[PATCH rtems-lwip v1 2/8] lwip: Use definitions from tools
Kinsey Moore
kinsey.moore at oarcorp.com
Tue Aug 23 19:47:35 UTC 2022
This alters lwip to use network structs from the toolchain headers
instead of redefining them slightly differently itself. This is
important for being able to port code to work on lwip as most ported
code will depend on the tools headers instead of being written
specifically for lwIP and the mismatches caused result in memory
corruption and other problems. This also brings the changes in these
lwIP headers in line with the add-only code import philosophy.
lwip/src/include/lwip/def.h | 8 ++++
lwip/src/include/lwip/inet.h | 16 ++++++++
lwip/src/include/lwip/netdb.h | 69 +++++----------------------------
lwip/src/include/lwip/sockets.h | 53 ++++++++++++++++++-------
4 files changed, 72 insertions(+), 74 deletions(-)
diff --git a/lwip/src/include/lwip/def.h b/lwip/src/include/lwip/def.h
index dfb266d..cafb4dd 100644
--- a/lwip/src/include/lwip/def.h
+++ b/lwip/src/include/lwip/def.h
@@ -58,6 +58,10 @@
#define PERF_STOP(x) /* null definition */
#endif /* LWIP_PERF */
+#ifdef __rtems__
+#include <netinet/in.h>
+#endif
#ifdef __cplusplus
extern "C" {
#endif
@@ -115,6 +119,10 @@ u32_t lwip_htonl(u32_t x);
#endif /* BYTE_ORDER == BIG_ENDIAN */
/* Provide usual function names as macros for users, but this can be turned off */
+#ifdef __rtems__
+#define LWIP_DONT_PROVIDE_BYTEORDER_FUNCTIONS
+#endif
#ifndef LWIP_DONT_PROVIDE_BYTEORDER_FUNCTIONS
#define htons(x) lwip_htons(x)
#define ntohs(x) lwip_ntohs(x)
diff --git a/lwip/src/include/lwip/inet.h b/lwip/src/include/lwip/inet.h
index 2982a0f..b6fac46 100644
--- a/lwip/src/include/lwip/inet.h
+++ b/lwip/src/include/lwip/inet.h
@@ -55,6 +55,21 @@ extern "C" {
typedef u32_t in_addr_t;
#endif
+#ifdef __rtems__
+#define inet_addr_from_ip4addr(target_inaddr, source_ipaddr) ((target_inaddr)->s_addr = ip4_addr_get_u32(source_ipaddr))
+#define inet_addr_to_ip4addr(target_ipaddr, source_inaddr) (ip4_addr_set_u32(target_ipaddr, (source_inaddr)->s_addr))
+#define inet6_addr_from_ip6addr(target_in6addr, source_ip6addr) {(target_in6addr)->__u6_addr.__u6_addr32[0] = (source_ip6addr)->addr[0]; \
+ (target_in6addr)->__u6_addr.__u6_addr32[1] = (source_ip6addr)->addr[1]; \
+ (target_in6addr)->__u6_addr.__u6_addr32[2] = (source_ip6addr)->addr[2]; \
+ (target_in6addr)->__u6_addr.__u6_addr32[3] = (source_ip6addr)->addr[3];}
+#define inet6_addr_to_ip6addr(target_ip6addr, source_in6addr) {(target_ip6addr)->addr[0] = (source_in6addr)->__u6_addr.__u6_addr32[0]; \
+ (target_ip6addr)->addr[1] = (source_in6addr)->__u6_addr.__u6_addr32[1]; \
+ (target_ip6addr)->addr[2] = (source_in6addr)->__u6_addr.__u6_addr32[2]; \
+ (target_ip6addr)->addr[3] = (source_in6addr)->__u6_addr.__u6_addr32[3]; \
+ ip6_addr_clear_zone(target_ip6addr);}
+#else
struct in_addr {
in_addr_t s_addr;
@@ -161,6 +176,7 @@ extern const struct in6_addr in6addr_any;
#endif /* LWIP_IPV6 */
+#endif /* __rtems__ */
#ifdef __cplusplus
diff --git a/lwip/src/include/lwip/netdb.h b/lwip/src/include/lwip/netdb.h
index ff33ec7..eaae285 100644
--- a/lwip/src/include/lwip/netdb.h
+++ b/lwip/src/include/lwip/netdb.h
@@ -46,6 +46,9 @@
extern "C" {
#endif
+#ifdef __rtems__
+#include <netdb.h>
+#else
/* some rarely used options */
#ifndef LWIP_DNS_API_DECLARE_H_ERRNO
#define LWIP_DNS_API_DECLARE_H_ERRNO 1
@@ -111,9 +114,15 @@ struct addrinfo {
struct addrinfo *ai_next; /* Pointer to next in list. */
#endif /* LWIP_DNS_API_DECLARE_STRUCTS */
#define NETDB_ELEM_SIZE (sizeof(struct addrinfo) + sizeof(struct sockaddr_storage) + DNS_MAX_NAME_LENGTH + 1)
+#if LWIP_DNS_API_DECLARE_H_ERRNO
+/* application accessible error code set by the DNS API functions */
