[PATCH] bsps/xilinx/versal: Remove IPL32 BSPs, add aiedge and change defaults
Mon Aug 22 20:21:16 UTC 2022
Looks ok. Push it.
On Mon, Aug 22, 2022 at 1:54 AM <chrisj at rtems.org> wrote:
> From: Chris Johns <chrisj at rtems.org>
> - Versal has IO mapped to the upper 64bit address space and
>   needs full 64bit addresses.
> - Add xilinx_versal_aiedge for custom hardware
> - Make the hardware settings the defaults and qemu as variants
> Closes #4693
>  spec/build/bsps/aarch64/xilinx-versal/abi.yml | 10 +--
>  .../{bspqemuilp32.yml => bspaiedge.yml}       |  8 +-
>  .../{bspqemulp64.yml => bspqemu.yml}          |  4 +-
>  .../{bspvck190lp64.yml => bspvck190.yml}      |  2 +-
>  .../{bspvck190ilp32.yml => grp_aiedge.yml}    | 16 ++--
>  .../aarch64/xilinx-versal/linkcmds_ilp32.yml  | 74 -------------------
>  .../bsps/aarch64/xilinx-versal/optclkuart.yml |  9 +--
>  .../bsps/aarch64/xilinx-versal/optloadoff.yml |  7 +-
>  .../bsps/aarch64/xilinx-versal/optramori.yml  |  7 +-
>  .../bsps/aarch64/xilinx-versal/tstaiedge.yml  | 15 ++++
>  10 files changed, 42 insertions(+), 110 deletions(-)
>  rename spec/build/bsps/aarch64/xilinx-versal/{bspqemuilp32.yml =>
> bspaiedge.yml} (67%)
>  rename spec/build/bsps/aarch64/xilinx-versal/{bspqemulp64.yml =>
> bspqemu.yml} (82%)
>  rename spec/build/bsps/aarch64/xilinx-versal/{bspvck190lp64.yml =>
> bspvck190.yml} (91%)
>  rename spec/build/bsps/aarch64/xilinx-versal/{bspvck190ilp32.yml =>
> grp_aiedge.yml} (51%)
>  delete mode 100644
> spec/build/bsps/aarch64/xilinx-versal/linkcmds_ilp32.yml
>  create mode 100644 spec/build/bsps/aarch64/xilinx-versal/tstaiedge.yml
> diff --git a/spec/build/bsps/aarch64/xilinx-versal/abi.yml
> b/spec/build/bsps/aarch64/xilinx-versal/abi.yml
> index 90bfca9f76..b52df18fb3 100644
> --- a/spec/build/bsps/aarch64/xilinx-versal/abi.yml
> +++ b/spec/build/bsps/aarch64/xilinx-versal/abi.yml
> @@ -5,16 +5,10 @@ actions:
>  - env-append: null
>  build-type: option
>  copyrights:
> -- Copyright (C) 2021 Gedare Bloom
> +- Copyright (C) 2021 Gedare Bloom
>  default:
>  - -mcpu=cortex-a72
> -default-by-variant:
> -- value:
> -  - -mcpu=cortex-a72
> -  - -mabi=ilp32
> -  variants:
> -  - aarch64/xilinx_versal_ilp32_qemu
> -  - aarch64/xilinx_versal_ilp32_vck190
> +default-by-variant: []
>  description: |
>    ABI flags
>  enabled-by: true
> diff --git a/spec/build/bsps/aarch64/xilinx-versal/bspqemuilp32.yml
> b/spec/build/bsps/aarch64/xilinx-versal/bspaiedge.yml
> similarity index 67%
> rename from spec/build/bsps/aarch64/xilinx-versal/bspqemuilp32.yml
> rename to spec/build/bsps/aarch64/xilinx-versal/bspaiedge.yml
> index cdad919b1c..f8c9011143 100644
> --- a/spec/build/bsps/aarch64/xilinx-versal/bspqemuilp32.yml
> +++ b/spec/build/bsps/aarch64/xilinx-versal/bspaiedge.yml
> @@ -1,10 +1,10 @@
>  SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
>  arch: aarch64
> -bsp: xilinx_versal_ilp32_qemu
> +bsp: xilinx_versal_aiedge
>  build-type: bsp
>  cflags: []
>  copyrights:
> +- Copyright (C) 2022 Chris Johns <chris at contemporary.software>
>  cppflags: []
>  enabled-by: true
>  family: xilinx-versal
