[PATCH v6 05/10] bsps/arm/stm32f4: Add HAL to build
Duc Doan dtbpkmte at gmail.com
Sun Aug 7 10:58:17 UTC 2022
This patch modifies some HAL headers to connect with RTEMS
and add HAL code to build. It also adds some options to
enable HAL, specify clock source and chip variant.
 bsps/arm/stm32f4/include/bsp/io.h             |   4 +
 bsps/arm/stm32f4/include/stm32f4xx.h          |   4 +
 bsps/arm/stm32f4/include/stm32f4xx_hal_conf.h | 506 ++++++++++++++++++
 spec/build/bsps/arm/stm32f4/grp.yml           |  12 +-
 spec/build/bsps/arm/stm32f4/obj.yml           | 220 +++++++-
 spec/build/bsps/arm/stm32f4/optenhal.yml      |  16 +
 spec/build/bsps/arm/stm32f4/opthse.yml        |  17 +
 spec/build/bsps/arm/stm32f4/optusehse.yml     |  16 +
 spec/build/bsps/arm/stm32f4/optvariant.yml    |  24 +
 9 files changed, 816 insertions(+), 3 deletions(-)
 create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_conf.h
 create mode 100644 spec/build/bsps/arm/stm32f4/optenhal.yml
 create mode 100644 spec/build/bsps/arm/stm32f4/opthse.yml
 create mode 100644 spec/build/bsps/arm/stm32f4/optusehse.yml
 create mode 100644 spec/build/bsps/arm/stm32f4/optvariant.yml
diff --git a/bsps/arm/stm32f4/include/bsp/io.h b/bsps/arm/stm32f4/include/bsp/io.h
index 4fa39bdca9..9cdb96fa49 100644
--- a/bsps/arm/stm32f4/include/bsp/io.h
+++ b/bsps/arm/stm32f4/include/bsp/io.h
@@ -19,6 +19,10 @@
 #include <stdint.h>
 #include <bspopts.h>
+#ifdef __rtems__
+#include <stm32f4xx.h>
+#endif /* __rtems__ */
 #ifdef __cplusplus
 extern "C" {
 #endif /* __cplusplus */
diff --git a/bsps/arm/stm32f4/include/stm32f4xx.h b/bsps/arm/stm32f4/include/stm32f4xx.h
index 2c3482db4f..e246f579ce 100644
--- a/bsps/arm/stm32f4/include/stm32f4xx.h
+++ b/bsps/arm/stm32f4/include/stm32f4xx.h
@@ -37,6 +37,10 @@
 #ifndef __STM32F4xx_H
 #define __STM32F4xx_H
+#ifdef __rtems__
+#include <bspopts.h>
 #ifdef __cplusplus
  extern "C" {
diff --git a/bsps/arm/stm32f4/include/stm32f4xx_hal_conf.h b/bsps/arm/stm32f4/include/stm32f4xx_hal_conf.h
new file mode 100644
index 0000000000..51603cae20
--- /dev/null
+++ b/bsps/arm/stm32f4/include/stm32f4xx_hal_conf.h
@@ -0,0 +1,506 @@
+  * @file    stm32f4xx_hal_conf_template.h
+  * @author  MCD Application Team
+  * @brief   HAL configuration template file.
+  *          This file should be copied to the application folder and renamed
+  *          to stm32f4xx_hal_conf.h.
+  * @attention
+  * Copyright (c) 2017 STMicroelectronics.
+  * All rights reserved.
+  * This software is licensed under terms that can be found in the LICENSE file
+  * in the root directory of this software component.
+  * If no LICENSE file comes with this software, it is provided AS-IS.
+/* Define to prevent recursive inclusion -------------------------------------*/
+#ifndef __STM32F4xx_HAL_CONF_H
+#define __STM32F4xx_HAL_CONF_H
+#ifdef __rtems__
+#define HSE_VALUE ((uint32_t) STM32F4_HSE_FREQUENCY)
+#ifdef __cplusplus
+ extern "C" {
+#endif
+/* Exported types ------------------------------------------------------------*/
+/* Exported constants --------------------------------------------------------*/
+/* ########################## Module Selection ############################## */
+  * @brief This is the list of modules to be used in the HAL driver
+#define HAL_MODULE_ENABLED
+#define HAL_ADC_MODULE_ENABLED
+#define HAL_CAN_MODULE_ENABLED
+/* #define HAL_CAN_LEGACY_MODULE_ENABLED */
+#define HAL_CRC_MODULE_ENABLED
+#define HAL_CEC_MODULE_ENABLED
+#define HAL_CRYP_MODULE_ENABLED
+#define HAL_DAC_MODULE_ENABLED
+#define HAL_DCMI_MODULE_ENABLED
+#define HAL_DMA_MODULE_ENABLED
+#define HAL_DMA2D_MODULE_ENABLED
+#define HAL_ETH_MODULE_ENABLED
+#define HAL_FLASH_MODULE_ENABLED
+#define HAL_NAND_MODULE_ENABLED
+#define HAL_NOR_MODULE_ENABLED
+#define HAL_PCCARD_MODULE_ENABLED
+#define HAL_SRAM_MODULE_ENABLED
+#define HAL_SDRAM_MODULE_ENABLED
+#define HAL_HASH_MODULE_ENABLED
+#define HAL_GPIO_MODULE_ENABLED
+#define HAL_EXTI_MODULE_ENABLED
+#define HAL_I2C_MODULE_ENABLED
+#define HAL_SMBUS_MODULE_ENABLED
+#define HAL_I2S_MODULE_ENABLED
+#define HAL_IWDG_MODULE_ENABLED
+#define HAL_LTDC_MODULE_ENABLED
+#define HAL_DSI_MODULE_ENABLED
+#define HAL_PWR_MODULE_ENABLED
+#define HAL_QSPI_MODULE_ENABLED
+#define HAL_RCC_MODULE_ENABLED
+#define HAL_RNG_MODULE_ENABLED
+#define HAL_RTC_MODULE_ENABLED
+#define HAL_SAI_MODULE_ENABLED
+#define HAL_SD_MODULE_ENABLED
+#define HAL_SPI_MODULE_ENABLED
+#define HAL_TIM_MODULE_ENABLED
+#define HAL_UART_MODULE_ENABLED
+#define HAL_USART_MODULE_ENABLED
+#define HAL_IRDA_MODULE_ENABLED
+#define HAL_SMARTCARD_MODULE_ENABLED
+#define HAL_WWDG_MODULE_ENABLED
+#define HAL_CORTEX_MODULE_ENABLED
+#define HAL_PCD_MODULE_ENABLED
+#define HAL_HCD_MODULE_ENABLED
+#define HAL_FMPI2C_MODULE_ENABLED
+#define HAL_FMPSMBUS_MODULE_ENABLED
+#define HAL_SPDIFRX_MODULE_ENABLED
+#define HAL_DFSDM_MODULE_ENABLED
+#define HAL_LPTIM_MODULE_ENABLED
+#define HAL_MMC_MODULE_ENABLED
+/* ########################## HSE/HSI Values adaptation ##################### */
+  * @brief Adjust the value of External High Speed oscillator (HSE) used in your application.