+extern int h_errno;
+#endif /* LWIP_DNS_API_DECLARE_H_ERRNO*/
struct hostent *lwip_gethostbyname(const char *name);
int lwip_gethostbyname_r(const char *name, struct hostent *ret, char *buf,
size_t buflen, struct hostent **result, int *h_errnop);
@@ -123,64 +132,6 @@ int lwip_getaddrinfo(const char *nodename,
const struct addrinfo *hints,
struct addrinfo **res);
-const char *hstrerror(int err);
-#include "lwip/sockets.h"
-#define EAI_OVERFLOW 208
- struct servent {
- char *s_name; /* official service name */
- char **s_aliases; /* alias list */
- int s_port; /* port number */
- char *s_proto; /* protocol to use */
- * Error return codes from getaddrinfo()
- #define EAI_ADDRFAMILY 1 /* address family for hostname not supported */
- #define EAI_NODATA 7 /* no address associated with hostname */
- #define EAI_SOCKTYPE 10 /* ai_socktype not supported */
- #define EAI_SYSTEM 11 /* system 6rror returned in errno */
- #define EAI_BADHINTS 12
- #define EAI_PROTOCOL 13
- #define EAI_MAX 14
- * Constants for getnameinfo()
-#define NI_MAXHOST 1025
-#define NI_MAXSERV 32
- * Flag values for getnameinfo()
-#define NI_NOFQDN 0x00000001
-#define NI_NUMERICHOST 0x00000002
-#define NI_NAMEREQD 0x00000004
-#define NI_NUMERICSERV 0x00000008
-#define NI_DGRAM 0x00000010
-#define NI_WITHSCOPEID 0x00000020
-#ifndef AF_UNIX
-#define AF_UNIX 1
-#endif
-int
-getnameinfo(const struct sockaddr *sa, socklen_t salen,
- char *host, size_t hostlen,
- char *serv, size_t servlen, int flags);
-const char *gai_strerror(int ecode);
-struct servent *getservbyname(const char *name, const char *proto);
-#if LWIP_DNS_API_DECLARE_H_ERRNO
-/* application accessible error code set by the DNS API functions */
-extern int h_errno;
-#endif /* LWIP_DNS_API_DECLARE_H_ERRNO*/
#if LWIP_COMPAT_SOCKETS
/** @ingroup netdbapi */
#define gethostbyname(name) lwip_gethostbyname(name)
@@ -194,8 +145,6 @@ extern int h_errno;
lwip_getaddrinfo(nodname, servname, hints, res)
#endif /* LWIP_COMPAT_SOCKETS */
#ifdef __cplusplus
#endif
diff --git a/lwip/src/include/lwip/sockets.h b/lwip/src/include/lwip/sockets.h
index 2917041..be94852 100644
--- a/lwip/src/include/lwip/sockets.h
+++ b/lwip/src/include/lwip/sockets.h
@@ -39,6 +39,22 @@
#ifndef LWIP_HDR_SOCKETS_H
#define LWIP_HDR_SOCKETS_H
+#ifdef __rtems__
+#ifdef TCP_MSS
+#define TCP_MSS_DEFINED_EARLY
+#pragma push_macro("TCP_MSS")
+#endif
+#include <netinet/tcp.h>
+#pragma pop_macro("TCP_MSS")
+#ifndef TCP_MSS_DEFINED_EARLY
+#undef TCP_MSS
+#endif
#include "lwip/opt.h"
#if LWIP_SOCKET /* don't build if not configured for use in lwipopts.h */
@@ -67,6 +83,10 @@ typedef u8_t sa_family_t;
typedef u16_t in_port_t;
#endif
+#ifdef __rtems__
+#define SIN_ZERO_LEN 8
+#else
#if LWIP_IPV4
/* members are in network byte order */
struct sockaddr_in {
@@ -90,7 +110,6 @@ struct sockaddr_in6 {
-#ifndef __rtems__
struct sockaddr {
u8_t sa_len;
sa_family_t sa_family;
@@ -148,7 +167,6 @@ struct cmsghdr {
int cmsg_level; /* originating protocol */
int cmsg_type; /* protocol-specific type */
-#endif /* __rtems__ */
/* Data section follows header and possible padding, typically referred to as
unsigned char cmsg_data[]; */
@@ -160,7 +178,6 @@ will need to increase long long */
#define ALIGN_H(size) (((size) + sizeof(long) - 1U) & ~(sizeof(long)-1U))
#define ALIGN_D(size) ALIGN_H(size)
-#ifndef __rtems__
#define CMSG_FIRSTHDR(mhdr) \
((mhdr)->msg_controllen >= sizeof(struct cmsghdr) ? \
(struct cmsghdr *)(mhdr)->msg_control : \
@@ -255,7 +272,6 @@ struct linger {
#define PF_INET AF_INET
#define PF_INET6 AF_INET6
#define PF_UNSPEC AF_UNSPEC
#define IPPROTO_IP 0
#define IPPROTO_ICMP 1
@@ -268,7 +284,6 @@ struct linger {