> @@ -12,8 +12,8 @@ includes: []
>  install: []
>  links:
>  - role: build-dependency
> -  uid: grp_qemu
> +  uid: grp_aiedge
> -  uid: linkcmds_ilp32
> +  uid: linkcmds_lp64
>  source: []
>  type: build
> diff --git a/spec/build/bsps/aarch64/xilinx-versal/bspqemulp64.yml
> b/spec/build/bsps/aarch64/xilinx-versal/bspqemu.yml
> similarity index 82%
> rename from spec/build/bsps/aarch64/xilinx-versal/bspqemulp64.yml
> rename to spec/build/bsps/aarch64/xilinx-versal/bspqemu.yml
> index bd8dab6a6e..f7f167dbfb 100644
> --- a/spec/build/bsps/aarch64/xilinx-versal/bspqemulp64.yml
> +++ b/spec/build/bsps/aarch64/xilinx-versal/bspqemu.yml
> @@ -1,10 +1,10 @@
>  arch: aarch64
> -bsp: xilinx_versal_lp64_qemu
> +bsp: xilinx_versal_qemu
>  build-type: bsp
>  cflags: []
>  copyrights:
>  cppflags: []
>  enabled-by: true
> diff --git a/spec/build/bsps/aarch64/xilinx-versal/bspvck190lp64.yml
> b/spec/build/bsps/aarch64/xilinx-versal/bspvck190.yml
> similarity index 91%
> rename from spec/build/bsps/aarch64/xilinx-versal/bspvck190lp64.yml
> rename to spec/build/bsps/aarch64/xilinx-versal/bspvck190.yml
> index b33a10f8f0..bc2bbc1c5d 100644
> --- a/spec/build/bsps/aarch64/xilinx-versal/bspvck190lp64.yml
> +++ b/spec/build/bsps/aarch64/xilinx-versal/bspvck190.yml
> @@ -1,6 +1,6 @@
>  arch: aarch64
> -bsp: xilinx_versal_lp64_vck190
> +bsp: xilinx_versal_vck190
>  build-type: bsp
>  cflags: []
>  copyrights:
> diff --git a/spec/build/bsps/aarch64/xilinx-versal/bspvck190ilp32.yml
> b/spec/build/bsps/aarch64/xilinx-versal/grp_aiedge.yml
> similarity index 51%
> rename from spec/build/bsps/aarch64/xilinx-versal/bspvck190ilp32.yml
> rename to spec/build/bsps/aarch64/xilinx-versal/grp_aiedge.yml
> index 741b28c6e8..680584f36c 100644
> --- a/spec/build/bsps/aarch64/xilinx-versal/bspvck190ilp32.yml
> +++ b/spec/build/bsps/aarch64/xilinx-versal/grp_aiedge.yml
> @@ -1,19 +1,19 @@
> -arch: aarch64
> -bsp: xilinx_versal_ilp32_vck190
> -build-type: bsp
> +build-type: group
>  cflags: []
>  copyrights:
> -- Copyright (C) 2021 Gedare Bloom <gedare at rtems.org>
>  cppflags: []
> +cxxflags: []
>  enabled-by: true
> -family: xilinx-versal
>  includes: []
>  install: []
> +ldflags: []
>  links:
> -  uid: grp_vck190
> +  uid: grp
> -source: []
> +  uid: tstaiedge
>  type: build
> +use-after: []
> +use-before: []
> diff --git a/spec/build/bsps/aarch64/xilinx-versal/linkcmds_ilp32.yml
> b/spec/build/bsps/aarch64/xilinx-versal/linkcmds_ilp32.yml
> deleted file mode 100644
> index 2d7a922495..0000000000
> --- a/spec/build/bsps/aarch64/xilinx-versal/linkcmds_ilp32.yml
> +++ /dev/null
> @@ -1,74 +0,0 @@
> -SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> -build-type: config-file
> -content: |
> -  /* SPDX-License-Identifier: BSD-2-Clause */
> -   * Copyright (C) 2021 Gedare Bloom <gedare at rtems.org>
> -   * Redistribution and use in source and binary forms, with or without
> -   * modification, are permitted provided that the following conditions
> -   * are met:
> -   * 1. Redistributions of source code must retain the above copyright
> -   *    notice, this list of conditions and the following disclaimer.