+  *        This value is used by the RCC HAL module to compute the system frequency
+  *        (when HSE is used as system clock source, directly or through the PLL).
+#if !defined  (HSE_VALUE)
+  #define HSE_VALUE              25000000U /*!< Value of the External oscillator in Hz */
+#endif /* HSE_VALUE */
+#if !defined  (HSE_STARTUP_TIMEOUT)
+  #define HSE_STARTUP_TIMEOUT    100U      /*!< Time out for HSE start up, in ms */
+#endif /* HSE_STARTUP_TIMEOUT */
+  * @brief Internal High Speed oscillator (HSI) value.
+  *        (when HSI is used as system clock source, directly or through the PLL).
+#if !defined  (HSI_VALUE)
+  #define HSI_VALUE              16000000U /*!< Value of the Internal oscillator in Hz */
+#endif /* HSI_VALUE */
+  * @brief Internal Low Speed oscillator (LSI) value.
+#if !defined  (LSI_VALUE)
+ #define LSI_VALUE               32000U    /*!< LSI Typical Value in Hz */
+#endif /* LSI_VALUE */                     /*!< Value of the Internal Low Speed oscillator in Hz
+                                                The real value may vary depending on the variations
+                                                in voltage and temperature. */
+  * @brief External Low Speed oscillator (LSE) value.
+#if !defined  (LSE_VALUE)
+ #define LSE_VALUE               32768U    /*!< Value of the External Low Speed oscillator in Hz */
+#endif /* LSE_VALUE */
+#if !defined  (LSE_STARTUP_TIMEOUT)
+  #define LSE_STARTUP_TIMEOUT    5000U     /*!< Time out for LSE start up, in ms */
+#endif /* LSE_STARTUP_TIMEOUT */
+  * @brief External clock source for I2S peripheral
+  *        This value is used by the I2S HAL module to compute the I2S clock source
+  *        frequency, this source is inserted directly through I2S_CKIN pad.
+#if !defined  (EXTERNAL_CLOCK_VALUE)
+  #define EXTERNAL_CLOCK_VALUE     12288000U /*!< Value of the External oscillator in Hz*/
+#endif /* EXTERNAL_CLOCK_VALUE */
+/* Tip: To avoid modifying this file each time you need to use different HSE,
+   ===  you can define the HSE value in your toolchain compiler preprocessor. */
+/* ########################### System Configuration ######################### */
+  * @brief This is the HAL system configuration section
+#define  VDD_VALUE                    3300U /*!< Value of VDD in mv */
+#define  TICK_INT_PRIORITY            0x0FU /*!< tick interrupt priority */
+#define  USE_RTOS                     0U
+#define  PREFETCH_ENABLE              1U
+#define  INSTRUCTION_CACHE_ENABLE     1U
+#define  DATA_CACHE_ENABLE            1U
+#define  USE_HAL_ADC_REGISTER_CALLBACKS         0U /* ADC register callback disabled       */
+#define  USE_HAL_CAN_REGISTER_CALLBACKS         0U /* CAN register callback disabled       */
+#define  USE_HAL_CEC_REGISTER_CALLBACKS         0U /* CEC register callback disabled       */
+#define  USE_HAL_CRYP_REGISTER_CALLBACKS        0U /* CRYP register callback disabled      */
+#define  USE_HAL_DAC_REGISTER_CALLBACKS         0U /* DAC register callback disabled       */
+#define  USE_HAL_DCMI_REGISTER_CALLBACKS        0U /* DCMI register callback disabled      */
+#define  USE_HAL_DFSDM_REGISTER_CALLBACKS       0U /* DFSDM register callback disabled     */
+#define  USE_HAL_DMA2D_REGISTER_CALLBACKS       0U /* DMA2D register callback disabled     */
+#define  USE_HAL_DSI_REGISTER_CALLBACKS         0U /* DSI register callback disabled       */
+#define  USE_HAL_ETH_REGISTER_CALLBACKS         0U /* ETH register callback disabled       */
+#define  USE_HAL_HASH_REGISTER_CALLBACKS        0U /* HASH register callback disabled      */
+#define  USE_HAL_HCD_REGISTER_CALLBACKS         0U /* HCD register callback disabled       */
+#define  USE_HAL_I2C_REGISTER_CALLBACKS         0U /* I2C register callback disabled       */
+#define  USE_HAL_FMPI2C_REGISTER_CALLBACKS      0U /* FMPI2C register callback disabled    */
+#define  USE_HAL_FMPSMBUS_REGISTER_CALLBACKS    0U /* FMPSMBUS register callback disabled  */
+#define  USE_HAL_I2S_REGISTER_CALLBACKS         0U /* I2S register callback disabled       */
