i2c device initialization on MVME3100 RTEMS5 (presumably also in 6?)
Heinz Junkes
junkes at fhi-berlin.mpg.de
Thu Aug 4 07:47:57 UTC 2022
Hi Chris,
sorry, I had cut that off :-(
It is addressed in a hook (in bspstart.c)
static void mvme3100_i2c_initialize(void)
printk("-------- call BSP_i2c_initialize() with _IO_All_drivers_initialized = true\n");
* we need the drivers registered as they appear, due to get
* the i2c devices ready
_IO_All_drivers_initialized = true;
BSP_i2c_initialize();
_IO_All_drivers_initialized = false;
RTEMS_SYSINIT_ITEM(
mvme3100_i2c_initialize,
RTEMS_SYSINIT_BSP_PRE_DRIVERS,
RTEMS_SYSINIT_ORDER_MIDDLE
Viele Grüße
Heinz
> On 4. Aug 2022, at 03:31, Chris Johns <chrisj at rtems.org> wrote:
> On 3/8/2022 9:52 pm, Heinz Junkes wrote:
>> We had a problem initialising the i2c devices on the MVME3100.
>> Unfortunately, I still don't understand the order of initialisation.
>> However, the direct driver initialisation from bspstart no longer worked as it did with older versions.
>> My workaround therefore looks like this:
>> rtems at rtems-dev:~/MVME3100/kernel$ git diff bsps/powerpc/mvme3100/start/bspstart.c
>> diff --git a/bsps/powerpc/mvme3100/start/bspstart.c b/bsps/powerpc/mvme3100/start/bspstart.c
>> index 0ec215e33b..96d6e2f9cd 100644
>> --- a/bsps/powerpc/mvme3100/start/bspstart.c
>> +++ b/bsps/powerpc/mvme3100/start/bspstart.c
>> @@ -52,6 +52,8 @@
>> extern unsigned long __rtems_end[];
>> extern unsigned ppc_exc_lock_std, ppc_exc_gpr3_std;
>> +extern bool _IO_All_drivers_initialized;
>> * Copy Additional boot param passed by boot loader
>> @@ -419,7 +421,14 @@ void bsp_start( void )
>> + printk("-------- call BSP_i2c_initialize() with _IO_All_drivers_initialized = true\n");
>> + * we need the drivers registered as they appear, due to get
>> + * the i2c devices ready
>> + _IO_All_drivers_initialized = true;
>> + _IO_All_drivers_initialized = false;
> Where is this being called? I cannot see it in the patch. If it is BSP start I
> think it is too early to make these calls.
>> RTEMS_SYSINIT_ITEM(
>> You can find this in cpukit/sapi/src/ioregisterdriver.c:
>> if ( _IO_All_drivers_initialized ) {
>> /* Other drivers have already been initialized, we initialize
>> * the driver directly.
>> return rtems_io_initialize( major, 0, NULL );
>> } else {
>> /* The driver will be initialized together with all other drivers
>> * in a later stage by _IO_Initialize_all_drivers().
>> return RTEMS_SUCCESSFUL;
>> I can imagine that this is not an elegant way, but it's the best I could do. Is there any idea how to do it "right"?
>> Or should I submit this patch?
> I suspect touching that internal variable is not great. That variable could go
> away or be made static.
> There maybe another BSP hook that could be used or a SYSINIT hook maybe be needed.
> Chris
