[PATCH] bsps/xilinx/versal: Remove IPL32 BSPs, add aiedge and change defaults
Kinsey Moore kinsey.moore at oarcorp.com
Tue Aug 23 19:29:51 UTC 2022
Looks good to me as well.
On 8/22/2022 15:21, Joel Sherrill wrote:
> Looks ok. Push it.
> On Mon, Aug 22, 2022 at 1:54 AM <chrisj at rtems.org> wrote:
>     From: Chris Johns <chrisj at rtems.org>
>     - Versal has IO mapped to the upper 64bit address space and
>       needs full 64bit addresses.
>     - Add xilinx_versal_aiedge for custom hardware
>     - Make the hardware settings the defaults and qemu as variants
>     Closes #4693
>      spec/build/bsps/aarch64/xilinx-versal/abi.yml | 10 +--
>      .../{bspqemuilp32.yml => bspaiedge.yml}       |  8 +-
>      .../{bspqemulp64.yml => bspqemu.yml}          |  4 +-
>      .../{bspvck190lp64.yml => bspvck190.yml}      |  2 +-
>      .../{bspvck190ilp32.yml => grp_aiedge.yml}    | 16 ++--
>      .../aarch64/xilinx-versal/linkcmds_ilp32.yml  | 74
>      .../bsps/aarch64/xilinx-versal/optclkuart.yml |  9 +--
>      .../bsps/aarch64/xilinx-versal/optloadoff.yml |  7 +-
>      .../bsps/aarch64/xilinx-versal/optramori.yml  |  7 +-
>      .../bsps/aarch64/xilinx-versal/tstaiedge.yml  | 15 ++++
>      10 files changed, 42 insertions(+), 110 deletions(-)
>      rename spec/build/bsps/aarch64/xilinx-versal/{bspqemuilp32.yml =>
>     bspaiedge.yml} (67%)
>      rename spec/build/bsps/aarch64/xilinx-versal/{bspqemulp64.yml =>
>     bspqemu.yml} (82%)
>      rename spec/build/bsps/aarch64/xilinx-versal/{bspvck190lp64.yml
>     => bspvck190.yml} (91%)
>      rename spec/build/bsps/aarch64/xilinx-versal/{bspvck190ilp32.yml
>     => grp_aiedge.yml} (51%)
>      delete mode 100644
>     spec/build/bsps/aarch64/xilinx-versal/linkcmds_ilp32.yml
>      create mode 100644
>     spec/build/bsps/aarch64/xilinx-versal/tstaiedge.yml
>     diff --git a/spec/build/bsps/aarch64/xilinx-versal/abi.yml
>     b/spec/build/bsps/aarch64/xilinx-versal/abi.yml
>     index 90bfca9f76..b52df18fb3 100644
>     --- a/spec/build/bsps/aarch64/xilinx-versal/abi.yml
>     +++ b/spec/build/bsps/aarch64/xilinx-versal/abi.yml
>     @@ -5,16 +5,10 @@ actions:
>      - env-append: null
>      build-type: option
>      copyrights:
>     -- Copyright (C) 2021 Gedare Bloom
>     +- Copyright (C) 2021 Gedare Bloom
>      default:
>      - -mcpu=cortex-a72
>     -default-by-variant:
>     -- value:
>     -  - -mcpu=cortex-a72
>     -  - -mabi=ilp32
>     -  variants:
>     -  - aarch64/xilinx_versal_ilp32_qemu
>     -  - aarch64/xilinx_versal_ilp32_vck190
>     +default-by-variant: []
>      description: |
>        ABI flags
>      enabled-by: true
>     diff --git
>     a/spec/build/bsps/aarch64/xilinx-versal/bspqemuilp32.yml
>     b/spec/build/bsps/aarch64/xilinx-versal/bspaiedge.yml
>     similarity index 67%
>     rename from spec/build/bsps/aarch64/xilinx-versal/bspqemuilp32.yml
>     rename to spec/build/bsps/aarch64/xilinx-versal/bspaiedge.yml
>     index cdad919b1c..f8c9011143 100644
>     --- a/spec/build/bsps/aarch64/xilinx-versal/bspqemuilp32.yml
>     +++ b/spec/build/bsps/aarch64/xilinx-versal/bspaiedge.yml
>     @@ -1,10 +1,10 @@
>      SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
>      arch: aarch64
>     -bsp: xilinx_versal_ilp32_qemu
>     +bsp: xilinx_versal_aiedge
>      build-type: bsp
>      cflags: []
>      copyrights:
>     +- Copyright (C) 2022 Chris Johns <chris at contemporary.software>
>      cppflags: []
>      enabled-by: true
>      family: xilinx-versal