+#define  USE_HAL_IRDA_REGISTER_CALLBACKS        0U /* IRDA register callback disabled      */
+#define  USE_HAL_LPTIM_REGISTER_CALLBACKS       0U /* LPTIM register callback disabled     */
+#define  USE_HAL_LTDC_REGISTER_CALLBACKS        0U /* LTDC register callback disabled      */
+#define  USE_HAL_MMC_REGISTER_CALLBACKS         0U /* MMC register callback disabled       */
+#define  USE_HAL_NAND_REGISTER_CALLBACKS        0U /* NAND register callback disabled      */
+#define  USE_HAL_NOR_REGISTER_CALLBACKS         0U /* NOR register callback disabled       */
+#define  USE_HAL_PCCARD_REGISTER_CALLBACKS      0U /* PCCARD register callback disabled    */
+#define  USE_HAL_PCD_REGISTER_CALLBACKS         0U /* PCD register callback disabled       */
+#define  USE_HAL_QSPI_REGISTER_CALLBACKS        0U /* QSPI register callback disabled      */
+#define  USE_HAL_RNG_REGISTER_CALLBACKS         0U /* RNG register callback disabled       */
+#define  USE_HAL_RTC_REGISTER_CALLBACKS         0U /* RTC register callback disabled       */
+#define  USE_HAL_SAI_REGISTER_CALLBACKS         0U /* SAI register callback disabled       */
+#define  USE_HAL_SD_REGISTER_CALLBACKS          0U /* SD register callback disabled        */
+#define  USE_HAL_SMARTCARD_REGISTER_CALLBACKS   0U /* SMARTCARD register callback disabled */
+#define  USE_HAL_SDRAM_REGISTER_CALLBACKS       0U /* SDRAM register callback disabled     */
+#define  USE_HAL_SRAM_REGISTER_CALLBACKS        0U /* SRAM register callback disabled      */
+#define  USE_HAL_SPDIFRX_REGISTER_CALLBACKS     0U /* SPDIFRX register callback disabled   */
+#define  USE_HAL_SMBUS_REGISTER_CALLBACKS       0U /* SMBUS register callback disabled     */
+#define  USE_HAL_SPI_REGISTER_CALLBACKS         0U /* SPI register callback disabled       */
+#define  USE_HAL_TIM_REGISTER_CALLBACKS         0U /* TIM register callback disabled       */
+#define  USE_HAL_UART_REGISTER_CALLBACKS        0U /* UART register callback disabled      */
+#define  USE_HAL_USART_REGISTER_CALLBACKS       0U /* USART register callback disabled     */
+#define  USE_HAL_WWDG_REGISTER_CALLBACKS        0U /* WWDG register callback disabled      */
+/* ########################## Assert Selection ############################## */
+  * @brief Uncomment the line below to expanse the "assert_param" macro in the
+  *        HAL drivers code
+/* #define USE_FULL_ASSERT    1U */
+/* ################## Ethernet peripheral configuration ##################### */
+/* Section 1 : Ethernet peripheral configuration */
+/* MAC ADDRESS: MAC_ADDR0:MAC_ADDR1:MAC_ADDR2:MAC_ADDR3:MAC_ADDR4:MAC_ADDR5 */
+#define MAC_ADDR0   2U
+#define MAC_ADDR1   0U
+#define MAC_ADDR2   0U
+#define MAC_ADDR3   0U
+#define MAC_ADDR4   0U
+#define MAC_ADDR5   0U
+/* Definition of the Ethernet driver buffers size and count */
+#define ETH_RX_BUF_SIZE                ETH_MAX_PACKET_SIZE /* buffer size for receive               */
+#define ETH_TX_BUF_SIZE                ETH_MAX_PACKET_SIZE /* buffer size for transmit              */
+#define ETH_RXBUFNB                    4U                  /* 4 Rx buffers of size ETH_RX_BUF_SIZE  */
+#define ETH_TXBUFNB                    4U                  /* 4 Tx buffers of size ETH_TX_BUF_SIZE  */
+/* Section 2: PHY configuration section */
+/* DP83848 PHY Address*/
+#define DP83848_PHY_ADDRESS             0x01U
+/* PHY Reset delay these values are based on a 1 ms Systick interrupt*/
+#define PHY_RESET_DELAY                 0x000000FFU
+/* PHY Configuration delay */
+#define PHY_CONFIG_DELAY                0x00000FFFU
+#define PHY_READ_TO                     0x0000FFFFU
+#define PHY_WRITE_TO                    0x0000FFFFU
+/* Section 3: Common PHY Registers */
+#define PHY_BCR                         ((uint16_t)0x0000)  /*!< Transceiver Basic Control Register   */
+#define PHY_BSR                         ((uint16_t)0x0001)  /*!< Transceiver Basic Status Register    */
+#define PHY_RESET                       ((uint16_t)0x8000)  /*!< PHY Reset */
+#define PHY_LOOPBACK                    ((uint16_t)0x4000)  /*!< Select loop-back mode */
