[PATCH] bsps/xilinx/versal: Add Cadence I2C driver support
chrisj at rtems.org
chrisj at rtems.org
Wed Aug 24 07:19:09 UTC 2022
bsps/aarch64/xilinx-versal/include/bsp.h | 4 ++
bsps/aarch64/xilinx-versal/include/bsp/i2c.h | 64 +++++++++++++++++++
bsps/aarch64/xilinx-versal/include/bsp/irq.h | 2 +
bsps/aarch64/xilinx-versal/start/bspstart.c | 12 ++++
spec/build/bsps/aarch64/xilinx-versal/grp.yml | 4 ++
.../bsps/aarch64/xilinx-versal/grp_aiedge.yml | 2 +
.../bsps/aarch64/xilinx-versal/grp_vck190.yml | 2 +
.../aarch64/xilinx-versal/objcadencei2c.yml | 21 ++++++
.../bsps/aarch64/xilinx-versal/optclki2c0.yml | 17 +++++
.../bsps/aarch64/xilinx-versal/optclki2c1.yml | 17 +++++
10 files changed, 145 insertions(+)
create mode 100644 bsps/aarch64/xilinx-versal/include/bsp/i2c.h
create mode 100644 spec/build/bsps/aarch64/xilinx-versal/objcadencei2c.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-versal/optclki2c0.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-versal/optclki2c1.yml
diff --git a/bsps/aarch64/xilinx-versal/include/bsp.h b/bsps/aarch64/xilinx-versal/include/bsp.h
index 0bd93f28bc..5b01637786 100644
--- a/bsps/aarch64/xilinx-versal/include/bsp.h
+++ b/bsps/aarch64/xilinx-versal/include/bsp.h
@@ -79,6 +79,10 @@ BSP_START_TEXT_SECTION void versal_setup_mmu_and_cache(void);
void versal_debug_console_flush(void);
+uint32_t versal_clock_i2c0(void);
+uint32_t versal_clock_i2c1(void);
#ifdef __cplusplus
#endif /* __cplusplus */
diff --git a/bsps/aarch64/xilinx-versal/include/bsp/i2c.h b/bsps/aarch64/xilinx-versal/include/bsp/i2c.h
new file mode 100644
index 0000000000..e76ae6cc9a
--- /dev/null
+++ b/bsps/aarch64/xilinx-versal/include/bsp/i2c.h
@@ -0,0 +1,64 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2022 Chris Johns <chris at contemporary.software>
+ * Copyright (C) 2014 embedded brains GmbH
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifndef LIBBSP_ARM_XILINX_VERSAL_I2C_H
+#define LIBBSP_ARM_XILINX_VERSAL_I2C_H
+#include <dev/i2c/cadence-i2c.h>
+#include <bsp/irq.h>
+#include <bsp.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+static inline int versal_register_i2c_0(void)
+ return i2c_bus_register_cadence(
+ "/dev/i2c-0",
+ 0x00FF020000,
+ versal_clock_i2c0(),
+ VERSAL_IRQ_I2C_0
+static inline int versal_register_i2c_1(void)
+ "/dev/i2c-1",
+ 0x00FF030000,
+ versal_clock_i2c1(),
+ VERSAL_IRQ_I2C_1
+#ifdef __cplusplus
+#endif /* LIBBSP_ARM_XILINX_VERSAL_I2C_H */
diff --git a/bsps/aarch64/xilinx-versal/include/bsp/irq.h b/bsps/aarch64/xilinx-versal/include/bsp/irq.h
index c5f199a9ae..b34bdfd345 100644
--- a/bsps/aarch64/xilinx-versal/include/bsp/irq.h
+++ b/bsps/aarch64/xilinx-versal/include/bsp/irq.h
@@ -53,6 +53,8 @@ extern "C" {
#define BSP_TIMER_VIRT_PPI 27
#define BSP_TIMER_PHYS_S_PPI 29
#define BSP_TIMER_PHYS_NS_PPI 30
+#define VERSAL_IRQ_I2C_0 46
+#define VERSAL_IRQ_I2C_1 47
#define VERSAL_IRQ_UART_0 50
#define VERSAL_IRQ_UART_1 51
#define VERSAL_IRQ_ETHERNET_0 88
diff --git a/bsps/aarch64/xilinx-versal/start/bspstart.c b/bsps/aarch64/xilinx-versal/start/bspstart.c
index 2f0048ddf3..89b06a0ff4 100644
--- a/bsps/aarch64/xilinx-versal/start/bspstart.c
+++ b/bsps/aarch64/xilinx-versal/start/bspstart.c
@@ -38,6 +38,18 @@
#include <bsp/irq-generic.h>
#include <bsp/linker-symbols.h>
+#include <rtems/score/basedefs.h>