> -   * 2. Redistributions in binary form must reproduce the above copyright
> -   *    notice, this list of conditions and the following disclaimer in
> the
> -   *    documentation and/or other materials provided with the
> distribution.
> -   * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> "AS IS"
> -   * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
> TO, THE
> -   * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> -   * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
> CONTRIBUTORS BE
> -   * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> -   * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> -   * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> -   * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER
> IN
> -   * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
> OTHERWISE)
> -   * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
> OF THE
> -   * POSSIBILITY OF SUCH DAMAGE.
> -  MEMORY {
> -    RAM       : ORIGIN = ${BSP_XILINX_VERSAL_RAM_BASE} +
> ${BSP_XILINX_VERSAL_LOAD_OFFSET}, LENGTH = ${BSP_XILINX_VERSAL_RAM_LENGTH}
> - ${BSP_XILINX_VERSAL_LOAD_OFFSET} - ${BSP_XILINX_VERSAL_NOCACHE_LENGTH} -
> (0x1000 * ${AARCH64_MMU_TRANSLATION_TABLE_PAGES})
> -    NOCACHE   : ORIGIN = ${BSP_XILINX_VERSAL_RAM_BASE} +
> ${BSP_XILINX_VERSAL_RAM_LENGTH} - (0x1000 *
> ${AARCH64_MMU_TRANSLATION_TABLE_PAGES}) -
> ${BSP_XILINX_VERSAL_NOCACHE_LENGTH}, LENGTH =
> -    RAM_MMU   : ORIGIN = ${BSP_XILINX_VERSAL_RAM_BASE} +
> ${AARCH64_MMU_TRANSLATION_TABLE_PAGES}), LENGTH = 0x1000 *
> -  REGION_ALIAS ("REGION_START",          RAM);
> -  REGION_ALIAS ("REGION_VECTOR",         RAM);
> -  REGION_ALIAS ("REGION_TEXT",           RAM);
> -  REGION_ALIAS ("REGION_TEXT_LOAD",      RAM);
> -  REGION_ALIAS ("REGION_RODATA",         RAM);
> -  REGION_ALIAS ("REGION_RODATA_LOAD",    RAM);
> -  REGION_ALIAS ("REGION_DATA",           RAM);
> -  REGION_ALIAS ("REGION_DATA_LOAD",      RAM);
> -  REGION_ALIAS ("REGION_FAST_TEXT",      RAM);
> -  REGION_ALIAS ("REGION_FAST_TEXT_LOAD", RAM);
> -  REGION_ALIAS ("REGION_FAST_DATA",      RAM);
> -  REGION_ALIAS ("REGION_FAST_DATA_LOAD", RAM);
> -  REGION_ALIAS ("REGION_BSS",            RAM);
> -  REGION_ALIAS ("REGION_WORK",           RAM);
> -  REGION_ALIAS ("REGION_STACK",          RAM);
> -  REGION_ALIAS ("REGION_NOCACHE",        NOCACHE);
> -  REGION_ALIAS ("REGION_NOCACHE_LOAD",   NOCACHE);
> -  bsp_stack_exception_size = DEFINED (bsp_stack_exception_size) ?