+#define PHY_FULLDUPLEX_100M             ((uint16_t)0x2100)  /*!< Set the full-duplex mode at 100 Mb/s */
+#define PHY_HALFDUPLEX_100M             ((uint16_t)0x2000)  /*!< Set the half-duplex mode at 100 Mb/s */
+#define PHY_FULLDUPLEX_10M              ((uint16_t)0x0100)  /*!< Set the full-duplex mode at 10 Mb/s  */
+#define PHY_HALFDUPLEX_10M              ((uint16_t)0x0000)  /*!< Set the half-duplex mode at 10 Mb/s  */
+#define PHY_AUTONEGOTIATION             ((uint16_t)0x1000)  /*!< Enable auto-negotiation function     */
+#define PHY_RESTART_AUTONEGOTIATION     ((uint16_t)0x0200)  /*!< Restart auto-negotiation function    */
+#define PHY_POWERDOWN                   ((uint16_t)0x0800)  /*!< Select the power down mode           */
+#define PHY_ISOLATE                     ((uint16_t)0x0400)  /*!< Isolate PHY from MII                 */
+#define PHY_AUTONEGO_COMPLETE           ((uint16_t)0x0020)  /*!< Auto-Negotiation process completed   */
+#define PHY_LINKED_STATUS               ((uint16_t)0x0004)  /*!< Valid link established               */
+#define PHY_JABBER_DETECTION            ((uint16_t)0x0002)  /*!< Jabber condition detected            */
+/* Section 4: Extended PHY Registers */
+#define PHY_SR                          ((uint16_t)0x0010)  /*!< PHY status register Offset                      */
+#define PHY_MICR                        ((uint16_t)0x0011)  /*!< MII Interrupt Control Register                  */
+#define PHY_MISR                        ((uint16_t)0x0012)  /*!< MII Interrupt Status and Misc. Control Register */
+#define PHY_LINK_STATUS                 ((uint16_t)0x0001)  /*!< PHY Link mask                                   */
+#define PHY_SPEED_STATUS                ((uint16_t)0x0002)  /*!< PHY Speed mask                                  */
+#define PHY_DUPLEX_STATUS               ((uint16_t)0x0004)  /*!< PHY Duplex mask                                 */
+#define PHY_MICR_INT_EN                 ((uint16_t)0x0002)  /*!< PHY Enable interrupts                           */
+#define PHY_MICR_INT_OE                 ((uint16_t)0x0001)  /*!< PHY Enable output interrupt events              */
+#define PHY_MISR_LINK_INT_EN            ((uint16_t)0x0020)  /*!< Enable Interrupt on change of link status       */
+#define PHY_LINK_INTERRUPT              ((uint16_t)0x2000)  /*!< PHY link status interrupt mask                  */
+/* ################## SPI peripheral configuration ########################## */
+/* CRC FEATURE: Use to activate CRC feature inside HAL SPI Driver
+* Activated: CRC code is present inside driver
+* Deactivated: CRC code cleaned from driver
+#define USE_SPI_CRC                     1U
+/* Includes ------------------------------------------------------------------*/
+  * @brief Include module's header file
+#ifdef HAL_RCC_MODULE_ENABLED
+  #include "stm32f4xx_hal_rcc.h"
+#endif /* HAL_RCC_MODULE_ENABLED */
+#ifdef HAL_GPIO_MODULE_ENABLED
+  #include "stm32f4xx_hal_gpio.h"
+#endif /* HAL_GPIO_MODULE_ENABLED */
+#ifdef HAL_EXTI_MODULE_ENABLED
+  #include "stm32f4xx_hal_exti.h"
+#endif /* HAL_EXTI_MODULE_ENABLED */
+#ifdef HAL_DMA_MODULE_ENABLED
+  #include "stm32f4xx_hal_dma.h"
+#endif /* HAL_DMA_MODULE_ENABLED */
+#ifdef HAL_CORTEX_MODULE_ENABLED
+  #include "stm32f4xx_hal_cortex.h"
+#endif /* HAL_CORTEX_MODULE_ENABLED */
+#ifdef HAL_ADC_MODULE_ENABLED
+  #include "stm32f4xx_hal_adc.h"
+#endif /* HAL_ADC_MODULE_ENABLED */
+#ifdef HAL_CAN_MODULE_ENABLED
+  #include "stm32f4xx_hal_can.h"
+#endif /* HAL_CAN_MODULE_ENABLED */
+#ifdef HAL_CAN_LEGACY_MODULE_ENABLED
+  #include "stm32f4xx_hal_can_legacy.h"
+#endif /* HAL_CAN_LEGACY_MODULE_ENABLED */
+#ifdef HAL_CRC_MODULE_ENABLED
+  #include "stm32f4xx_hal_crc.h"
+#endif /* HAL_CRC_MODULE_ENABLED */
+#ifdef HAL_CRYP_MODULE_ENABLED
+  #include "stm32f4xx_hal_cryp.h"
+#endif /* HAL_CRYP_MODULE_ENABLED */
+#ifdef HAL_DMA2D_MODULE_ENABLED
+  #include "stm32f4xx_hal_dma2d.h"
+#endif /* HAL_DMA2D_MODULE_ENABLED */
+#ifdef HAL_DAC_MODULE_ENABLED
+  #include "stm32f4xx_hal_dac.h"
+#endif /* HAL_DAC_MODULE_ENABLED */
