[PATCH rtems 2/2] psxtimer0[12]/psxtimer.c: Reformat file header.
Thu Aug 4 22:08:05 UTC 2022
 testsuites/psxtests/psxtimer01/psxtimer.c | 9 ++++++---
 testsuites/psxtests/psxtimer02/psxtimer.c | 9 ++++++---
 2 files changed, 12 insertions(+), 6 deletions(-)
diff --git a/testsuites/psxtests/psxtimer01/psxtimer.c b/testsuites/psxtests/psxtimer01/psxtimer.c
index 560dc2e..57d23c1 100644
--- a/testsuites/psxtests/psxtimer01/psxtimer.c
+++ b/testsuites/psxtests/psxtimer01/psxtimer.c
@@ -1,6 +1,7 @@
 /* SPDX-License-Identifier: BSD-2-Clause */
+ * @file POSIX Timer Test
  *  This is a simple real-time applications which contains 3 periodic tasks.
@@ -12,8 +13,10 @@
  *  The share data is protected with a POSIX mutex.
- *  Other POSIX facilities such as timers, condition, .. is also used
+ *  Other POSIX facilities such as timers, condition, .. are also used.
  *  COPYRIGHT (c) 1989-2009.
  *  On-Line Applications Research Corporation (OAR).
diff --git a/testsuites/psxtests/psxtimer02/psxtimer.c b/testsuites/psxtests/psxtimer02/psxtimer.c
index 7da0f7a..26d1d5a 100644
--- a/testsuites/psxtests/psxtimer02/psxtimer.c
+++ b/testsuites/psxtests/psxtimer02/psxtimer.c
@@ -1,6 +1,7 @@
+ * @file POSIX Timer Test #2
@@ -12,8 +13,10 @@
1.8.3.1
