[PATCH v1 07/12] cpu.h: Fix gcc 12 warnings
Ryan Long
ryan.long at oarcorp.com
Tue Aug 16 20:11:55 UTC 2022
Added two pragmas to address, and changed the value of
AARCH64_EXCEPTION_MAKE_ENUM_64_BIT to INT_MAX because the old value was not
in range of an int.
Updates #4662
cpukit/score/cpu/aarch64/include/rtems/score/cpu.h | 20 ++++++++++++++++++--
1 file changed, 18 insertions(+), 2 deletions(-)
diff --git a/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h b/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
index 47a8e97985..282977853f 100644
--- a/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
@@ -43,6 +43,7 @@
#endif
#include <rtems/score/aarch64.h>
#include <libcpu/vectors.h>
+#include <limits.h>
* @addtogroup RTEMSScoreCPUAArch64
@@ -156,7 +157,14 @@
extern "C" {
#endif
+ This is to fix the following warning
+ ISO C does not support 'uint128_t' types
+#pragma GCC diagnostic push
+#pragma GCC diagnostic ignored "-Wpedantic"
typedef unsigned __int128 uint128_t;
+#pragma GCC diagnostic pop
typedef struct {
uint64_t register_x19;
@@ -404,7 +412,7 @@ typedef enum {
AARCH64_EXCEPTION_LEL32_FIQ = 14,
AARCH64_EXCEPTION_LEL32_SERROR = 15,
MAX_EXCEPTIONS = 16,
- AARCH64_EXCEPTION_MAKE_ENUM_64_BIT = 0xffffffffffffffff
+ AARCH64_EXCEPTION_MAKE_ENUM_64_BIT = INT_MAX
} AArch64_symbolic_exception_name;
#define VECTOR_POINTER_OFFSET 0x78
@@ -432,7 +440,15 @@ static inline void* AArch64_set_exception_handler(
*vector_address = handler;
/* return now-previous vector pointer */
- return (void*)current_vector_pointer;
+ * This was put in to fix the following warning:
+ * warning: ISO C forbids conversion of function pointer to object pointer type.
+ return (void*)current_vector_pointer;
typedef struct {
2.11.0