+#ifdef HAL_DCMI_MODULE_ENABLED
+  #include "stm32f4xx_hal_dcmi.h"
+#endif /* HAL_DCMI_MODULE_ENABLED */
+#ifdef HAL_ETH_MODULE_ENABLED
+  #include "stm32f4xx_hal_eth.h"
+#endif /* HAL_ETH_MODULE_ENABLED */
+#ifdef HAL_FLASH_MODULE_ENABLED
+  #include "stm32f4xx_hal_flash.h"
+#endif /* HAL_FLASH_MODULE_ENABLED */
+#ifdef HAL_SRAM_MODULE_ENABLED
+  #include "stm32f4xx_hal_sram.h"
+#endif /* HAL_SRAM_MODULE_ENABLED */
+#ifdef HAL_NOR_MODULE_ENABLED
+  #include "stm32f4xx_hal_nor.h"
+#endif /* HAL_NOR_MODULE_ENABLED */
+#ifdef HAL_NAND_MODULE_ENABLED
+  #include "stm32f4xx_hal_nand.h"
+#endif /* HAL_NAND_MODULE_ENABLED */
+#ifdef HAL_PCCARD_MODULE_ENABLED
+  #include "stm32f4xx_hal_pccard.h"
+#endif /* HAL_PCCARD_MODULE_ENABLED */
+#ifdef HAL_SDRAM_MODULE_ENABLED
+  #include "stm32f4xx_hal_sdram.h"
+#endif /* HAL_SDRAM_MODULE_ENABLED */
+#ifdef HAL_HASH_MODULE_ENABLED
+ #include "stm32f4xx_hal_hash.h"
+#endif /* HAL_HASH_MODULE_ENABLED */
+#ifdef HAL_I2C_MODULE_ENABLED
+ #include "stm32f4xx_hal_i2c.h"
+#endif /* HAL_I2C_MODULE_ENABLED */
+#ifdef HAL_SMBUS_MODULE_ENABLED
+ #include "stm32f4xx_hal_smbus.h"
+#endif /* HAL_SMBUS_MODULE_ENABLED */
+#ifdef HAL_I2S_MODULE_ENABLED
+ #include "stm32f4xx_hal_i2s.h"
+#endif /* HAL_I2S_MODULE_ENABLED */
+#ifdef HAL_IWDG_MODULE_ENABLED
+ #include "stm32f4xx_hal_iwdg.h"
+#endif /* HAL_IWDG_MODULE_ENABLED */
+#ifdef HAL_LTDC_MODULE_ENABLED
+ #include "stm32f4xx_hal_ltdc.h"
+#endif /* HAL_LTDC_MODULE_ENABLED */
+#ifdef HAL_PWR_MODULE_ENABLED
+ #include "stm32f4xx_hal_pwr.h"
+#endif /* HAL_PWR_MODULE_ENABLED */
+#ifdef HAL_RNG_MODULE_ENABLED
+ #include "stm32f4xx_hal_rng.h"
+#endif /* HAL_RNG_MODULE_ENABLED */
+#ifdef HAL_RTC_MODULE_ENABLED
+ #include "stm32f4xx_hal_rtc.h"
+#endif /* HAL_RTC_MODULE_ENABLED */
+#ifdef HAL_SAI_MODULE_ENABLED
+ #include "stm32f4xx_hal_sai.h"
+#endif /* HAL_SAI_MODULE_ENABLED */
+#ifdef HAL_SD_MODULE_ENABLED
+ #include "stm32f4xx_hal_sd.h"
+#endif /* HAL_SD_MODULE_ENABLED */
+#ifdef HAL_SPI_MODULE_ENABLED
+ #include "stm32f4xx_hal_spi.h"
+#endif /* HAL_SPI_MODULE_ENABLED */
+#ifdef HAL_TIM_MODULE_ENABLED
+ #include "stm32f4xx_hal_tim.h"
+#endif /* HAL_TIM_MODULE_ENABLED */
+#ifdef HAL_UART_MODULE_ENABLED
+ #include "stm32f4xx_hal_uart.h"
+#endif /* HAL_UART_MODULE_ENABLED */
+#ifdef HAL_USART_MODULE_ENABLED
+ #include "stm32f4xx_hal_usart.h"
+#endif /* HAL_USART_MODULE_ENABLED */
+#ifdef HAL_IRDA_MODULE_ENABLED
+ #include "stm32f4xx_hal_irda.h"
+#endif /* HAL_IRDA_MODULE_ENABLED */
+#ifdef HAL_SMARTCARD_MODULE_ENABLED
+ #include "stm32f4xx_hal_smartcard.h"
+#endif /* HAL_SMARTCARD_MODULE_ENABLED */
+#ifdef HAL_WWDG_MODULE_ENABLED
+ #include "stm32f4xx_hal_wwdg.h"
+#endif /* HAL_WWDG_MODULE_ENABLED */
+#ifdef HAL_PCD_MODULE_ENABLED
+ #include "stm32f4xx_hal_pcd.h"
+#endif /* HAL_PCD_MODULE_ENABLED */
+#ifdef HAL_HCD_MODULE_ENABLED
+ #include "stm32f4xx_hal_hcd.h"
+#endif /* HAL_HCD_MODULE_ENABLED */
+#ifdef HAL_DSI_MODULE_ENABLED
+ #include "stm32f4xx_hal_dsi.h"
+#endif /* HAL_DSI_MODULE_ENABLED */
+#ifdef HAL_QSPI_MODULE_ENABLED
+ #include "stm32f4xx_hal_qspi.h"
+#endif /* HAL_QSPI_MODULE_ENABLED */
+#ifdef HAL_CEC_MODULE_ENABLED
+ #include "stm32f4xx_hal_cec.h"
+#endif /* HAL_CEC_MODULE_ENABLED */
+#ifdef HAL_FMPI2C_MODULE_ENABLED
+ #include "stm32f4xx_hal_fmpi2c.h"
+#endif /* HAL_FMPI2C_MODULE_ENABLED */
+#ifdef HAL_FMPSMBUS_MODULE_ENABLED
+ #include "stm32f4xx_hal_fmpsmbus.h"
+#endif /* HAL_FMPSMBUS_MODULE_ENABLED */
+#ifdef HAL_SPDIFRX_MODULE_ENABLED
+ #include "stm32f4xx_hal_spdifrx.h"
+#endif /* HAL_SPDIFRX_MODULE_ENABLED */
+#ifdef HAL_DFSDM_MODULE_ENABLED
+ #include "stm32f4xx_hal_dfsdm.h"
+#endif /* HAL_DFSDM_MODULE_ENABLED */
+#ifdef HAL_LPTIM_MODULE_ENABLED
+ #include "stm32f4xx_hal_lptim.h"
+#endif /* HAL_LPTIM_MODULE_ENABLED */
+#ifdef HAL_MMC_MODULE_ENABLED
+ #include "stm32f4xx_hal_mmc.h"
+#endif /* HAL_MMC_MODULE_ENABLED */
+/* Exported macro ------------------------------------------------------------*/
+#ifdef  USE_FULL_ASSERT
+  * @brief  The assert_param macro is used for function's parameters check.
