[PATCH v4 1/2] bsp/riscv: Work area size based on stack pointer
Hesham Almatary
Hesham.Almatary at cl.cam.ac.uk
Mon Aug 15 13:43:29 UTC 2022
On Mon, 15 Aug 2022 at 08:16, Daniel Cederman <cederman at gaisler.com> wrote:
> From: Martin Aberg <maberg at gaisler.com>
> Remember the initial stack pointer in start.S. It can later be used to
> determine top of RAM.
> bsps/riscv/include/bsp/start.h | 67 ++++++++++++++++
> .../shared/start/bspgetworkarea-fromstack.c | 76 +++++++++++++++++++
> bsps/riscv/shared/start/start.S | 15 ++++
> cpukit/score/cpu/riscv/include/rtems/asm.h | 12 +++
> 4 files changed, 170 insertions(+)
> create mode 100644 bsps/riscv/include/bsp/start.h
> create mode 100644 bsps/riscv/shared/start/bspgetworkarea-fromstack.c
> diff --git a/bsps/riscv/include/bsp/start.h b/bsps/riscv/include/bsp/start.h
> new file mode 100644
> index 0000000000..f40f1873a7
> --- /dev/null
> +++ b/bsps/riscv/include/bsp/start.h
> @@ -0,0 +1,67 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
> + * @file
> + * @ingroup RTEMSBSPsRISCVSharedStart
> + * @brief RISC-V start definitions.
> + * Copyright (c) 2021 Cobham Gaisler AB.
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + * notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + * notice, this list of conditions and the following disclaimer in the
> + * documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#ifndef LIBBSP_RISCV_SHARED_START_H
> +#define LIBBSP_RISCV_SHARED_START_H
> + * @defgroup RTEMSBSPsRISCVSharedStart Start Support
> + * @brief Start support.
> +#include <stdint.h>
> +#ifdef __cplusplus
> +extern "C" {
> +#endif
> + * This variable is initialized by the first CPU entering the BSP start code.
> + * The value is the stack pointer at entry.
> +extern const uintptr_t riscv_start_stack_pointer;
> +#ifdef __cplusplus
> +#endif
> +#endif /* LIBBSP_RISCV_SHARED_START_H */
> diff --git a/bsps/riscv/shared/start/bspgetworkarea-fromstack.c b/bsps/riscv/shared/start/bspgetworkarea-fromstack.c
> index 0000000000..d55a876346
> --- /dev/null
> +++ b/bsps/riscv/shared/start/bspgetworkarea-fromstack.c
> @@ -0,0 +1,76 @@
> + * @file
> + * @brief BSP specific initialization support routines
> + * COPYRIGHT (c) 1989-2020.
> + * On-Line Applications Research Corporation (OAR).
> + * Cobham Gaisler AB.
> + * are met:
> +#include <bsp.h>
> +#include <bsp/start.h>
> +#include <bsp/bootcard.h>
> +#include <rtems/sysinit.h>
> + * These are provided by the linkcmds for ALL of the BSPs which use this file.
> +extern char WorkAreaBase[];
> +extern char RamEnd[];
> +static Memory_Area _Memory_Areas[ 1 ];
> +static void bsp_memory_initialize( void )
> + char *end;
> + /* top of RAM inidicated by initial stack pointer */
> + end = (char *) riscv_start_stack_pointer;
> + if (end == 0) {
> + /* fall back to linker symbol if not set */
> + end = RamEnd;
> + _Memory_Initialize( &_Memory_Areas[ 0 ], WorkAreaBase, end );
> +RTEMS_SYSINIT_ITEM(
> + bsp_memory_initialize,
> + RTEMS_SYSINIT_MEMORY,
> + RTEMS_SYSINIT_ORDER_MIDDLE
> +static const Memory_Information _Memory_Information =
> + MEMORY_INFORMATION_INITIALIZER( _Memory_Areas );
> +const Memory_Information *_Memory_Get( void )
> + return &_Memory_Information;
> diff --git a/bsps/riscv/shared/start/start.S b/bsps/riscv/shared/start/start.S
> index 3702f8ac2f..d87f41a3dd 100644
> --- a/bsps/riscv/shared/start/start.S
> +++ b/bsps/riscv/shared/start/start.S
> @@ -60,6 +60,9 @@ SYM(_start):
> LADDR t0, _RISCV_Exception_handler
> csrw mtvec, t0
> + /* Save stack pointer so it can mark end of work area later on */
> + mv t3, sp
I might be missing something, but I assume at this point of the code
execution, $sp is undefined and it depends on hardware/firmware that
runs before RTEMS what to reset $sp to. Isn't that the case?
> /* Load stack pointer and branch to secondary processor start if necessary */
> #ifdef RTEMS_SMP
> LADDR sp, _ISR_Stack_area_begin
> @@ -75,6 +78,9 @@ SYM(_start):
> LADDR sp, _ISR_Stack_area_end
> #endif
> + LADDR t0, riscv_start_stack_pointer
> + SREG t3, 0(t0)
> #ifdef BSP_START_COPY_FDT_FROM_U_BOOT
> mv a0, a1
> call bsp_fdt_copy
> @@ -146,3 +152,12 @@ SYM(_start):
> #endif
> #endif /* RTEMS_SMP */
> + .section .bsp_start_data, "aw"
> + .align PTR_ALIGN
> + .globl riscv_start_stack_pointer
> + .type riscv_start_stack_pointer, @object
> + .size riscv_start_stack_pointer, PTR_SIZE
> +riscv_start_stack_pointer:
> + PTR_VALUE 0
> diff --git a/cpukit/score/cpu/riscv/include/rtems/asm.h b/cpukit/score/cpu/riscv/include/rtems/asm.h
> index 4e09d16410..b20e7f49ba 100644
> --- a/cpukit/score/cpu/riscv/include/rtems/asm.h
> +++ b/cpukit/score/cpu/riscv/include/rtems/asm.h
> @@ -133,12 +133,24 @@
> #define SREG sw
> +#define PTR_ALIGN 2
> +#define PTR_SIZE 4
> +#define PTR_VALUE .word
> #elif __riscv_xlen == 64
> #define LREG ld
> #define SREG sd
> +#define PTR_ALIGN 3
> +#define PTR_SIZE 8
> +#define PTR_VALUE .dword
> #endif /* __riscv_xlen */
> #ifdef __riscv_cmodel_medany
> 2.34.1
> devel mailing list
> devel at rtems.org
