rtems-docs fail to build
Fri Aug 12 06:05:44 UTC 2022
On 12/8/2022 6:10 am, Joel Sherrill wrote:
> Subject says it. This is the error and a git bisect which points to Chris
> updating the arm section of the user guide. I don't see the issue looking at the
> patch.
> From f028448e5f21f4317a0a7b9b336d7e492ebea6c7 Mon Sep 17 00:00:00 2001
> From: Chris Johns <chrisj at rtems.org <mailto:chrisj at rtems.org>>
> Date: Wed, 3 Aug 2022 14:20:52 +1000
> Subject: [PATCH rtems-docs] versions: Update arm
> Error output followed by git bisect.
> Build: 6.f028448 (3rd August 2022)
> [4/7] Compiling build/user/latex/user.tex
> first pass on pdflatex
> This is pdfTeX, Version 3.14159265-2.6-1.40.20 (TeX Live 2019) (preloaded
> format=pdflatex)
>  \write18 enabled.
> entering extended mode
The issue is the change I made to the ARM BSP to correctly handle section
numbering and TOC. This changed the depth the source builds from and that has
changed the relative path to the BBB P2 debug connector image. HTML does not
generate an error however PDF does. I will push the fix.
I will also push a change to the pdflatex build that sets the TEXINPUTS env
variable to include some sphinx latex support that was being silently ignored.