>     @@ -12,8 +12,8 @@ includes: []
>      install: []
>      links:
>      - role: build-dependency
>     -  uid: grp_qemu
>     +  uid: grp_aiedge
>     -  uid: linkcmds_ilp32
>     +  uid: linkcmds_lp64
>      source: []
>      type: build
>     diff --git a/spec/build/bsps/aarch64/xilinx-versal/bspqemulp64.yml
>     b/spec/build/bsps/aarch64/xilinx-versal/bspqemu.yml
>     similarity index 82%
>     rename from spec/build/bsps/aarch64/xilinx-versal/bspqemulp64.yml
>     rename to spec/build/bsps/aarch64/xilinx-versal/bspqemu.yml
>     index bd8dab6a6e..f7f167dbfb 100644
>     --- a/spec/build/bsps/aarch64/xilinx-versal/bspqemulp64.yml
>     +++ b/spec/build/bsps/aarch64/xilinx-versal/bspqemu.yml
>     @@ -1,10 +1,10 @@
>      arch: aarch64
>     -bsp: xilinx_versal_lp64_qemu
>     +bsp: xilinx_versal_qemu
>      build-type: bsp
>      cflags: []
>      copyrights:
>      cppflags: []
>      enabled-by: true
>     diff --git
>     a/spec/build/bsps/aarch64/xilinx-versal/bspvck190lp64.yml
>     b/spec/build/bsps/aarch64/xilinx-versal/bspvck190.yml
>     similarity index 91%
>     rename from spec/build/bsps/aarch64/xilinx-versal/bspvck190lp64.yml
>     rename to spec/build/bsps/aarch64/xilinx-versal/bspvck190.yml
>     index b33a10f8f0..bc2bbc1c5d 100644
>     --- a/spec/build/bsps/aarch64/xilinx-versal/bspvck190lp64.yml
>     +++ b/spec/build/bsps/aarch64/xilinx-versal/bspvck190.yml
>     @@ -1,6 +1,6 @@
>      arch: aarch64
>     -bsp: xilinx_versal_lp64_vck190
>     +bsp: xilinx_versal_vck190
>      build-type: bsp
>      cflags: []
>      copyrights:
>     diff --git
>     a/spec/build/bsps/aarch64/xilinx-versal/bspvck190ilp32.yml
>     b/spec/build/bsps/aarch64/xilinx-versal/grp_aiedge.yml
>     similarity index 51%
>     rename from spec/build/bsps/aarch64/xilinx-versal/bspvck190ilp32.yml
>     rename to spec/build/bsps/aarch64/xilinx-versal/grp_aiedge.yml
>     index 741b28c6e8..680584f36c 100644
>     --- a/spec/build/bsps/aarch64/xilinx-versal/bspvck190ilp32.yml
>     +++ b/spec/build/bsps/aarch64/xilinx-versal/grp_aiedge.yml
>     @@ -1,19 +1,19 @@
>     -arch: aarch64
>     -bsp: xilinx_versal_ilp32_vck190
>     -build-type: bsp
>     +build-type: group
>      cflags: []
>      copyrights:
>     -- Copyright (C) 2021 Gedare Bloom <gedare at rtems.org>
>      cppflags: []
>     +cxxflags: []
>      enabled-by: true
>     -family: xilinx-versal
>      includes: []
>      install: []
>     +ldflags: []
>      links:
>     -  uid: grp_vck190
>     +  uid: grp
>     -source: []
>     +  uid: tstaiedge
>      type: build
>     +use-after: []
>     +use-before: []
>     diff --git
>     a/spec/build/bsps/aarch64/xilinx-versal/linkcmds_ilp32.yml
>     b/spec/build/bsps/aarch64/xilinx-versal/linkcmds_ilp32.yml
>     deleted file mode 100644
>     index 2d7a922495..0000000000
>     --- a/spec/build/bsps/aarch64/xilinx-versal/linkcmds_ilp32.yml
>     +++ /dev/null
>     @@ -1,74 +0,0 @@
>     -SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
>     -build-type: config-file
>     -content: |
>     -  /* SPDX-License-Identifier: BSD-2-Clause */
>     -   * Copyright (C) 2021 Gedare Bloom <gedare at rtems.org>
>     -   * Redistribution and use in source and binary forms, with or
>     without
>     -   * modification, are permitted provided that the following
>     conditions
>     -   * are met:
>     -   * 1. Redistributions of source code must retain the above
>     copyright
>     -   *    notice, this list of conditions and the following disclaimer.
