[PATCH] bsps/xilinx/versal: Add Cadence I2C driver support
    Kinsey Moore
    kinsey.moore at oarcorp.com
    Wed Aug 24 15:50:12 UTC 2022
This looks good to me.
Kinsey
On 8/24/2022 02:19, chrisj at rtems.org wrote:
> From: Chris Johns <chrisj at rtems.org>
>   bsps/aarch64/xilinx-versal/include/bsp.h      |  4 ++
>   bsps/aarch64/xilinx-versal/include/bsp/i2c.h  | 64 +++++++++++++++++++
>   bsps/aarch64/xilinx-versal/include/bsp/irq.h  |  2 +
>   bsps/aarch64/xilinx-versal/start/bspstart.c   | 12 ++++
>   spec/build/bsps/aarch64/xilinx-versal/grp.yml |  4 ++
>   .../bsps/aarch64/xilinx-versal/grp_aiedge.yml |  2 +
>   .../bsps/aarch64/xilinx-versal/grp_vck190.yml |  2 +
>   .../aarch64/xilinx-versal/objcadencei2c.yml   | 21 ++++++
>   .../bsps/aarch64/xilinx-versal/optclki2c0.yml | 17 +++++
>   .../bsps/aarch64/xilinx-versal/optclki2c1.yml | 17 +++++
>   10 files changed, 145 insertions(+)
>   create mode 100644 bsps/aarch64/xilinx-versal/include/bsp/i2c.h
>   create mode 100644 spec/build/bsps/aarch64/xilinx-versal/objcadencei2c.yml
>   create mode 100644 spec/build/bsps/aarch64/xilinx-versal/optclki2c0.yml
>   create mode 100644 spec/build/bsps/aarch64/xilinx-versal/optclki2c1.yml
> diff --git a/bsps/aarch64/xilinx-versal/include/bsp.h b/bsps/aarch64/xilinx-versal/include/bsp.h
> index 0bd93f28bc..5b01637786 100644
> --- a/bsps/aarch64/xilinx-versal/include/bsp.h
> +++ b/bsps/aarch64/xilinx-versal/include/bsp.h
> @@ -79,6 +79,10 @@ BSP_START_TEXT_SECTION void versal_setup_mmu_and_cache(void);
>   void versal_debug_console_flush(void);
> +uint32_t versal_clock_i2c0(void);
> +uint32_t versal_clock_i2c1(void);
>   #ifdef __cplusplus
>   #endif /* __cplusplus */
> diff --git a/bsps/aarch64/xilinx-versal/include/bsp/i2c.h b/bsps/aarch64/xilinx-versal/include/bsp/i2c.h
> new file mode 100644
> index 0000000000..e76ae6cc9a
> --- /dev/null
> +++ b/bsps/aarch64/xilinx-versal/include/bsp/i2c.h
> @@ -0,0 +1,64 @@
> + * SPDX-License-Identifier: BSD-2-Clause
> + * Copyright (C) 2022 Chris Johns <chris at contemporary.software>
> + * Copyright (C) 2014 embedded brains GmbH
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#ifndef LIBBSP_ARM_XILINX_VERSAL_I2C_H
> +#define LIBBSP_ARM_XILINX_VERSAL_I2C_H
> +#include <dev/i2c/cadence-i2c.h>
> +#include <bsp/irq.h>
> +#include <bsp.h>
> +#ifdef __cplusplus
> +extern "C" {
> +#endif /* __cplusplus */
> +static inline int versal_register_i2c_0(void)
> +  return i2c_bus_register_cadence(
> +    "/dev/i2c-0",
> +    0x00FF020000,
> +    versal_clock_i2c0(),
> +    VERSAL_IRQ_I2C_0
> +static inline int versal_register_i2c_1(void)
> +    "/dev/i2c-1",
> +    0x00FF030000,
> +    versal_clock_i2c1(),
> +    VERSAL_IRQ_I2C_1
> +#ifdef __cplusplus
> +#endif /* LIBBSP_ARM_XILINX_VERSAL_I2C_H */
> diff --git a/bsps/aarch64/xilinx-versal/include/bsp/irq.h b/bsps/aarch64/xilinx-versal/include/bsp/irq.h
> index c5f199a9ae..b34bdfd345 100644
> --- a/bsps/aarch64/xilinx-versal/include/bsp/irq.h
> +++ b/bsps/aarch64/xilinx-versal/include/bsp/irq.h
> @@ -53,6 +53,8 @@ extern "C" {
>   #define BSP_TIMER_VIRT_PPI 27
>   #define BSP_TIMER_PHYS_S_PPI 29
>   #define BSP_TIMER_PHYS_NS_PPI 30
> +#define VERSAL_IRQ_I2C_0 46
> +#define VERSAL_IRQ_I2C_1 47
>   #define VERSAL_IRQ_UART_0 50
>   #define VERSAL_IRQ_UART_1 51
>   #define VERSAL_IRQ_ETHERNET_0 88
> diff --git a/bsps/aarch64/xilinx-versal/start/bspstart.c b/bsps/aarch64/xilinx-versal/start/bspstart.c
