-Werror on amd64 BSP makes it to installed package configuration file
Chris Johns
chrisj at rtems.org
Sun Aug 21 23:11:07 UTC 2022
On 20/8/2022 6:07 am, Joel Sherrill wrote:
> On Fri, Aug 19, 2022, 3:00 PM Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
> > On 20 Aug 2022, at 3:39 am, Joel Sherrill <joel at rtems.org
> <mailto:joel at rtems.org>> wrote:
> > Hi
> > Stephen tripped across this and I'm reporting it because it is going to
> > take some discussion to resolve.
> > Stephen is using the .pc files to create a configuration file
> > for the FACE Conformance Test Suite. This is now basically working
> > for multiple BSPs. The amd64 includes -Werror in its BSP compiler
> > options and is the only BSP to do so.
> Looks like a bug to me. It should not be in the standard CFLAGS returned by
> pkgconfig.
> Is there code.on our side filtering flags that missed this? I grep'ed for Werror
> and Wall but didn't find anything.
It should be only including the ABI flags so maybe they are wrong in this BSP:
https://git.rtems.org/rtems/tree/spec/build/bsps/x86_64/amd64/abi.yml
I have no idea why this is here.
> > (1) Do we want a BSP to include -Werror? amd64 being the only one
> > and use having a history of chasing warnings after gcc upgrades.
> Yes remove.
> Ok but is this the only way to remove a warning from the PC file?
The waf code to build generate the file should only include the ABI and include
options.