>     -   * 2. Redistributions in binary form must reproduce the above
>     copyright
>     disclaimer in the
>     -   *    documentation and/or other materials provided with the
>     distribution.
>     -   * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
>     CONTRIBUTORS "AS IS"
>     -   * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
>     LIMITED TO, THE
>     -   * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
>     PARTICULAR PURPOSE
>     -   * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
>     CONTRIBUTORS BE
>     -   * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
>     EXEMPLARY, OR
>     -   * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
>     PROCUREMENT OF
>     -   * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
>     OR BUSINESS
>     -   * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
>     WHETHER IN
>     -   * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
>     OTHERWISE)
>     -   * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
>     ADVISED OF THE
>     -   * POSSIBILITY OF SUCH DAMAGE.
>     -  MEMORY {
>     -    RAM       : ORIGIN = ${BSP_XILINX_VERSAL_RAM_BASE} +
>     ${BSP_XILINX_VERSAL_LOAD_OFFSET}, LENGTH =
>     ${BSP_XILINX_VERSAL_RAM_LENGTH} - ${BSP_XILINX_VERSAL_LOAD_OFFSET}
>     - ${BSP_XILINX_VERSAL_NOCACHE_LENGTH} - (0x1000 *
>     ${AARCH64_MMU_TRANSLATION_TABLE_PAGES})
>     -    NOCACHE   : ORIGIN = ${BSP_XILINX_VERSAL_RAM_BASE} +
>     ${BSP_XILINX_VERSAL_RAM_LENGTH} - (0x1000 *
>     ${AARCH64_MMU_TRANSLATION_TABLE_PAGES}) -
>     ${BSP_XILINX_VERSAL_NOCACHE_LENGTH}, LENGTH =
>     -    RAM_MMU   : ORIGIN = ${BSP_XILINX_VERSAL_RAM_BASE} +
>     ${AARCH64_MMU_TRANSLATION_TABLE_PAGES}), LENGTH = 0x1000 *
>     -  REGION_ALIAS ("REGION_START",          RAM);
>     -  REGION_ALIAS ("REGION_VECTOR",         RAM);
>     -  REGION_ALIAS ("REGION_TEXT",           RAM);
>     -  REGION_ALIAS ("REGION_TEXT_LOAD",      RAM);
>     -  REGION_ALIAS ("REGION_RODATA",         RAM);
>     -  REGION_ALIAS ("REGION_RODATA_LOAD",    RAM);
>     -  REGION_ALIAS ("REGION_DATA",           RAM);
>     -  REGION_ALIAS ("REGION_DATA_LOAD",      RAM);
>     -  REGION_ALIAS ("REGION_FAST_TEXT",      RAM);
>     -  REGION_ALIAS ("REGION_FAST_TEXT_LOAD", RAM);
>     -  REGION_ALIAS ("REGION_FAST_DATA",      RAM);
>     -  REGION_ALIAS ("REGION_FAST_DATA_LOAD", RAM);
>     -  REGION_ALIAS ("REGION_BSS",            RAM);
>     -  REGION_ALIAS ("REGION_WORK",           RAM);
>     -  REGION_ALIAS ("REGION_STACK",          RAM);
>     -  REGION_ALIAS ("REGION_NOCACHE",        NOCACHE);
>     -  REGION_ALIAS ("REGION_NOCACHE_LOAD",   NOCACHE);
>     -  bsp_stack_exception_size = DEFINED (bsp_stack_exception_size) ?
