[PATCH] rtems/malloc.h: Add API level Doxygen group
Joel Sherrill
joel at rtems.org
Wed Aug 10 13:35:13 UTC 2022
This looks good.
On Wed, Aug 10, 2022 at 8:24 AM Sebastian Huber <
> The interfaces in the MallocSupport group belong to the implementation.
> They
> are used by confdefs.h for example.
> cpukit/include/rtems/malloc.h | 60 ++++++++++++++++++++++++-----------
> 1 file changed, 41 insertions(+), 19 deletions(-)
> diff --git a/cpukit/include/rtems/malloc.h b/cpukit/include/rtems/malloc.h
> index 7d7f8fa677..c26b262881 100644
> --- a/cpukit/include/rtems/malloc.h
> +++ b/cpukit/include/rtems/malloc.h
> @@ -3,7 +3,12 @@
> * @file
> - * This file defines the interface to RTEMS extensions to the Malloc
> Family.
> + * @ingroup MallocSupport
> + * @ingroup RTEMSAPIMalloc
> + * @brief This header file defines interfaces to support and use dynamic
> memory
> + * allocation.
> @@ -46,11 +51,13 @@ extern "C" {
> #endif
> - * @defgroup MallocSupport Malloc Support
> + * @defgroup MallocSupport Malloc Support
> + * @ingroup libcsupport
> - * @ingroup libcsupport
> + * @brief This group contains interfaces to support dynamic memory
> allocation.
> - * @brief RTEMS extensions to the Malloc Family
> @@ -63,8 +70,6 @@ extern Heap_Control *RTEMS_Malloc_Heap;
> void _Malloc_Initialize( void );
> -void rtems_heap_set_sbrk_amount( ptrdiff_t sbrk_amount );
> typedef void *(*rtems_heap_extend_handler)(
> Heap_Control *heap,
> size_t alloc_size
> @@ -78,19 +83,6 @@ void *rtems_heap_extend_via_sbrk(
> size_t alloc_size
> - * @brief Greedy allocate that empties the sbrk memory
> - * Afterwards all the sbrk avialable memory will have been allocated
> - * to the provided heap.
> - * @see rtems_heap_extend_via_sbrk().
> -void rtems_heap_sbrk_greedy_allocate(
> - Heap_Control *heap,
> - size_t alloc_size
> void *rtems_heap_null_extend(
> Heap_Control *heap,
> size_t alloc_size
> @@ -104,6 +96,34 @@ extern const rtems_heap_extend_handler
> rtems_malloc_extend_handler;
> typedef void (*rtems_malloc_dirtier_t)(void *, size_t);
> extern rtems_malloc_dirtier_t rtems_malloc_dirty_helper;
> + * @defgroup RTEMSAPIMalloc Dynamic Memory Allocation
> + * @brief This group contains non-standard interfaces to use dynamic
> memory
> + * allocation.
> +void rtems_heap_set_sbrk_amount( ptrdiff_t sbrk_amount );
> + * @brief Greedy allocate that empties the sbrk memory
> + * Afterwards all the sbrk avialable memory will have been allocated
> + * to the provided heap.
> + * @see rtems_heap_extend_via_sbrk().
> +void rtems_heap_sbrk_greedy_allocate(
> + Heap_Control *heap,
> + size_t alloc_size
> * @brief Dirty Memory Function
> @@ -251,6 +271,8 @@ void *rtems_heap_greedy_allocate_all_except_largest(
> void rtems_heap_greedy_free( void *opaque );
> #ifdef __cplusplus
> #endif
> 2.35.3
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220810/748f17ad/attachment.htm>