> bsp_stack_exception_size : 1024;
> -  bsp_section_rwbarrier_align = DEFINED (bsp_section_rwbarrier_align) ?
> bsp_section_rwbarrier_align : 1M;
> -  bsp_vector_table_in_start_section = 1;
> -  bsp_translation_table_base = ORIGIN (RAM_MMU);
> -  bsp_translation_table_end = ORIGIN (RAM_MMU) + LENGTH (RAM_MMU);
> -  OUTPUT_FORMAT ("elf32-littleaarch64")
> -  OUTPUT_ARCH (aarch64:ilp32)
> -  INCLUDE linkcmds.base
> -copyrights:
> -enabled-by: true
> -install-path: ${BSP_LIBDIR}
> -links: []
> -target: linkcmds
> -type: build
> diff --git a/spec/build/bsps/aarch64/xilinx-versal/optclkuart.yml
> b/spec/build/bsps/aarch64/xilinx-versal/optclkuart.yml
> index 4ba449b8fd..fb344019e2 100644
> --- a/spec/build/bsps/aarch64/xilinx-versal/optclkuart.yml
> +++ b/spec/build/bsps/aarch64/xilinx-versal/optclkuart.yml
> @@ -4,13 +4,12 @@ actions:
>  - define: null
>  build-type: option
>  copyrights:
> -default: 24000000
> +- Copyright (C) 2021 Gedare Bloom <gedare at rtems.org>
> +default: 100000000
>  default-by-variant:
> -- value: 100000000
> +- value: 24000000
>    variants:
> -  - aarch64/xilinx_versal_ilp32.*
> -  - aarch64/xilinx_versal_lp64.*
> +  - aarch64/xilinx_versal_qemu
>  description: |
>    Versal UART clock frequency in Hz
>  enabled-by: true
> diff --git a/spec/build/bsps/aarch64/xilinx-versal/optloadoff.yml
> b/spec/build/bsps/aarch64/xilinx-versal/optloadoff.yml
> index 41023dcf3e..577a1451dd 100644
> --- a/spec/build/bsps/aarch64/xilinx-versal/optloadoff.yml
> +++ b/spec/build/bsps/aarch64/xilinx-versal/optloadoff.yml
> @@ -7,12 +7,11 @@ actions:
>  build-type: option
>  copyrights:
> -default: 32768
> +default: 0x0
>  default-by-variant:
> -- value: 0x0
> +- value: 32768
>    variants:
> -  - aarch64/xilinx_versal_lp64_vck190
>  description: |
>    offset of RAM region from memory area base
>  enabled-by: true
> diff --git a/spec/build/bsps/aarch64/xilinx-versal/optramori.yml
> b/spec/build/bsps/aarch64/xilinx-versal/optramori.yml
> index 8ab8f5bc13..6e94f55b7e 100644
> --- a/spec/build/bsps/aarch64/xilinx-versal/optramori.yml
> +++ b/spec/build/bsps/aarch64/xilinx-versal/optramori.yml
>  build-type: option
>  copyrights:
> -default: 0x20000000
> +default: 0x10000000
>  default-by-variant:
> -- value: 0x10000000
> +- value: 0x20000000
>    variants:
>  description: |
>    base address of memory area available to the BSP
>  enabled-by: true
> diff --git a/spec/build/bsps/aarch64/xilinx-versal/tstaiedge.yml
> b/spec/build/bsps/aarch64/xilinx-versal/tstaiedge.yml
> new file mode 100644
> index 0000000000..cbc1c7e381
> --- /dev/null
> +++ b/spec/build/bsps/aarch64/xilinx-versal/tstaiedge.yml
> @@ -0,0 +1,15 @@
> +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> +actions:
> +- set-test-state:
> +    # expected to produce a fatal-error when run
> +    minimum: exclude
> +build-type: option
> +copyrights:
> +default: null
> +description: ''
> +enabled-by: true
> +links: []
> +type: build
> 2.19.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220822/20365394/attachment-0001.htm>