>     bsp_stack_exception_size : 1024;
>     -  bsp_section_rwbarrier_align = DEFINED
>     (bsp_section_rwbarrier_align) ? bsp_section_rwbarrier_align : 1M;
>     -  bsp_vector_table_in_start_section = 1;
>     -  bsp_translation_table_base = ORIGIN (RAM_MMU);
>     -  bsp_translation_table_end = ORIGIN (RAM_MMU) + LENGTH (RAM_MMU);
>     -  OUTPUT_FORMAT ("elf32-littleaarch64")
>     -  OUTPUT_ARCH (aarch64:ilp32)
>     -  INCLUDE linkcmds.base
>     -copyrights:
>     -enabled-by: true
>     -install-path: ${BSP_LIBDIR}
>     -links: []
>     -target: linkcmds
>     -type: build
>     diff --git a/spec/build/bsps/aarch64/xilinx-versal/optclkuart.yml
>     b/spec/build/bsps/aarch64/xilinx-versal/optclkuart.yml
>     index 4ba449b8fd..fb344019e2 100644
>     --- a/spec/build/bsps/aarch64/xilinx-versal/optclkuart.yml
>     +++ b/spec/build/bsps/aarch64/xilinx-versal/optclkuart.yml
>     @@ -4,13 +4,12 @@ actions:
>      - define: null
>      build-type: option
>      copyrights:
>     -default: 24000000
>     +- Copyright (C) 2021 Gedare Bloom <gedare at rtems.org>
>     +default: 100000000
>      default-by-variant:
>     -- value: 100000000
>     +- value: 24000000
>        variants:
>     -  - aarch64/xilinx_versal_ilp32.*
>     -  - aarch64/xilinx_versal_lp64.*
>     +  - aarch64/xilinx_versal_qemu
>      description: |
>        Versal UART clock frequency in Hz
>      enabled-by: true
>     diff --git a/spec/build/bsps/aarch64/xilinx-versal/optloadoff.yml
>     b/spec/build/bsps/aarch64/xilinx-versal/optloadoff.yml
>     index 41023dcf3e..577a1451dd 100644
>     --- a/spec/build/bsps/aarch64/xilinx-versal/optloadoff.yml
>     +++ b/spec/build/bsps/aarch64/xilinx-versal/optloadoff.yml
>     @@ -7,12 +7,11 @@ actions:
>      build-type: option
>      copyrights:
>     -default: 32768
>     +default: 0x0
>      default-by-variant:
>     -- value: 0x0
>     +- value: 32768
>        variants:
>     -  - aarch64/xilinx_versal_lp64_vck190
>      description: |
>        offset of RAM region from memory area base
>      enabled-by: true
>     diff --git a/spec/build/bsps/aarch64/xilinx-versal/optramori.yml
>     b/spec/build/bsps/aarch64/xilinx-versal/optramori.yml
>     index 8ab8f5bc13..6e94f55b7e 100644
>     --- a/spec/build/bsps/aarch64/xilinx-versal/optramori.yml
>     +++ b/spec/build/bsps/aarch64/xilinx-versal/optramori.yml
>      build-type: option
>      copyrights:
>     -default: 0x20000000
>     +default: 0x10000000
>      default-by-variant:
>     -- value: 0x10000000
>     +- value: 0x20000000
>        variants:
>      description: |
>        base address of memory area available to the BSP
>      enabled-by: true
>     diff --git a/spec/build/bsps/aarch64/xilinx-versal/tstaiedge.yml
>     b/spec/build/bsps/aarch64/xilinx-versal/tstaiedge.yml
>     new file mode 100644
>     index 0000000000..cbc1c7e381
>     --- /dev/null
>     +++ b/spec/build/bsps/aarch64/xilinx-versal/tstaiedge.yml
>     @@ -0,0 +1,15 @@
>     +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
>     +actions:
>     +- set-test-state:
>     +    # expected to produce a fatal-error when run
>     +    minimum: exclude
>     +build-type: option
>     +copyrights:
>     +default: null
>     +description: ''
>     +enabled-by: true
>     +links: []
>     +type: build
>     2.19.1
>     _______________________________________________
>     devel mailing list
>     devel at rtems.org
>     http://lists.rtems.org/mailman/listinfo/devel
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220823/86785806/attachment-0001.htm>
