[PATCH v2 1/1] bsp/riscv: Work area size based on /memory node in fdt
Joel Sherrill
joel at rtems.org
Sat Aug 20 15:56:48 UTC 2022
On Fri, Aug 19, 2022, 8:28 AM Hesham Almatary <Hesham.Almatary at cl.cam.ac.uk>
wrote:
> On Fri, 19 Aug 2022 at 13:36, Daniel Cederman <cederman at gaisler.com>
> wrote:
>> On 2022-08-19 11:16, Hesham Almatary wrote:
>> > On Thu, 18 Aug 2022 at 13:55, Daniel Cederman <cederman at gaisler.com>
>> wrote:
>> >> I missed your comment, but have made the change now. Are there any
>> instructions on how to run the RISCV BSP tests on QEMU or Spike? I could
>> not get it to work. Do I need a special version of QEMU or Spike?
>> > Thanks! AFAIR, you need to run the "medany" RISC-V variants for QEMU,
>> > I'd use rtems-tester. No special QEMU version is needed.
>> Thanks! I had to change "-m 64M -kernel" to "-m 128M -bios" to get it to
>> run. Got the same result both with and without the patch for
>> rv64imafd_medany:
> Great! Thanks for testing. A patch to fix that in tester will be greatly
> appreciated. I thought I submitted the -bios change before but apparently
> not.
Include it as part of this patch sweep please. And make sure results from
the OAR build machines are in the build@ mailing list archives. If not,
that will need to be looked into.
I'm glad this is coming together.
Make sure the license text formatting matches other files.
>> Passed: 653
>> Failed: 16
>> User Input: 5
>> Expected Fail: 0
>> Indeterminate: 0
>> Benchmark: 3
>> Timeout: 5
>> Test too long: 0
>> Invalid: 0
>> Wrong Version: 0
>> Wrong Build: 0
>> Wrong Tools: 0
>> Wrong Header: 0
>> Total: 682
>> Failures:
>> exit03.exe
>> ttest02.exe
>> psx12.exe
>> smpirqs01.exe
>> sp69.exe
>> spintrcritical24.exe
>> spsysinit01.exe
>> ts-fatal-scheduler-requires-exactly-one-processor.exe
>> ts-fatal-start-of-mandatory-processor-failed.exe
>> ts-validation-1.exe
>> ts-validation-one-cpu-0.exe
>> minimum.exe
>> smpstart01.exe
>> ts-fatal-smp.exe
>> ts-performance-no-clock-0.exe
>> ts-validation-intr.exe
>> User Input:
>> monitor.exe
>> termios.exe
>> top.exe
>> fileio.exe
>> capture.exe
>> Benchmark:
>> dhrystone.exe
>> linpack.exe
>> whetstone.exe
>> Timeouts:
>> ts-fatal-start-on-not-online-processor.exe
>> ts-validation-0.exe
>> ts-validation-no-clock-0.exe
>> ts-validation-smp-only-0.exe
>> ts-validation-timecounter-smp-0.exe
>> >> On 2022-08-18 10:24, Hesham Almatary wrote:
>> >> All good, I'd just replace the "end == 0" with "end == NULL" as per my
>> >> comment above. Also please test on other RISC-V QEMU platforms to make
>> >> sure nothing got broken.
>> >> On Wed, 17 Aug 2022 at 14:10, Joel Sherrill <joel at rtems.org> wrote:
>> >> I'm ok with this if Hesham acks as well.
>> >> --joel
>> >> On Wed, Aug 17, 2022 at 6:35 AM Daniel Cederman <cederman at gaisler.com>
>> wrote:
>> >> Uses the first entry in the /memory node to determine the end of the
>> >> work area. Falls back on linker symbol if unable to parse the node.
>> >> bsps/riscv/shared/start/bspgetworkarea.c | 144
>> >> spec/build/bsps/riscv/riscv/obj.yml | 1 +
>> >> 2 files changed, 145 insertions(+)
>> >> create mode 100644 bsps/riscv/shared/start/bspgetworkarea.c
>> >> diff --git a/bsps/riscv/shared/start/bspgetworkarea.c
>> b/bsps/riscv/shared/start/bspgetworkarea.c
>> >> new file mode 100644
>> >> index 0000000000..1fa051d25e
>> >> --- /dev/null
>> >> +++ b/bsps/riscv/shared/start/bspgetworkarea.c
>> >> @@ -0,0 +1,144 @@
>> >> +/* SPDX-License-Identifier: BSD-2-Clause */
>> >> + * @file
>> >> + * @brief BSP specific initialization support routines
>> >> + * COPYRIGHT (c) 1989-2020.
>> >> + * On-Line Applications Research Corporation (OAR).
>> >> + * Cobham Gaisler AB.
>> >> + * Redistribution and use in source and binary forms, with or without
>> >> + * modification, are permitted provided that the following conditions
>> >> + * are met:
>> >> + * 1. Redistributions of source code must retain the above copyright
>> >> + * notice, this list of conditions and the following disclaimer.