+  * @param  expr If expr is false, it calls assert_failed function
+  *         which reports the name of the source file and the source
+  *         line number of the call that failed.
+  *         If expr is true, it returns no value.
+  * @retval None
+  #define assert_param(expr) ((expr) ? (void)0U : assert_failed((uint8_t *)__FILE__, __LINE__))
+/* Exported functions ------------------------------------------------------- */
+  void assert_failed(uint8_t* file, uint32_t line);
+#else
+  #define assert_param(expr) ((void)0U)
+#endif /* USE_FULL_ASSERT */
+#ifdef __cplusplus
+#endif
+#endif /* __STM32F4xx_HAL_CONF_H */
diff --git a/spec/build/bsps/arm/stm32f4/grp.yml b/spec/build/bsps/arm/stm32f4/grp.yml
index f523f6dfee..99a78e1890 100644
--- a/spec/build/bsps/arm/stm32f4/grp.yml
+++ b/spec/build/bsps/arm/stm32f4/grp.yml
@@ -18,6 +18,14 @@ links:
   uid: abi
 - role: build-dependency
   uid: obj
+- role: build-dependency
+  uid: optenhal
+  uid: optvariant
+  uid: opthse
+  uid: optusehse
   uid: opteni2c1
@@ -50,10 +58,10 @@ links:
   uid: optsysclk
   uid: optusartbaud
-- role: build-dependency
-  uid: ../../linkcmds
   uid: ../../obj
+  uid: ../../linkcmds
   uid: ../../objirq
diff --git a/spec/build/bsps/arm/stm32f4/obj.yml b/spec/build/bsps/arm/stm32f4/obj.yml
index e5c2b77f8a..257ac48079 100644
--- a/spec/build/bsps/arm/stm32f4/obj.yml
+++ b/spec/build/bsps/arm/stm32f4/obj.yml
@@ -12,6 +12,134 @@ install:
   source:
   - bsps/arm/stm32f4/include/bsp.h
   - bsps/arm/stm32f4/include/tm27.h
+  - bsps/arm/stm32f4/include/stm32f401xc.h
+  - bsps/arm/stm32f4/include/stm32f401xe.h
+  - bsps/arm/stm32f4/include/stm32f405xx.h
+  - bsps/arm/stm32f4/include/stm32f407xx.h
+  - bsps/arm/stm32f4/include/stm32f410cx.h
+  - bsps/arm/stm32f4/include/stm32f410rx.h
+  - bsps/arm/stm32f4/include/stm32f410tx.h
+  - bsps/arm/stm32f4/include/stm32f411xe.h
+  - bsps/arm/stm32f4/include/stm32f412cx.h
+  - bsps/arm/stm32f4/include/stm32f412rx.h
+  - bsps/arm/stm32f4/include/stm32f412vx.h
+  - bsps/arm/stm32f4/include/stm32f412zx.h
+  - bsps/arm/stm32f4/include/stm32f413xx.h
+  - bsps/arm/stm32f4/include/stm32f415xx.h
+  - bsps/arm/stm32f4/include/stm32f417xx.h
+  - bsps/arm/stm32f4/include/stm32f423xx.h
+  - bsps/arm/stm32f4/include/stm32f427xx.h
+  - bsps/arm/stm32f4/include/stm32f429xx.h
+  - bsps/arm/stm32f4/include/stm32f437xx.h
+  - bsps/arm/stm32f4/include/stm32f439xx.h
+  - bsps/arm/stm32f4/include/stm32f446xx.h
+  - bsps/arm/stm32f4/include/stm32f469xx.h
+  - bsps/arm/stm32f4/include/stm32f479xx.h
+  - bsps/arm/stm32f4/include/stm32f4xx.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_adc_ex.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_adc.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_can.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_cec.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_conf.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_cortex.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_crc.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_cryp_ex.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_cryp.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_dac_ex.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_dac.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_dcmi_ex.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_dcmi.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_def.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_dfsdm.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_dma2d.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_dma_ex.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_dma.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_dsi.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_eth.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_exti.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_flash_ex.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_flash.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_flash_ramfunc.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_fmpi2c_ex.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_fmpi2c.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_fmpsmbus_ex.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_fmpsmbus.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_gpio_ex.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_gpio.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_hash_ex.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_hash.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_hcd.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_i2c_ex.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_i2c.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_i2s_ex.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_i2s.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_irda.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_iwdg.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_lptim.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_ltdc_ex.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_ltdc.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_mmc.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_nand.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_nor.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_pccard.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_pcd_ex.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_pcd.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_pwr_ex.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_pwr.