[PATCH v2 1/1] bsp/riscv: Work area size based on /memory node in fdt
Hesham Almatary Hesham.Almatary at cl.cam.ac.uk
Fri Aug 19 13:27:22 UTC 2022
On Fri, 19 Aug 2022 at 13:36, Daniel Cederman <cederman at gaisler.com> wrote:
> On 2022-08-19 11:16, Hesham Almatary wrote:
> > On Thu, 18 Aug 2022 at 13:55, Daniel Cederman <cederman at gaisler.com>
> wrote:
> >> I missed your comment, but have made the change now. Are there any
> instructions on how to run the RISCV BSP tests on QEMU or Spike? I could
> not get it to work. Do I need a special version of QEMU or Spike?
> > Thanks! AFAIR, you need to run the "medany" RISC-V variants for QEMU,
> > I'd use rtems-tester. No special QEMU version is needed.
> Thanks! I had to change "-m 64M -kernel" to "-m 128M -bios" to get it to
> run. Got the same result both with and without the patch for
> rv64imafd_medany:
Great! Thanks for testing. A patch to fix that in tester will be greatly
appreciated. I thought I submitted the -bios change before but apparently
not.
> Passed:        653
> Failed:         16
> User Input:      5
> Expected Fail:   0
> Indeterminate:   0
> Benchmark:       3
> Timeout:         5
> Test too long:   0
> Invalid:         0
> Wrong Version:   0
> Wrong Build:     0
> Wrong Tools:     0
> Wrong Header:    0
> Total:         682
> Failures:
>   exit03.exe
>   ttest02.exe
>   psx12.exe
>   smpirqs01.exe
>   sp69.exe
>   spintrcritical24.exe
>   spsysinit01.exe
>   ts-fatal-scheduler-requires-exactly-one-processor.exe
>   ts-fatal-start-of-mandatory-processor-failed.exe
>   ts-validation-1.exe
>   ts-validation-one-cpu-0.exe
>   minimum.exe
>   smpstart01.exe
>   ts-fatal-smp.exe
>   ts-performance-no-clock-0.exe
>   ts-validation-intr.exe
> User Input:
>   monitor.exe
>   termios.exe
>   top.exe
>   fileio.exe
>   capture.exe
> Benchmark:
>   dhrystone.exe
>   linpack.exe
>   whetstone.exe
> Timeouts:
>   ts-fatal-start-on-not-online-processor.exe
>   ts-validation-0.exe
>   ts-validation-no-clock-0.exe
>   ts-validation-smp-only-0.exe
>   ts-validation-timecounter-smp-0.exe
> >> On 2022-08-18 10:24, Hesham Almatary wrote:
> >> All good, I'd just replace the "end == 0" with "end == NULL" as per my
> >> comment above. Also please test on other RISC-V QEMU platforms to make
> >> sure nothing got broken.
> >> On Wed, 17 Aug 2022 at 14:10, Joel Sherrill <joel at rtems.org> wrote:
> >> I'm ok with this if Hesham acks as well.
> >> --joel
> >> On Wed, Aug 17, 2022 at 6:35 AM Daniel Cederman <cederman at gaisler.com>
> wrote:
> >> Uses the first entry in the /memory node to determine the end of the
> >> work area. Falls back on linker symbol if unable to parse the node.
> >>   bsps/riscv/shared/start/bspgetworkarea.c | 144 +++++++++++++++++++++++
> >>   spec/build/bsps/riscv/riscv/obj.yml      |   1 +
> >>   2 files changed, 145 insertions(+)
> >>   create mode 100644 bsps/riscv/shared/start/bspgetworkarea.c
> >> diff --git a/bsps/riscv/shared/start/bspgetworkarea.c
> b/bsps/riscv/shared/start/bspgetworkarea.c
> >> new file mode 100644
> >> index 0000000000..1fa051d25e
> >> --- /dev/null
> >> +++ b/bsps/riscv/shared/start/bspgetworkarea.c
> >> @@ -0,0 +1,144 @@
> >> +/* SPDX-License-Identifier: BSD-2-Clause */
> >> + * @file
> >> + * @brief BSP specific initialization support routines
> >> + * COPYRIGHT (c) 1989-2020.
> >> + * On-Line Applications Research Corporation (OAR).
> >> + * Cobham Gaisler AB.
> >> + * Redistribution and use in source and binary forms, with or without
> >> + * modification, are permitted provided that the following conditions
> >> + * are met:
> >> + * 1. Redistributions of source code must retain the above copyright
> >> + *    notice, this list of conditions and the following disclaimer.
> >> + * 2. Redistributions in binary form must reproduce the above copyright
> >> + *    notice, this list of conditions and the following disclaimer in
> the
> >> + *    documentation and/or other materials provided with the
> distribution.