>> >> + * 2. Redistributions in binary form must reproduce the above
>> copyright
>> >> + * notice, this list of conditions and the following disclaimer in
>> the
>> >> + * documentation and/or other materials provided with the
>> distribution.
>> >> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
>> CONTRIBUTORS "AS IS"
>> >> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
>> TO, THE
>> >> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
>> PURPOSE
>> >> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
>> CONTRIBUTORS BE
>> >> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>> >> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT
>> OF
>> >> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
>> BUSINESS
>> >> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
>> WHETHER IN
>> >> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
>> OTHERWISE)
>> >> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
>> ADVISED OF THE
>> >> + * POSSIBILITY OF SUCH DAMAGE.
>> >> +#include <bsp.h>
>> >> +#include <bsp/fdt.h>
>> >> +#include <rtems/sysinit.h>
>> >> +#include <libfdt.h>
>> >> + * These are provided by the linkcmds for ALL of the BSPs which use
>> this file.
>> >> +extern char WorkAreaBase[];
>> >> +extern char RamEnd[];
>> >> +static Memory_Area _Memory_Areas[ 1 ];
>> >> +static const char memory_path[] = "/memory";
>> >> +static void* get_end_of_memory_from_fdt(void)
>> >> + const void *fdt;
>> >> + const void *val;
>> >> + int node;
>> >> + int parent;
>> >> + int ac;
>> >> + int sc;
>> >> + int len;
>> >> + uintptr_t start;
>> >> + uintptr_t size;
>> >> + fdt = bsp_fdt_get();
>> >> + node = fdt_path_offset_namelen(
>> >> + fdt,
>> >> + memory_path,
>> >> + (int) sizeof(memory_path) - 1
>> >> + if (node < 0) {
>> >> + return NULL;
>> >> + parent = fdt_parent_offset(fdt, node);
>> >> + if (parent < 0) {
>> >> + return NULL;
>> >> + ac = fdt_address_cells(fdt, parent);
>> >> + if (ac != 1 && ac != 2) {
>> >> + return NULL;
>> >> + sc = fdt_size_cells(fdt, parent);
>> >> + if (sc != 1 && sc != 2) {
>> >> + return NULL;
>> >> + if (sc > ac) {
>> >> + return NULL;
>> >> + val = fdt_getprop(fdt, node, "reg", &len);
>> >> + if (len < sc + ac) {
>> >> + return NULL;
>> >> + if (ac == 1) {
>> >> + start = fdt32_to_cpu(((fdt32_t *)val)[0]);
>> >> + size = fdt32_to_cpu(((fdt32_t *)val)[1]);
>> >> + if (ac == 2) {
>> >> + start = fdt64_to_cpu(((fdt64_t *)val)[0]);
>> >> + if (sc == 1)
>> >> + size = fdt32_to_cpu(((fdt32_t *)(val+8))[0]);
>> >> + else
>> >> + size = fdt64_to_cpu(((fdt64_t *)val)[1]);
>> >> + return (void*) (start + size);
>> >> +static void bsp_memory_initialize( void )
>> >> + void *end;
>> >> + /* get end of memory from the "/memory" node in the fdt */
>> >> + end = get_end_of_memory_from_fdt();
>> >> + if (end == 0) {
>> >> + /* fall back to linker symbol if "/memory" node not found or
>> invalid */
>> >> + end = RamEnd;
>> >> + _Memory_Initialize( &_Memory_Areas[ 0 ], WorkAreaBase, end );
>> >> +RTEMS_SYSINIT_ITEM(
>> >> + bsp_memory_initialize,
>> >> + RTEMS_SYSINIT_MEMORY,
>> >> + RTEMS_SYSINIT_ORDER_MIDDLE
>> >> +static const Memory_Information _Memory_Information =
>> >> + MEMORY_INFORMATION_INITIALIZER( _Memory_Areas );
>> >> +const Memory_Information *_Memory_Get( void )
>> >> + return &_Memory_Information;
>> >> diff --git a/spec/build/bsps/riscv/riscv/obj.yml
>> b/spec/build/bsps/riscv/riscv/obj.yml
>> >> index 5e767be1bb..b2eb467824 100644
>> >> --- a/spec/build/bsps/riscv/riscv/obj.yml
>> >> +++ b/spec/build/bsps/riscv/riscv/obj.yml
>> >> @@ -29,6 +29,7 @@ source:
>> >> - bsps/riscv/riscv/irq/irq.c
>> >> - bsps/riscv/riscv/start/bsp_fatal_halt.c
>> >> - bsps/riscv/riscv/start/bspstart.c
>> >> +- bsps/riscv/shared/start/bspgetworkarea.c
>> >> - bsps/shared/cache/nocache.c
>> >> - bsps/shared/dev/btimer/btimer-cpucounter.c
>> >> - bsps/shared/dev/getentropy/getentropy-cpucounter.c
>> >> 2.34.1
>> >> _______________________________________________
>> >> devel mailing list
>> >> devel at rtems.org
>> >> http://lists.rtems.org/mailman/listinfo/devel
>> >> devel mailing list
>> >> devel at rtems.org
>> >> devel mailing list
>> >> devel at rtems.org
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220820/92178397/attachment.htm>
