[PATCH v1 06/12] test.h: Add pragma for gcc 12 warning
Ryan Long
ryan.long at oarcorp.com
Tue Aug 16 20:11:54 UTC 2022
Updates #4662
cpukit/include/rtems/test.h | 7 +++++++
1 file changed, 7 insertions(+)
diff --git a/cpukit/include/rtems/test.h b/cpukit/include/rtems/test.h
index c283be7860..e0823394d1 100644
--- a/cpukit/include/rtems/test.h
+++ b/cpukit/include/rtems/test.h
@@ -218,12 +218,19 @@ void T_check_null(const T_check_context_msg *, const void *);
void T_check_not_null(const T_check_context_msg *, const void *);
+ * This was added to address the following warning.
+ * warning: 'a' may be used uninitialized
+#pragma GCC diagnostic push
+#pragma GCC diagnostic ignored "-Wmaybe-uninitialized"
#define T_flags_not_null(a, flags, sa) \
static const T_check_context_msg T_check_instance = { \
{ T_FILE_NAME, __LINE__, (flags) | T_CHECK_FMT }, sa }; \
T_check_not_null(&T_check_instance, a); \
+#pragma GCC diagnostic pop
void T_check_eq_mem(const T_check_context_msg *, const void *, const void *,
size_t);
2.11.0
