[PATCH 4/5] versions: Update microblaze, powerpc, riscv and x86_64
chrisj at rtems.org
chrisj at rtems.org
Wed Aug 3 04:33:00 UTC 2022
Updates #4695
user/bsps/bsps-microblaze.rst | 10 +++++-----
user/bsps/bsps-powerpc.rst | 8 ++++----
user/bsps/bsps-riscv.rst | 3 ++-
user/bsps/bsps-x86_64.rst | 2 +-
4 files changed, 12 insertions(+), 11 deletions(-)
diff --git a/user/bsps/bsps-microblaze.rst b/user/bsps/bsps-microblaze.rst
index e20df53..32aad90 100644
--- a/user/bsps/bsps-microblaze.rst
+++ b/user/bsps/bsps-microblaze.rst
@@ -53,8 +53,8 @@ The name ``system_dtb`` is significant as it is the name expected by the BSP.
$ rtems-bin2c -C -A 8 -N system_dtb my_device_tree.dtb my_dtb
The ``BSP_MICROBLAZE_FPGA_DTB_HEADER_PATH`` BSP configuration option can then be
-set to the path of the resulting source file, ``my_dtb.c``, to include it in the
-BSP build.
+set to the path of the resulting source file, ``my_dtb.c``, in the waf INI file
+to include it in the BSP build.
.. code-block:: none
@@ -64,7 +64,7 @@ BSP build.
Running Executables
-A .dtb (device tree blob) file should be provided to QEMU via the ``-hw-dtb``
+A ``.dtb`` (device tree blob) file should be provided to QEMU via the ``-hw-dtb``
option. In the example command below, the device tree blob comes from the Xilinx
Petalinux KCU105 MicroBlaze BSP (https://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/embedded-design-tools.html).
@@ -94,7 +94,7 @@ Then start GDB and connect to QEMU.
- $ microblaze-rtems6-gdb build/microblaze/kcu105_qemu/testsuites/samples/hello.exe
+ $ microblaze-rtems at rtems-ver-major@-gdb build/microblaze/kcu105_qemu/testsuites/samples/hello.exe
(gdb) target remote localhost:1234
(gdb) break Init
(gdb) continue
@@ -146,7 +146,7 @@ application, and debug as usual. By default the GDB server listens on port 3002.
- $ microblaze-rtems6-gdb example.exe
+ $ microblaze-rtems at rtems-ver-major@-gdb example.exe
(gdb) target extended-remote localhost:3002
(gdb) load
(gdb) break Init
diff --git a/user/bsps/bsps-powerpc.rst b/user/bsps/bsps-powerpc.rst
index 80edfae..3d1ce88 100644
--- a/user/bsps/bsps-powerpc.rst
+++ b/user/bsps/bsps-powerpc.rst
@@ -36,10 +36,10 @@ image. Use the following commands:
- powerpc-rtems5-objcopy -O binary -R .comment -S ticker.exe rtems
+ powerpc-rtems at rtems-ver-major@-objcopy -O binary -R .comment -S ticker.exe rtems
gzip -9 -f rtems
- powerpc-rtems5-ld -o ticker.boot bootloader.o --just-symbols=ticker.exe -b binary rtems.gz -T ppcboot.lds -no-warn-mismatch
- powerpc-rtems5-objcopy -O binary ticker.boot ticker.bin
+ powerpc-rtems at rtems-ver-major@-ld -o ticker.boot bootloader.o --just-symbols=ticker.exe -b binary rtems.gz -T ppcboot.lds -no-warn-mismatch
+ powerpc-rtems at rtems-ver-major@-objcopy -O binary ticker.boot ticker.bin
mpc55xxevb
@@ -107,7 +107,7 @@ image. Use the following commands:
- powerpc-rtems5-objcopy -O binary app.exe app.bin
+ powerpc-rtems at rtems-ver-major@-objcopy -O binary app.exe app.bin
gzip -9 -f -c app.bin > app.bin.gz
mkimage -A ppc -O linux -T kernel -a 0x4000 -e 0x4000 -n RTEMS -d app.bin.gz app.img
diff --git a/user/bsps/bsps-riscv.rst b/user/bsps/bsps-riscv.rst
index 0799ad6..5faa87b 100644
--- a/user/bsps/bsps-riscv.rst
+++ b/user/bsps/bsps-riscv.rst
@@ -50,7 +50,8 @@ The reference platform for this BSP is the Qemu `virt` machine.
Build Configuration Options
-The following options are available at the configure command line.
+The following options can be used in the BSP section of the ``waf``
+configuration INI file. The ``waf`` defaults can be used to inspect the values.
``BSP_PRESS_KEY_FOR_RESET``
If defined to a non-zero value, then print a message and wait until pressed
diff --git a/user/bsps/bsps-x86_64.rst b/user/bsps/bsps-x86_64.rst
index eefffab..a7f7326 100644
--- a/user/bsps/bsps-x86_64.rst
+++ b/user/bsps/bsps-x86_64.rst
@@ -20,7 +20,7 @@ in the RTEMS testsuite.
-There are no options available to ``configure`` at build time, at the moment.
+There are no BSP configuration options available at build time.
Testing with QEMU
2.24.1
