[PATCH rtems-lwip v1 3/8] rtemslwip: Document a deficiency in syslog
Kinsey Moore kinsey.moore at oarcorp.com
Tue Aug 23 19:47:36 UTC 2022
 rtemslwip/common/syslog.c | 3 +++
 1 file changed, 3 insertions(+)
diff --git a/rtemslwip/common/syslog.c b/rtemslwip/common/syslog.c
index e544074..4da911e 100644
--- a/rtemslwip/common/syslog.c
+++ b/rtemslwip/common/syslog.c
@@ -38,6 +38,9 @@ syslog (int pri, const char *fmt, ...)
  * FIXME: Should cbuf be static?  Then we wouldn't
  *        have to worry about blowing stacks with a local variable
  *        that large.  Could make cbuf bigger, too.
+ * FIXME: This does not properly handle the %m format specifier which should
+ *        insert the string result of strerror(errno).
 void
 vsyslog (int pri, const char *fmt, va_list ap)
2.30.2