+RTEMS_WEAK uint32_t versal_clock_i2c0(void)
+ return VERSAL_CLOCK_I2C0;
+RTEMS_WEAK uint32_t versal_clock_i2c1(void)
+ return VERSAL_CLOCK_I2C1;
void bsp_start( void )
bsp_interrupt_initialize();
diff --git a/spec/build/bsps/aarch64/xilinx-versal/grp.yml b/spec/build/bsps/aarch64/xilinx-versal/grp.yml
index 27a77e9e6f..262278f214 100644
--- a/spec/build/bsps/aarch64/xilinx-versal/grp.yml
+++ b/spec/build/bsps/aarch64/xilinx-versal/grp.yml
@@ -32,6 +32,10 @@ links:
uid: optramlen
- role: build-dependency
uid: optramori
+- role: build-dependency
+ uid: optclki2c0
+ uid: optclki2c1
uid: optclkuart
diff --git a/spec/build/bsps/aarch64/xilinx-versal/grp_aiedge.yml b/spec/build/bsps/aarch64/xilinx-versal/grp_aiedge.yml
index 680584f36c..30f5852ac4 100644
--- a/spec/build/bsps/aarch64/xilinx-versal/grp_aiedge.yml
+++ b/spec/build/bsps/aarch64/xilinx-versal/grp_aiedge.yml
@@ -12,6 +12,8 @@ ldflags: []
links:
uid: grp
+ uid: objcadencei2c
uid: tstaiedge
type: build
diff --git a/spec/build/bsps/aarch64/xilinx-versal/grp_vck190.yml b/spec/build/bsps/aarch64/xilinx-versal/grp_vck190.yml
index 661a528038..2f9662c597 100644
--- a/spec/build/bsps/aarch64/xilinx-versal/grp_vck190.yml
+++ b/spec/build/bsps/aarch64/xilinx-versal/grp_vck190.yml
links:
uid: grp
uid: tstvck190
type: build
diff --git a/spec/build/bsps/aarch64/xilinx-versal/objcadencei2c.yml b/spec/build/bsps/aarch64/xilinx-versal/objcadencei2c.yml
index 0000000000..f290d433e7
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-versal/objcadencei2c.yml
@@ -0,0 +1,21 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: objects
+cflags: []
+copyrights:
+- Copyright (C) 2021 On-Line Applications Research (OAR)
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+install:
+- destination: ${BSP_INCLUDEDIR}/bsp
+ source:
+ - bsps/aarch64/xilinx-versal/include/bsp/i2c.h
+- destination: ${BSP_INCLUDEDIR}/dev/i2c
+ source:
+ - bsps/include/dev/i2c/cadence-i2c-regs.h
+ - bsps/include/dev/i2c/cadence-i2c.h
+links: []
+source:
+- bsps/shared/dev/i2c/cadence-i2c.c
+type: build
diff --git a/spec/build/bsps/aarch64/xilinx-versal/optclki2c0.yml b/spec/build/bsps/aarch64/xilinx-versal/optclki2c0.yml
index 0000000000..3d567c961c
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-versal/optclki2c0.yml
@@ -0,0 +1,17 @@
+actions:
+- get-integer: null
+- define: null
+build-type: option
+copyrights:
+- Copyright (C) 2022 Chris Johns <chris at contemporary.software>
+default: 99999001
+default-by-variant: []
+description: |
+ Versal i2c0 clock frequency in Hz. This is the frequency after the signal
+ has been processed using the values passed to the I2C0_REF_CTRL register.
+enabled-by: true
+format: '{}'
+links: []
+name: VERSAL_CLOCK_I2C0
+type: build
diff --git a/spec/build/bsps/aarch64/xilinx-versal/optclki2c1.yml b/spec/build/bsps/aarch64/xilinx-versal/optclki2c1.yml
index 0000000000..4f67f3ee95
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-versal/optclki2c1.yml
@@ -0,0 +1,17 @@
+actions:
+- define: null
+build-type: option
+copyrights:
+default: 99999001
+description: |
+ Versal i2c1 clock frequency in Hz. This is the frequency after the signal
+ has been processed using the values passed to the I2C1_REF_CTRL register.
+enabled-by: true
+format: '{}'
+links: []
+name: VERSAL_CLOCK_I2C1
+type: build
2.19.1