> >> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> "AS IS"
> >> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
> TO, THE
> >> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> >> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
> CONTRIBUTORS BE
> >> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> >> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> >> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> >> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
> WHETHER IN
> >> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
> OTHERWISE)
> >> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
> OF THE
> >> + * POSSIBILITY OF SUCH DAMAGE.
> >> +#include <bsp.h>
> >> +#include <bsp/fdt.h>
> >> +#include <rtems/sysinit.h>
> >> +#include <libfdt.h>
> >> + *  These are provided by the linkcmds for ALL of the BSPs which use
> this file.
> >> +extern char WorkAreaBase[];
> >> +extern char RamEnd[];
> >> +static Memory_Area _Memory_Areas[ 1 ];
> >> +static const char memory_path[] = "/memory";
> >> +static void* get_end_of_memory_from_fdt(void)
> >> +  const void *fdt;
> >> +  const void *val;
> >> +  int node;
> >> +  int parent;
> >> +  int ac;
> >> +  int sc;
> >> +  int len;
> >> +  uintptr_t start;
> >> +  uintptr_t size;
> >> +  fdt = bsp_fdt_get();
> >> +  node = fdt_path_offset_namelen(
> >> +    fdt,
> >> +    memory_path,
> >> +    (int) sizeof(memory_path) - 1
> >> +  if (node < 0) {
> >> +    return NULL;
> >> +  parent = fdt_parent_offset(fdt, node);
> >> +  if (parent < 0) {
> >> +    return NULL;
> >> +  ac = fdt_address_cells(fdt, parent);
> >> +  if (ac != 1 && ac != 2) {
> >> +    return NULL;
> >> +  sc = fdt_size_cells(fdt, parent);
> >> +  if (sc != 1 && sc != 2) {
> >> +    return NULL;
> >> +  if (sc > ac) {
> >> +    return NULL;
> >> +  val = fdt_getprop(fdt, node, "reg", &len);
> >> +  if (len < sc + ac) {
> >> +    return NULL;
> >> +  if (ac == 1) {
> >> +    start = fdt32_to_cpu(((fdt32_t *)val)[0]);
> >> +    size = fdt32_to_cpu(((fdt32_t *)val)[1]);
> >> +  if (ac == 2) {
> >> +    start = fdt64_to_cpu(((fdt64_t *)val)[0]);
> >> +    if (sc == 1)
> >> +      size = fdt32_to_cpu(((fdt32_t *)(val+8))[0]);
> >> +    else
> >> +      size = fdt64_to_cpu(((fdt64_t *)val)[1]);
> >> +  return (void*) (start + size);
> >> +static void bsp_memory_initialize( void )
> >> +  void *end;
> >> +  /* get end of memory from the "/memory" node in the fdt */
> >> +  end = get_end_of_memory_from_fdt();
> >> +  if (end == 0) {
> >> +    /* fall back to linker symbol if "/memory" node not found or
> invalid */
> >> +    end = RamEnd;
> >> +  _Memory_Initialize( &_Memory_Areas[ 0 ], WorkAreaBase, end );
> >> +RTEMS_SYSINIT_ITEM(
> >> +  bsp_memory_initialize,
> >> +  RTEMS_SYSINIT_MEMORY,
> >> +  RTEMS_SYSINIT_ORDER_MIDDLE
> >> +static const Memory_Information _Memory_Information =
> >> +  MEMORY_INFORMATION_INITIALIZER( _Memory_Areas );
> >> +const Memory_Information *_Memory_Get( void )
> >> +  return &_Memory_Information;
> >> diff --git a/spec/build/bsps/riscv/riscv/obj.yml
> b/spec/build/bsps/riscv/riscv/obj.yml
> >> index 5e767be1bb..b2eb467824 100644
> >> --- a/spec/build/bsps/riscv/riscv/obj.yml
> >> +++ b/spec/build/bsps/riscv/riscv/obj.yml
> >> @@ -29,6 +29,7 @@ source:
> >>   - bsps/riscv/riscv/irq/irq.c
> >>   - bsps/riscv/riscv/start/bsp_fatal_halt.c
> >>   - bsps/riscv/riscv/start/bspstart.c
> >> +- bsps/riscv/shared/start/bspgetworkarea.c
> >>   - bsps/shared/cache/nocache.c
> >>   - bsps/shared/dev/btimer/btimer-cpucounter.c
> >>   - bsps/shared/dev/getentropy/getentropy-cpucounter.c
> >> 2.34.1
> >> _______________________________________________
> >> devel mailing list
> >> devel at rtems.org
> >> http://lists.rtems.org/mailman/listinfo/devel
> >> devel mailing list
> >> devel at rtems.org
> >> devel mailing list
> >> devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220819/55119dd1/attachment-0001.htm>