#define IPPROTO_UDPLITE 136
#define IPPROTO_RAW 255
-#ifndef __rtems__
/* Flags we can use with send and recv. */
#define MSG_PEEK 0x01 /* Peeks at an incoming message */
#define MSG_WAITALL 0x02 /* Unimplemented: Requests that the function block until the full amount of data requested can be returned */
@@ -278,32 +293,39 @@ struct linger {
#define MSG_MORE 0x10 /* Sender will send more */
#ifndef __rtems__
#define MSG_NOSIGNAL 0x20 /* Uninmplemented: Requests not to send the SIGPIPE signal if an attempt to send is made on a stream-oriented socket that is no longer connected. */
* Options for level IPPROTO_IP
#define IP_TOS 1
#define IP_TTL 2
#define IP_PKTINFO 8
#if LWIP_TCP
+#ifndef __rtems__
* Options for level IPPROTO_TCP
#define TCP_NODELAY 0x01 /* don't delay send to coalesce packets */
+#endif
#define TCP_KEEPALIVE 0x02 /* send KEEPALIVE probes when idle for pcb->keep_idle milliseconds */
+#ifndef __rtems__
#define TCP_KEEPIDLE 0x03 /* set pcb->keep_idle - Same as TCP_KEEPALIVE, but use seconds for get/setsockopt */
#define TCP_KEEPINTVL 0x04 /* set pcb->keep_intvl - Use seconds for get/setsockopt */
#define TCP_KEEPCNT 0x05 /* set pcb->keep_cnt - Use number of probes sent for get/setsockopt */
+#endif
#endif /* LWIP_TCP */
#if LWIP_IPV6
* Options for level IPPROTO_IPV6
+#ifndef __rtems__
#define IPV6_CHECKSUM 7 /* RFC3542: calculate and insert the ICMPv6 checksum for raw sockets. */
#define IPV6_V6ONLY 27 /* RFC3493: boolean control to restrict AF_INET6 sockets to IPv6 communications only. */
+#endif
#if LWIP_UDP && LWIP_UDPLITE
@@ -315,6 +337,7 @@ struct linger {
#endif /* LWIP_UDP && LWIP_UDPLITE*/
+#ifndef __rtems__
#if LWIP_MULTICAST_TX_OPTIONS
* Options and types for UDP multicast traffic handling
@@ -336,6 +359,7 @@ typedef struct ip_mreq {
struct in_addr imr_interface; /* local IP address of interface */
} ip_mreq;
#endif /* LWIP_IGMP */
#if LWIP_IPV4
struct in_pktinfo {
@@ -348,6 +372,7 @@ struct in_pktinfo {
* Options and types related to IPv6 multicast membership
+#ifndef __rtems__
#define IPV6_JOIN_GROUP 12
#define IPV6_ADD_MEMBERSHIP IPV6_JOIN_GROUP
#define IPV6_LEAVE_GROUP 13
@@ -357,6 +382,7 @@ typedef struct ipv6_mreq {
struct in6_addr ipv6mr_multiaddr; /* IPv6 multicast addr */
unsigned int ipv6mr_interface; /* interface index, or 0 */
} ipv6_mreq;
+#endif
#endif /* LWIP_IPV6_MLD */
@@ -414,16 +440,17 @@ typedef struct ipv6_mreq {
* to encode the in/out status of the parameter; for now
* we restrict parameters to at most 128 bytes.
+#ifdef __rtems__
+#include <sys/fcntl.h>
+#include <sys/filio.h>
+#include <sys/select.h>
+#endif
#if !defined(FIONREAD) || !defined(FIONBIO)
-#undef IOCPARM_MASK
#define IOCPARM_MASK 0x7fU /* parameters must be < 128 bytes */
-#ifndef __rtems__
#define IOC_VOID 0x20000000UL /* no parameters */
#define IOC_OUT 0x40000000UL /* copy out parameters */
-#endif /* __rtems __ */
-#undef IOC_IN
#define IOC_IN 0x80000000UL /* copy in parameters */
-#ifndef __rtems__
#define IOC_INOUT (IOC_IN|IOC_OUT)
/* 0x20000000 distinguishes new &
old ioctl's */
@@ -431,8 +458,6 @@ typedef struct ipv6_mreq {
#define _IOR(x,y,t) ((long)(IOC_OUT|((sizeof(t)&IOCPARM_MASK)<<16)|((x)<<8)|(y)))
-#undef _IOW
#define _IOW(x,y,t) ((long)(IOC_IN|((sizeof(t)&IOCPARM_MASK)<<16)|((x)<<8)|(y)))
#endif /* !defined(FIONREAD) || !defined(FIONBIO) */
@@ -679,7 +704,7 @@ int lwip_inet_pton(int af, const char *src, void *dst);
#define poll(fds,nfds,timeout) lwip_poll(fds,nfds,timeout)
#endif
/** @ingroup socket */
-//#define ioctlsocket(s,cmd,argp) lwip_ioctl(s,cmd,argp)
+#define ioctlsocket(s,cmd,argp) lwip_ioctl(s,cmd,argp)
#define inet_ntop(af,src,dst,size) lwip_inet_ntop(af,src,dst,size)
2.30.2
