[PATCH v4 1/2] bsp/riscv: Work area size based on stack pointer
Daniel Cederman
cederman at gaisler.com
Mon Aug 15 14:34:56 UTC 2022
On 2022-08-15 15:43, Hesham Almatary wrote:
> On Mon, 15 Aug 2022 at 08:16, Daniel Cederman <cederman at gaisler.com> wrote:
>> From: Martin Aberg <maberg at gaisler.com>
>> Remember the initial stack pointer in start.S. It can later be used to
>> determine top of RAM.
>> bsps/riscv/include/bsp/start.h | 67 ++++++++++++++++
>> .../shared/start/bspgetworkarea-fromstack.c | 76 +++++++++++++++++++
>> bsps/riscv/shared/start/start.S | 15 ++++
>> cpukit/score/cpu/riscv/include/rtems/asm.h | 12 +++
>> 4 files changed, 170 insertions(+)
>> create mode 100644 bsps/riscv/include/bsp/start.h
>> create mode 100644 bsps/riscv/shared/start/bspgetworkarea-fromstack.c
>> diff --git a/bsps/riscv/include/bsp/start.h b/bsps/riscv/include/bsp/start.h
>> new file mode 100644
>> index 0000000000..f40f1873a7
>> --- /dev/null
>> +++ b/bsps/riscv/include/bsp/start.h
>> @@ -0,0 +1,67 @@
>> +/* SPDX-License-Identifier: BSD-2-Clause */
>> + * @file
>> + * @ingroup RTEMSBSPsRISCVSharedStart
>> + * @brief RISC-V start definitions.
>> + * Copyright (c) 2021 Cobham Gaisler AB.
>> + * Redistribution and use in source and binary forms, with or without
>> + * modification, are permitted provided that the following conditions
>> + * are met:
>> + * 1. Redistributions of source code must retain the above copyright
>> + * notice, this list of conditions and the following disclaimer.
>> + * 2. Redistributions in binary form must reproduce the above copyright
>> + * notice, this list of conditions and the following disclaimer in the
>> + * documentation and/or other materials provided with the distribution.
>> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
>> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
>> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
>> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
>> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
>> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
>> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
>> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
>> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
>> + * POSSIBILITY OF SUCH DAMAGE.
>> +#ifndef LIBBSP_RISCV_SHARED_START_H
>> +#define LIBBSP_RISCV_SHARED_START_H
>> + * @defgroup RTEMSBSPsRISCVSharedStart Start Support
>> + * @brief Start support.
>> +#include <stdint.h>
>> +#ifdef __cplusplus
>> +extern "C" {
>> +#endif
>> + * This variable is initialized by the first CPU entering the BSP start code.
>> + * The value is the stack pointer at entry.
>> +extern const uintptr_t riscv_start_stack_pointer;
>> +#ifdef __cplusplus
>> +#endif
>> +#endif /* LIBBSP_RISCV_SHARED_START_H */
>> diff --git a/bsps/riscv/shared/start/bspgetworkarea-fromstack.c b/bsps/riscv/shared/start/bspgetworkarea-fromstack.c
>> index 0000000000..d55a876346
>> --- /dev/null
>> +++ b/bsps/riscv/shared/start/bspgetworkarea-fromstack.c
>> @@ -0,0 +1,76 @@
>> + * @file
>> + * @brief BSP specific initialization support routines
>> + * COPYRIGHT (c) 1989-2020.
>> + * On-Line Applications Research Corporation (OAR).
>> + * Cobham Gaisler AB.
>> + * are met:
>> +#include <bsp.h>
>> +#include <bsp/start.h>
>> +#include <bsp/bootcard.h>
>> +#include <rtems/sysinit.h>
>> + * These are provided by the linkcmds for ALL of the BSPs which use this file.
>> +extern char WorkAreaBase[];
>> +extern char RamEnd[];
>> +static Memory_Area _Memory_Areas[ 1 ];
>> +static void bsp_memory_initialize( void )
>> + char *end;
>> + /* top of RAM inidicated by initial stack pointer */
>> + end = (char *) riscv_start_stack_pointer;
>> + if (end == 0) {
>> + /* fall back to linker symbol if not set */
>> + end = RamEnd;
>> + _Memory_Initialize( &_Memory_Areas[ 0 ], WorkAreaBase, end );
>> +RTEMS_SYSINIT_ITEM(
>> + bsp_memory_initialize,
>> + RTEMS_SYSINIT_MEMORY,
>> + RTEMS_SYSINIT_ORDER_MIDDLE
>> +static const Memory_Information _Memory_Information =
>> + MEMORY_INFORMATION_INITIALIZER( _Memory_Areas );
>> +const Memory_Information *_Memory_Get( void )
>> + return &_Memory_Information;
>> diff --git a/bsps/riscv/shared/start/start.S b/bsps/riscv/shared/start/start.S
>> index 3702f8ac2f..d87f41a3dd 100644
>> --- a/bsps/riscv/shared/start/start.S
>> +++ b/bsps/riscv/shared/start/start.S
>> @@ -60,6 +60,9 @@ SYM(_start):
>> LADDR t0, _RISCV_Exception_handler
>> csrw mtvec, t0
>> + /* Save stack pointer so it can mark end of work area later on */
>> + mv t3, sp
> I might be missing something, but I assume at this point of the code
> execution, $sp is undefined and it depends on hardware/firmware that
> runs before RTEMS what to reset $sp to. Isn't that the case?
That is correct. It allows the debugger/simulator/bootloader to provide
the size of the memory to the application without having it hardcoded in
the image. It is the same approach that we use for LEON.
>> /* Load stack pointer and branch to secondary processor start if necessary */
>> #ifdef RTEMS_SMP
>> LADDR sp, _ISR_Stack_area_begin
>> @@ -75,6 +78,9 @@ SYM(_start):
>> LADDR sp, _ISR_Stack_area_end
>> #endif
>> + LADDR t0, riscv_start_stack_pointer
>> + SREG t3, 0(t0)
>> #ifdef BSP_START_COPY_FDT_FROM_U_BOOT
>> mv a0, a1
>> call bsp_fdt_copy
>> @@ -146,3 +152,12 @@ SYM(_start):
>> #endif
>> #endif /* RTEMS_SMP */
>> + .section .bsp_start_data, "aw"
>> + .align PTR_ALIGN
>> + .globl riscv_start_stack_pointer
>> + .type riscv_start_stack_pointer, @object
>> + .size riscv_start_stack_pointer, PTR_SIZE
>> +riscv_start_stack_pointer:
>> + PTR_VALUE 0
>> diff --git a/cpukit/score/cpu/riscv/include/rtems/asm.h b/cpukit/score/cpu/riscv/include/rtems/asm.h
>> index 4e09d16410..b20e7f49ba 100644
>> --- a/cpukit/score/cpu/riscv/include/rtems/asm.h
>> +++ b/cpukit/score/cpu/riscv/include/rtems/asm.h
>> @@ -133,12 +133,24 @@
>> #define SREG sw
>> +#define PTR_ALIGN 2
>> +#define PTR_SIZE 4
>> +#define PTR_VALUE .word
>> #elif __riscv_xlen == 64
>> #define LREG ld
>> #define SREG sd
>> +#define PTR_ALIGN 3
>> +#define PTR_SIZE 8
>> +#define PTR_VALUE .dword
>> #endif /* __riscv_xlen */
>> #ifdef __riscv_cmodel_medany
>> 2.34.1
>> devel mailing list
>> devel at rtems.org