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_qspi.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_rcc_ex.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_rcc.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_rng.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_rtc_ex.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_rtc.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_sai_ex.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_sai.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_sd.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_sdram.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_smartcard.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_smbus.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_spdifrx.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_spi.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_sram.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_tim_ex.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_tim.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_uart.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_usart.h
+  - bsps/arm/stm32f4/include/stm32f4xx_hal_wwdg.h
+  - bsps/arm/stm32f4/include/stm32f4xx_ll_adc.h
+  - bsps/arm/stm32f4/include/stm32f4xx_ll_bus.h
+  - bsps/arm/stm32f4/include/stm32f4xx_ll_cortex.h
+  - bsps/arm/stm32f4/include/stm32f4xx_ll_crc.h
+  - bsps/arm/stm32f4/include/stm32f4xx_ll_dac.h
+  - bsps/arm/stm32f4/include/stm32f4xx_ll_dma2d.h
+  - bsps/arm/stm32f4/include/stm32f4xx_ll_dma.h
+  - bsps/arm/stm32f4/include/stm32f4xx_ll_exti.h
+  - bsps/arm/stm32f4/include/stm32f4xx_ll_fmc.h
+  - bsps/arm/stm32f4/include/stm32f4xx_ll_fmpi2c.h
+  - bsps/arm/stm32f4/include/stm32f4xx_ll_fsmc.h
+  - bsps/arm/stm32f4/include/stm32f4xx_ll_gpio.h
+  - bsps/arm/stm32f4/include/stm32f4xx_ll_i2c.h
+  - bsps/arm/stm32f4/include/stm32f4xx_ll_iwdg.h
+  - bsps/arm/stm32f4/include/stm32f4xx_ll_lptim.h
+  - bsps/arm/stm32f4/include/stm32f4xx_ll_pwr.h
+  - bsps/arm/stm32f4/include/stm32f4xx_ll_rcc.h
+  - bsps/arm/stm32f4/include/stm32f4xx_ll_rng.h
+  - bsps/arm/stm32f4/include/stm32f4xx_ll_rtc.h
+  - bsps/arm/stm32f4/include/stm32f4xx_ll_sdmmc.h
+  - bsps/arm/stm32f4/include/stm32f4xx_ll_spi.h
+  - bsps/arm/stm32f4/include/stm32f4xx_ll_system.h
+  - bsps/arm/stm32f4/include/stm32f4xx_ll_tim.h
+  - bsps/arm/stm32f4/include/stm32f4xx_ll_usart.h
+  - bsps/arm/stm32f4/include/stm32f4xx_ll_usb.h
+  - bsps/arm/stm32f4/include/stm32f4xx_ll_utils.h
+  - bsps/arm/stm32f4/include/stm32f4xx_ll_wwdg.h
+  - bsps/arm/stm32f4/include/system_stm32f4xx.h
+- destination: ${BSP_INCLUDEDIR}/Legacy
+  source:
+  - bsps/arm/stm32f4/include/Legacy/stm32_hal_legacy.h
+  - bsps/arm/stm32f4/include/Legacy/stm32f4xx_hal_eth_legacy.h
+  - bsps/arm/stm32f4/include/Legacy/stm32f4xx_hal_can_legacy.h
 - destination: ${BSP_INCLUDEDIR}/bsp
   source:
   - bsps/arm/stm32f4/include/bsp/i2c.h
@@ -24,7 +152,6 @@ install:
   - bsps/arm/stm32f4/include/bsp/stm32f10xxx_gpio.h
   - bsps/arm/stm32f4/include/bsp/stm32f10xxx_rcc.h
   - bsps/arm/stm32f4/include/bsp/stm32f4.h
-  - bsps/arm/stm32f4/include/bsp/stm32f4xxxx_adc.h
   - bsps/arm/stm32f4/include/bsp/stm32f4xxxx_exti.h
   - bsps/arm/stm32f4/include/bsp/stm32f4xxxx_flash.h
   - bsps/arm/stm32f4/include/bsp/stm32f4xxxx_gpio.h
@@ -41,6 +168,97 @@ install:
 links: []
 source:
 - bsps/arm/shared/clock/clock-armv7m.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_adc.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_adc_ex.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_can.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_cec.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_cortex.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_crc.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_cryp.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_cryp_ex.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_dac.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_dac_ex.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_dcmi.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_dcmi_ex.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_dfsdm.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_dma2d.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_dma.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_dma_ex.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_dsi.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_eth.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_exti.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_flash.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_flash_ex.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_flash_ramfunc.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_fmpi2c.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_fmpi2c_ex.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_fmpsmbus.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_fmpsmbus_ex.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_gpio.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_hash.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_hash_ex.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_hcd.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_i2c.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_i2c_ex.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_i2s.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_i2s_ex.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_irda.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_iwdg.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_lptim.