[PATCH rtems 1/2] Add support for CONFIGURE_POSIX_TIMERS_FACE_BEHAVIOR
Joel Sherrill
joel at rtems.org
Thu Aug 4 22:08:04 UTC 2022
This adds the configure option CONFIGURE_POSIX_TIMERS_FACE_BEHAVIOR
which allows the application to choose whether to have the POSIX
timer_create() function follow the behavior defined by POSIX or
the FACE Technical Standard.
Updates #4691.
cpukit/include/rtems/confdefs.h | 1 +
cpukit/include/rtems/confdefs/face.h | 71 +++++++++++++++++
cpukit/include/rtems/posix/timerimpl.h | 11 +++
cpukit/posix/src/psxtimercreate.c | 19 ++++-
spec/build/testsuites/psxtests/grp.yml | 2 +
spec/build/testsuites/psxtests/psxtimer_face01.yml | 20 +++++
testsuites/psxtests/psxtimer_face01/psxtimer.c | 89 ++++++++++++++++++++++
.../psxtests/psxtimer_face01/psxtimer_face01.doc | 39 ++++++++++
.../psxtests/psxtimer_face01/psxtimer_face01.scn | 4 +
9 files changed, 255 insertions(+), 1 deletion(-)
create mode 100644 cpukit/include/rtems/confdefs/face.h
create mode 100644 spec/build/testsuites/psxtests/psxtimer_face01.yml
create mode 100644 testsuites/psxtests/psxtimer_face01/psxtimer.c
create mode 100644 testsuites/psxtests/psxtimer_face01/psxtimer_face01.doc
create mode 100644 testsuites/psxtests/psxtimer_face01/psxtimer_face01.scn
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index e6dd3d7..3927d26 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -64,6 +64,7 @@
#include <rtems/confdefs/clock.h>
#include <rtems/confdefs/console.h>
#include <rtems/confdefs/extensions.h>
+#include <rtems/confdefs/face.h>
#include <rtems/confdefs/inittask.h>
#include <rtems/confdefs/initthread.h>
#include <rtems/confdefs/iodrivers.h>
diff --git a/cpukit/include/rtems/confdefs/face.h b/cpukit/include/rtems/confdefs/face.h
new file mode 100644
index 0000000..07ab62e
--- /dev/null
+++ b/cpukit/include/rtems/confdefs/face.h
@@ -0,0 +1,71 @@
+ * @file
+ * @ingroup RTEMSImplApplConfig
+ * @brief This header file evaluates configuration options related to
+ * the FACE Technical Standard.
+ * The FACE Technical Standard (https://opengroup.org/face) is an
+ * open standard designed for safety critical embedded systems. It
+ * includes POSIX profiles and requirements that promote safety
+ * and portability. As a general rules, the profiles place a minimum
+ * on the services which an operating system must provide. Those
+ * same profile definitions represent the maximum services which
+ * an application may use.
+ * Copyright (C) 2022 On-Line Applications Research Corporation (OAR)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifndef _RTEMS_CONFDEFS_FACE_H
+#define _RTEMS_CONFDEFS_FACE_H
+#ifndef __CONFIGURATION_TEMPLATE_h
+#error "Do not include this file directly, use <rtems/confdefs.h> instead"
+#endif
+#ifdef CONFIGURE_INIT
+#include <rtems/posix/timerimpl.h>
+#ifndef CONFIGURE_POSIX_TIMERS_FACE_BEHAVIOR
+ bool _POSIX_Timer_Is_allowed_on_CLOCK_REALTIME( void )
+ * Per the FACE Technical Standard, POSIX timers should not be
+ * allowed on CLOCK_REALTIME for safety reasons. If the application
+ * wants the FACE behavior, then this method is instantiated.
+ return false;
+#endif /* CONFIGURE_POSIX_TIMERS_FACE_BEHAVIOR */
+#endif /* CONFIGURE_INIT */
+#endif /* _RTEMS_CONFDEFS_FACE_H */
diff --git a/cpukit/include/rtems/posix/timerimpl.h b/cpukit/include/rtems/posix/timerimpl.h
index 8f92186..c6e3b64 100644
--- a/cpukit/include/rtems/posix/timerimpl.h
+++ b/cpukit/include/rtems/posix/timerimpl.h
@@ -139,6 +139,17 @@ RTEMS_INLINE_ROUTINE void _POSIX_Timer_Release(
_ISR_lock_ISR_enable( lock_context );
+ * @brief Follow POSIX or FACE Technical Standard on timer_create
+ * POSIX allows for the creation of timers based on CLOCK_REALTIME.
+ * This is viewed as a safety issue by the FACE Technical Standard
+ * and required to return an error. These are conflicting behaviors.
+ * This method is instanced by configuration when FACE conformant
+ * behavior is desired by the application.
+RTEMS_WEAK bool _POSIX_Timer_Is_allowed_on_CLOCK_REALTIME( void );
#ifdef __cplusplus
#endif
diff --git a/cpukit/posix/src/psxtimercreate.c b/cpukit/posix/src/psxtimercreate.c
index 0eefac3..9db9ec9 100644
--- a/cpukit/posix/src/psxtimercreate.c
+++ b/cpukit/posix/src/psxtimercreate.c
@@ -51,6 +51,18 @@
#include <rtems/seterr.h>
#include <rtems/sysinit.h>
+ * Allow timer_create(CLOCK_REALTIME. ...) per POSIX by default.
