-Werror on amd64 BSP makes it to installed package configuration file
Fri Aug 19 19:59:47 UTC 2022
> On 20 Aug 2022, at 3:39 am, Joel Sherrill <joel at rtems.org> wrote:
> Hi
> Stephen tripped across this and I'm reporting it because it is going to
> take some discussion to resolve.
> Stephen is using the .pc files to create a configuration file
> for the FACE Conformance Test Suite. This is now basically working
> for multiple BSPs. The amd64 includes -Werror in its BSP compiler
> options and is the only BSP to do so.
Looks like a bug to me. It should not be in the standard CFLAGS returned by pkgconfig.
> (1) Do we want a BSP to include -Werror? amd64 being the only one
> and use having a history of chasing warnings after gcc upgrades.
Yes remove.
> (2) I though warning flags were filtered out on the install. I'm not finding
> the code to do it but shouldn't this be filtered out like the other warning flags?
> Any other thoughts?
> --joel
> devel mailing list
> devel at rtems.org