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_ltdc.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_ltdc_ex.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_mmc.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_nand.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_nor.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_pccard.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_pcd.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_pcd_ex.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_pwr.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_pwr_ex.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_qspi.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_rcc.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_rcc_ex.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_rng.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_rtc.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_rtc_ex.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_sai.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_sai_ex.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_sd.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_sdram.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_smartcard.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_smbus.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_spdifrx.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_spi.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_sram.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_tim.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_tim_ex.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_uart.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_usart.c
+- bsps/arm/stm32f4/hal/stm32f4xx_hal_wwdg.c
+- bsps/arm/stm32f4/hal/stm32f4xx_ll_adc.c
+- bsps/arm/stm32f4/hal/stm32f4xx_ll_crc.c
+- bsps/arm/stm32f4/hal/stm32f4xx_ll_dac.c
+- bsps/arm/stm32f4/hal/stm32f4xx_ll_dma2d.c
+- bsps/arm/stm32f4/hal/stm32f4xx_ll_dma.c
+- bsps/arm/stm32f4/hal/stm32f4xx_ll_exti.c
+- bsps/arm/stm32f4/hal/stm32f4xx_ll_fmc.c
+- bsps/arm/stm32f4/hal/stm32f4xx_ll_fmpi2c.c
+- bsps/arm/stm32f4/hal/stm32f4xx_ll_fsmc.c
+- bsps/arm/stm32f4/hal/stm32f4xx_ll_gpio.c
+- bsps/arm/stm32f4/hal/stm32f4xx_ll_i2c.c
+- bsps/arm/stm32f4/hal/stm32f4xx_ll_lptim.c
+- bsps/arm/stm32f4/hal/stm32f4xx_ll_pwr.c
+- bsps/arm/stm32f4/hal/stm32f4xx_ll_rcc.c
+- bsps/arm/stm32f4/hal/stm32f4xx_ll_rng.c
+- bsps/arm/stm32f4/hal/stm32f4xx_ll_rtc.c
+- bsps/arm/stm32f4/hal/stm32f4xx_ll_sdmmc.c
+- bsps/arm/stm32f4/hal/stm32f4xx_ll_spi.c
+- bsps/arm/stm32f4/hal/stm32f4xx_ll_tim.c
+- bsps/arm/stm32f4/hal/stm32f4xx_ll_usart.c
+- bsps/arm/stm32f4/hal/stm32f4xx_ll_usb.c
+- bsps/arm/stm32f4/hal/stm32f4xx_ll_utils.c
+- bsps/arm/stm32f4/hal/system_stm32f4xx.c
 - bsps/arm/shared/irq/irq-armv7m.c
 - bsps/arm/shared/irq/irq-dispatch-armv7m.c
 - bsps/arm/shared/start/bsp-start-memcpy.S
diff --git a/spec/build/bsps/arm/stm32f4/optenhal.yml b/spec/build/bsps/arm/stm32f4/optenhal.yml
index 0000000000..3c1599a3d6
--- /dev/null
+++ b/spec/build/bsps/arm/stm32f4/optenhal.yml
@@ -0,0 +1,16 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+actions:
+- get-boolean: null
+- define-condition: null
+build-type: option
+copyrights:
+- Copyright (C) 2022 Duc Doan (dtbpkmte at gmail.com)
+default: true
+default-by-variant: []
+description: |
+  Use HAL driver
+enabled-by: true
+format: '{}'
+links: []
+name: USE_HAL_DRIVER
+type: build
diff --git a/spec/build/bsps/arm/stm32f4/opthse.yml b/spec/build/bsps/arm/stm32f4/opthse.yml
index 0000000000..d63f9e81a0
--- /dev/null
+++ b/spec/build/bsps/arm/stm32f4/opthse.yml
@@ -0,0 +1,17 @@
+actions:
+- get-integer: null
+- assert-uint32: null
+- format-and-define: null
+build-type: option
+copyrights:
+default: 8000000
+description: |
+  HSE frequency in Hz
+enabled-by: true
+format: '{}'
+links: []
+name: STM32F4_HSE_FREQUENCY
+type: build
diff --git a/spec/build/bsps/arm/stm32f4/optusehse.yml b/spec/build/bsps/arm/stm32f4/optusehse.yml
index 0000000000..192232f294
--- /dev/null
+++ b/spec/build/bsps/arm/stm32f4/optusehse.yml
@@ -0,0 +1,16 @@
+actions:
+- define: null
+build-type: option
+copyrights:
+default: 0
+description: |
+  Use HSI for PLL by default, set it to 1 to use HSE for PLL.
+enabled-by: true
+format: '{}'
+links: []
+name: STM32F4_USE_HSE
+type: build
diff --git a/spec/build/bsps/arm/stm32f4/optvariant.yml b/spec/build/bsps/arm/stm32f4/optvariant.yml
index 0000000000..f2583c5b95
--- /dev/null
+++ b/spec/build/bsps/arm/stm32f4/optvariant.yml
@@ -0,0 +1,24 @@
+copyrights:
+actions:
+- get-string: null
+- script: |
+    variants = ["STM32F405xx", "STM32F415xx", "STM32F407xx", "STM32F417xx", "STM32F427xx", "STM32F437xx", "STM32F429xx", "STM32F439xx", "STM32F401xC", "STM32F401xE", "STM32F410Tx", "STM32F410Rx", "STM32F411xE", "STM32F446xx", "STM32F469xx", "STM32F479xx", "STM32F412Cx", "STM32F412Rx", "STM32F412Vx", "STM32F413xx", "STM32F423xx"]
+    if value not in variants:
+        conf.fatal(
+            "STM32F4 chip variant '{}' is not one of {}".format(
+                value, variants
+    conf.define_cond(value, True)
+build-type: option
+default: STM32F407xx
+enabled-by: true
+format: '{}'
+links: []
+name: STM32F4_VARIANT
+description: |
+  Select the STM32F4 series chip variant out of STM32F405xx, STM32F415xx, STM32F407xx, STM32F417xx, STM32F427xx, STM32F437xx, STM32F429xx, STM32F439xx, STM32F401xC, STM32F401xE, STM32F410Tx, STM32F410Rx, STM32F411xE, STM32F446xx, STM32F469xx, STM32F479xx, STM32F412Cx, STM32F412Rx, STM32F412Vx, STM32F413xx, and STM32F423xx.
+type: build
2.37.1
