assembler-with-cpp \
+ -I ${PREFIX}/arm-rtems at rtems-ver-major@/imxrt1052/lib/include \
+ -include "YOUR.dts" /dev/null | \
+ dtc -O dtb -o "YOUR.dtb" -b 0 -p 64
sh> rtems-bin2c -A 8 -C -N imxrt_dtb "YOUR.dtb" "YOUR.c"
You'll get a C file which defines the `imxrt_dtb` array. Make sure that your new
@@ -145,7 +148,7 @@ can overwrite the following constant:
.. code-block:: c
#include "fsl_clock_config.h"
const clock_arm_pll_config_t armPllConfig_BOARD_BootClockRUN = {
.loopDivider = 100,
.src = 0,
diff --git a/user/bsps/arm/raspberrypi.rst b/user/bsps/arm/raspberrypi.rst
index 235134f..8f40e92 100644
--- a/user/bsps/arm/raspberrypi.rst
+++ b/user/bsps/arm/raspberrypi.rst
@@ -12,7 +12,7 @@ The default bootloader on the Raspberry Pi which is used to boot Raspbian
or other OS can be also used to boot RTEMS. U-boot can also be used.
Setup SD card
The Raspberry Pis have an unconventional booting mechanism. The GPU
boots first, initializes itself, runs the bootloader and starts the CPU.
@@ -20,13 +20,13 @@ The bootloader looks for a kernel image, by default the kernel images must
have a name of the form ``kernel*.img`` but this can be changed by adding
`kernel=<img_name>` to ``config.txt``.
-You must provide the required firmware files on the SD card for the GPU to proceed,
-and thereby to boot RTEMS.
-The BSP currently boots up with an older version of the official firmware. These files
-can be downloaded from
-`the Raspberry Pi Firmware Repository <https://github.com/raspberrypi/firmware/tree/1.20200601/boot>`_.
-You can remove the ``kernel*.img`` files if you want to, but don't touch
-the other files.
+You must provide the required firmware files on the SD card for the GPU to
+proceed, and thereby to boot RTEMS. The BSP currently boots up with an older
+version of the official firmware. These files can be downloaded from `the
+Raspberry Pi Firmware Repository
+<https://github.com/raspberrypi/firmware/tree/1.20200601/boot>`_. You can
+remove the ``kernel*.img`` files if you want to, but don't touch the other
+files.
Copy these files in to a SD card with FAT filesystem.
@@ -41,7 +41,7 @@ To create the kernel image:
- $ arm-rtems5-objcopy -Obinary hello.exe kernel.img
+ $ xsarm-rtems at rtems-ver-major@-objcopy -Obinary hello.exe kernel.img
Copy the kernel image to the SD card.
@@ -54,7 +54,7 @@ Make sure you have these lines below, in your ``config.txt``.
kernel=kernel.img
SPI Driver
SPI drivers are registered by the ``rpi_spi_init(bool bidirectional_mode)`` function.
@@ -72,7 +72,7 @@ SPI drivers are registered by the ``rpi_spi_init(bool bidirectional_mode)`` func
I2C Driver
I2C drivers are registered by the ``rpi_setup_i2c_bus()`` function.
@@ -132,7 +132,7 @@ In a new terminal, run GDB using
- $ arm-rtems5-gdb hello.exe
+ $ arm-rtems at rtems-ver-major@-gdb hello.exe
This will open GDB and will load the symbol table from hello.exe. Issue the
following commands in the GDB prompt.
diff --git a/user/bsps/arm/xen.rst b/user/bsps/arm/xen.rst
index c7085ce..d7538f0 100644
--- a/user/bsps/arm/xen.rst
+++ b/user/bsps/arm/xen.rst
@@ -42,13 +42,13 @@ The ``ticker.exe`` file can be found in the BSP build tree at:
- arm-rtems5/c/xen_virtual/testsuites/samples/ticker.exe
+ arm-rtems at rtems-ver-major@/c/xen_virtual/testsuites/samples/ticker.exe
The ``ticker.exe`` elf file must be translated to a binary format.
- arm-rtems5-objcopy -O binary ticker.exe ticker.bin
+ arm-rtems at rtems-ver-major@-objcopy -O binary ticker.exe ticker.bin
Then place the ``ticker.bin`` file on the dom0 filesystem.
diff --git a/user/bsps/bsps-arm.rst b/user/bsps/bsps-arm.rst
index 7f1e9d4..f1113e3 100644
--- a/user/bsps/bsps-arm.rst
+++ b/user/bsps/bsps-arm.rst
@@ -6,25 +6,27 @@
arm (ARM)
-.. include:: arm/altera-cyclone-v.rst
-.. include:: arm/atsam.rst
-.. include:: arm/beagle.rst
-.. include:: arm/csb336.rst
-.. include:: arm/csb337.rst
-.. include:: arm/edb7312.rst
-.. include:: arm/gumstix.rst
-.. include:: arm/imx.rst
-.. include:: arm/imxrt.rst
-.. include:: arm/lm3s69xx.rst
-.. include:: arm/lpc176x.rst
-.. include:: arm/lpc24xx.rst
-.. include:: arm/raspberrypi.rst
-.. include:: arm/realview-pbx-a9.rst
-.. include:: arm/rtl22xx.rst
-.. include:: arm/smdk2410.rst
-.. include:: arm/stm32f4.rst
-.. include:: arm/stm32h7.rst
-.. include:: arm/tms570.rst
-.. include:: arm/xen.rst
-.. include:: arm/xilinx-zynq.rst
-.. include:: arm/xilinx-zynqmp.rst
+.. toctree::
+ arm/altera-cyclone-v.rst
+ arm/atsam.rst
+ arm/beagle.rst
+ arm/csb336.rst
+ arm/csb337.rst
+ arm/edb7312.rst
+ arm/gumstix.rst
+ arm/imx.rst
+ arm/imxrt.rst
+ arm/lm3s69xx.rst
+ arm/lpc176x.rst
+ arm/lpc24xx.rst
+ arm/raspberrypi.rst
+ arm/realview-pbx-a9.rst
+ arm/rtl22xx.rst
+ arm/smdk2410.rst
+ arm/stm32f4.rst
+ arm/stm32h7.rst
+ arm/tms570.rst
+ arm/xen.rst
+ arm/xilinx-zynq.rst
+ arm/xilinx-zynqmp.rst
2.24.1
