[PATCH rtems 1/2] Add support for CONFIGURE_POSIX_TIMERS_FACE_BEHAVIOR
Fri Aug 5 10:45:32 UTC 2022
On 05/08/2022 00:08, Joel Sherrill wrote:
> This adds the configure option CONFIGURE_POSIX_TIMERS_FACE_BEHAVIOR
> which allows the application to choose whether to have the POSIX
> timer_create() function follow the behavior defined by POSIX or
> the FACE Technical Standard.
> Updates #4691.
It would be nice if you could add items for the new option to
rtems-central so that we can use it for the Doxygen documentation and
the manual.
>   cpukit/include/rtems/confdefs.h                    |  1 +
>   cpukit/include/rtems/confdefs/face.h               | 71 +++++++++++++++++
>   cpukit/include/rtems/posix/timerimpl.h             | 11 +++
>   cpukit/posix/src/psxtimercreate.c                  | 19 ++++-
>   spec/build/testsuites/psxtests/grp.yml             |  2 +
>   spec/build/testsuites/psxtests/psxtimer_face01.yml | 20 +++++
>   testsuites/psxtests/psxtimer_face01/psxtimer.c     | 89 ++++++++++++++++++++++
>   .../psxtests/psxtimer_face01/psxtimer_face01.doc   | 39 ++++++++++
>   .../psxtests/psxtimer_face01/psxtimer_face01.scn   |  4 +
>   9 files changed, 255 insertions(+), 1 deletion(-)
>   create mode 100644 cpukit/include/rtems/confdefs/face.h
>   create mode 100644 spec/build/testsuites/psxtests/psxtimer_face01.yml
>   create mode 100644 testsuites/psxtests/psxtimer_face01/psxtimer.c
>   create mode 100644 testsuites/psxtests/psxtimer_face01/psxtimer_face01.doc
>   create mode 100644 testsuites/psxtests/psxtimer_face01/psxtimer_face01.scn
> diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
> index e6dd3d7..3927d26 100644
> --- a/cpukit/include/rtems/confdefs.h
> +++ b/cpukit/include/rtems/confdefs.h
> @@ -64,6 +64,7 @@
>   #include <rtems/confdefs/clock.h>
>   #include <rtems/confdefs/console.h>
>   #include <rtems/confdefs/extensions.h>
> +#include <rtems/confdefs/face.h>
>   #include <rtems/confdefs/inittask.h>
>   #include <rtems/confdefs/initthread.h>
>   #include <rtems/confdefs/iodrivers.h>
> diff --git a/cpukit/include/rtems/confdefs/face.h b/cpukit/include/rtems/confdefs/face.h
> new file mode 100644
> index 0000000..07ab62e
> --- /dev/null
> +++ b/cpukit/include/rtems/confdefs/face.h
> @@ -0,0 +1,71 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
> + * @file
> + * @ingroup RTEMSImplApplConfig
> + * @brief This header file evaluates configuration options related to
> + *   the FACE Technical Standard.
> + * The FACE Technical Standard (https://opengroup.org/face) is an
> + * open standard designed for safety critical embedded systems. It
> + * includes POSIX profiles and requirements that promote safety
> + * and portability. As a general rules, the profiles place a minimum
> + * on the services which an operating system must provide. Those
> + * same profile definitions represent the maximum services which
> + * an application may use.
> + * Copyright (C) 2022 On-Line Applications Research Corporation (OAR)
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#ifndef _RTEMS_CONFDEFS_FACE_H
> +#define _RTEMS_CONFDEFS_FACE_H
> +#ifndef __CONFIGURATION_TEMPLATE_h
> +#error "Do not include this file directly, use <rtems/confdefs.h> instead"
> +#endif
> +#ifdef CONFIGURE_INIT
> +#include <rtems/posix/timerimpl.h>
> +#ifndef CONFIGURE_POSIX_TIMERS_FACE_BEHAVIOR
> +  bool _POSIX_Timer_Is_allowed_on_CLOCK_REALTIME( void )
> +     * Per the FACE Technical Standard, POSIX timers should not be
> +     * allowed on CLOCK_REALTIME for safety reasons. If the application
> +     * wants the FACE behavior, then this method is instantiated.
> +    return false;
I would change this to:
int _POSIX_Timer_Is_clock_valid( clockid_t clock_id )
It returns an error number or zero.
> +#endif /* CONFIGURE_POSIX_TIMERS_FACE_BEHAVIOR */
> +#endif /* CONFIGURE_INIT */
> +#endif /* _RTEMS_CONFDEFS_FACE_H */
> diff --git a/cpukit/include/rtems/posix/timerimpl.h b/cpukit/include/rtems/posix/timerimpl.h
> index 8f92186..c6e3b64 100644
> --- a/cpukit/include/rtems/posix/timerimpl.h
> +++ b/cpukit/include/rtems/posix/timerimpl.h
> @@ -139,6 +139,17 @@ RTEMS_INLINE_ROUTINE void _POSIX_Timer_Release(
>     _ISR_lock_ISR_enable( lock_context );
> + * @brief Follow POSIX or FACE Technical Standard on timer_create
> + * POSIX allows for the creation of timers based on CLOCK_REALTIME.
> + * This is viewed as a safety issue by the FACE Technical Standard
> + * and required to return an error. These are conflicting behaviors.
> + * This method is instanced by configuration when FACE conformant
> + * behavior is desired by the application.
> +RTEMS_WEAK bool _POSIX_Timer_Is_allowed_on_CLOCK_REALTIME( void );
No RTEMS_WEAK in the header file.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
