rtems-docs fail to build
Joel Sherrill
joel at rtems.org
Fri Aug 12 15:24:09 UTC 2022
On Fri, Aug 12, 2022 at 1:06 AM Chris Johns <chrisj at rtems.org> wrote:
> On 12/8/2022 6:10 am, Joel Sherrill wrote:
> > Subject says it. This is the error and a git bisect which points to Chris
> > updating the arm section of the user guide. I don't see the issue
> looking at the
> > patch.
> > From f028448e5f21f4317a0a7b9b336d7e492ebea6c7 Mon Sep 17 00:00:00 2001
> > From: Chris Johns <chrisj at rtems.org <mailto:chrisj at rtems.org>>
> > Date: Wed, 3 Aug 2022 14:20:52 +1000
> > Subject: [PATCH rtems-docs] versions: Update arm
> > Error output followed by git bisect.
> > Build: 6.f028448 (3rd August 2022)
> > [4/7] Compiling build/user/latex/user.tex
> > first pass on pdflatex
> > This is pdfTeX, Version 3.14159265-2.6-1.40.20 (TeX Live 2019) (preloaded
> > format=pdflatex)
> > \write18 enabled.
> > entering extended mode
> The issue is the change I made to the ARM BSP to correctly handle section
> numbering and TOC. This changed the depth the source builds from and that
> has
> changed the relative path to the BBB P2 debug connector image. HTML does
> not
> generate an error however PDF does. I will push the fix.
Thank you. I can confirm this works.
I know it takes longer but every time I build docs, I build pdf and html.
It is
odd cases like this that point out why it is good to let it build and come
back
to check on it.
> I will also push a change to the pdflatex build that sets the TEXINPUTS env
> variable to include some sphinx latex support that was being silently
> ignored.
Great! Will this have any visible change on output?
--joel
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220812/6f54568a/attachment.htm>