+ * configures that it wants the FACE behavior, then this method
+ * is overridden by <rtems/confdefs/face.h>.
+ return true;
int timer_create(
clockid_t clock_id,
struct sigevent *__restrict evp,
@@ -59,8 +71,13 @@ int timer_create(
POSIX_Timer_Control *ptimer;
- if ( clock_id != CLOCK_REALTIME && clock_id != CLOCK_MONOTONIC )
+ if ( clock_id == CLOCK_REALTIME ) {
+ if ( ! _POSIX_Timer_Is_allowed_on_CLOCK_REALTIME() ) {
+ rtems_set_errno_and_return_minus_one( EPERM );
+ } else if ( clock_id != CLOCK_MONOTONIC ) {
rtems_set_errno_and_return_minus_one( EINVAL );
if ( !timerid )
diff --git a/spec/build/testsuites/psxtests/grp.yml b/spec/build/testsuites/psxtests/grp.yml
index 5653879..354f9e7 100644
--- a/spec/build/testsuites/psxtests/grp.yml
+++ b/spec/build/testsuites/psxtests/grp.yml
@@ -240,6 +240,8 @@ links:
- role: build-dependency
uid: psxtimer02
+ uid: psxtimer_face01
+- role: build-dependency
uid: psxtimes01
uid: psxualarm
diff --git a/spec/build/testsuites/psxtests/psxtimer_face01.yml b/spec/build/testsuites/psxtests/psxtimer_face01.yml
index 0000000..9169525
--- /dev/null
+++ b/spec/build/testsuites/psxtests/psxtimer_face01.yml
@@ -0,0 +1,20 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: test-program
+cflags: []
+copyrights:
+- Copyright (C) 2022. On-Line Applications Research Corporation (OAR).
+cppflags: []
+cxxflags: []
+enabled-by:
+- RTEMS_POSIX_API
+features: c cprogram
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/psxtests/psxtimer_face01/psxtimer.c
+stlib: []
+target: testsuites/psxtests/psxtimer_face01.exe
+type: build
+use-after: []
+use-before: []
diff --git a/testsuites/psxtests/psxtimer_face01/psxtimer.c b/testsuites/psxtests/psxtimer_face01/psxtimer.c
index 0000000..261375a
--- /dev/null
+++ b/testsuites/psxtests/psxtimer_face01/psxtimer.c
@@ -0,0 +1,89 @@
+ * @file POSIX Timer Test of FACE Behavior
+ * COPYRIGHT (c) 2022. On-Line Applications Research Corporation (OAR).
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <pmacros.h>
+#include "tmacros.h"
+#include <unistd.h>
+#include <errno.h>
+#include <sched.h>
+#include <time.h> /* time facilities */
+#include <stdio.h> /* console facilities */
+const char rtems_test_name[] = "PSXTIMER 2";
+static void *POSIX_Init (
+ void *argument
+ struct sigevent event;
+ int status;
+ timer_t timer;
+ * If these are not filled in correctly, we don't pass its error checking.
+ event.sigev_notify = SIGEV_SIGNAL;
+ event.sigev_signo = SIGUSR1;
+ TEST_BEGIN();
+ puts( "timer_create - CLOCK_REALTIME forbidden - EPERM" );
+ status = timer_create( CLOCK_REALTIME, &event, NULL );
+ fatal_posix_service_status_errno( status, EPERM, "not allowed" );
+ TEST_END();
+ rtems_test_exit (0);
+/* configuration information */
+#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_POSIX_INIT_THREAD_TABLE
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_MAXIMUM_POSIX_THREADS 1
+#define CONFIGURE_MAXIMUM_POSIX_TIMERS 1
+#define CONFIGURE_POSIX_TIMERS_FACE_BEHAVIOR
+#include <rtems/confdefs.h>
+/* end of include file */
diff --git a/testsuites/psxtests/psxtimer_face01/psxtimer_face01.doc b/testsuites/psxtests/psxtimer_face01/psxtimer_face01.doc
index 0000000..8238531
--- /dev/null
+++ b/testsuites/psxtests/psxtimer_face01/psxtimer_face01.doc
@@ -0,0 +1,39 @@
+# SPDX-License-Identifier: BSD-2-Clause
+# COPYRIGHT (c) 1989-2009.
+# On-Line Applications Research Corporation (OAR).
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions
+# are met:
+# 1. Redistributions of source code must retain the above copyright
+# notice, this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright
+# notice, this list of conditions and the following disclaimer in the
+# documentation and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
+This file describes the directives and concepts tested by this test set.
+test set name: psxtimer_face01
+directives:
+ timer_create
+ CONFIGURE_POSIX_TIMERS_FACE_BEHAVIOR
+concepts:
++ This test exercises the CONFIGURE_POSIX_TIMERS_FACE_BEHAVIOR configure
+ option which alters the behavior of timer_create().
diff --git a/testsuites/psxtests/psxtimer_face01/psxtimer_face01.scn b/testsuites/psxtests/psxtimer_face01/psxtimer_face01.scn
index 0000000..4dab798
--- /dev/null
+++ b/testsuites/psxtests/psxtimer_face01/psxtimer_face01.scn
@@ -0,0 +1,4 @@
+*** BEGIN OF TEST PSXTIMER 2 ***
+*** TEST VERSION: 6.0.0.1c6ac88f938f4b135f3bbffc4b19bbc540508c80
+*** END OF TEST PSXTIMER 2 ***
1.8.3.1