> index 2f0048ddf3..89b06a0ff4 100644
> --- a/bsps/aarch64/xilinx-versal/start/bspstart.c
> +++ b/bsps/aarch64/xilinx-versal/start/bspstart.c
> @@ -38,6 +38,18 @@
>   #include <bsp/irq-generic.h>
>   #include <bsp/linker-symbols.h>
> +#include <rtems/score/basedefs.h>
> +RTEMS_WEAK uint32_t versal_clock_i2c0(void)
> +  return VERSAL_CLOCK_I2C0;
> +RTEMS_WEAK uint32_t versal_clock_i2c1(void)
> +  return VERSAL_CLOCK_I2C1;
>   void bsp_start( void )
>     bsp_interrupt_initialize();
> diff --git a/spec/build/bsps/aarch64/xilinx-versal/grp.yml b/spec/build/bsps/aarch64/xilinx-versal/grp.yml
> index 27a77e9e6f..262278f214 100644
> --- a/spec/build/bsps/aarch64/xilinx-versal/grp.yml
> +++ b/spec/build/bsps/aarch64/xilinx-versal/grp.yml
> @@ -32,6 +32,10 @@ links:
>     uid: optramlen
>   - role: build-dependency
>     uid: optramori
> +- role: build-dependency
> +  uid: optclki2c0
> +  uid: optclki2c1
>     uid: optclkuart
> diff --git a/spec/build/bsps/aarch64/xilinx-versal/grp_aiedge.yml b/spec/build/bsps/aarch64/xilinx-versal/grp_aiedge.yml
> index 680584f36c..30f5852ac4 100644
> --- a/spec/build/bsps/aarch64/xilinx-versal/grp_aiedge.yml
> +++ b/spec/build/bsps/aarch64/xilinx-versal/grp_aiedge.yml
> @@ -12,6 +12,8 @@ ldflags: []
>   links:
>     uid: grp
> +  uid: objcadencei2c
>     uid: tstaiedge
>   type: build
> diff --git a/spec/build/bsps/aarch64/xilinx-versal/grp_vck190.yml b/spec/build/bsps/aarch64/xilinx-versal/grp_vck190.yml
> index 661a528038..2f9662c597 100644
> --- a/spec/build/bsps/aarch64/xilinx-versal/grp_vck190.yml
> +++ b/spec/build/bsps/aarch64/xilinx-versal/grp_vck190.yml
>   links:
>     uid: grp
>     uid: tstvck190
>   type: build
> diff --git a/spec/build/bsps/aarch64/xilinx-versal/objcadencei2c.yml b/spec/build/bsps/aarch64/xilinx-versal/objcadencei2c.yml
> index 0000000000..f290d433e7
> --- /dev/null
> +++ b/spec/build/bsps/aarch64/xilinx-versal/objcadencei2c.yml
> @@ -0,0 +1,21 @@
> +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> +build-type: objects
> +cflags: []
> +copyrights:
> +- Copyright (C) 2021 On-Line Applications Research (OAR)
> +cppflags: []
> +cxxflags: []
> +enabled-by: true
> +includes: []
> +install:
> +- destination: ${BSP_INCLUDEDIR}/bsp
> +  source:
> +  - bsps/aarch64/xilinx-versal/include/bsp/i2c.h
> +- destination: ${BSP_INCLUDEDIR}/dev/i2c
> +  source:
> +  - bsps/include/dev/i2c/cadence-i2c-regs.h
> +  - bsps/include/dev/i2c/cadence-i2c.h
> +links: []
> +source:
> +- bsps/shared/dev/i2c/cadence-i2c.c
> +type: build
> diff --git a/spec/build/bsps/aarch64/xilinx-versal/optclki2c0.yml b/spec/build/bsps/aarch64/xilinx-versal/optclki2c0.yml
> index 0000000000..3d567c961c
> --- /dev/null
> +++ b/spec/build/bsps/aarch64/xilinx-versal/optclki2c0.yml
> @@ -0,0 +1,17 @@
> +actions:
> +- get-integer: null
> +- define: null
> +build-type: option
> +copyrights:
> +- Copyright (C) 2022 Chris Johns <chris at contemporary.software>
> +default: 99999001
> +default-by-variant: []
> +description: |
> +  Versal i2c0 clock frequency in Hz. This is the frequency after the signal
> +  has been processed using the values passed to the I2C0_REF_CTRL register.
> +enabled-by: true
> +format: '{}'
> +links: []
> +name: VERSAL_CLOCK_I2C0
> +type: build
> diff --git a/spec/build/bsps/aarch64/xilinx-versal/optclki2c1.yml b/spec/build/bsps/aarch64/xilinx-versal/optclki2c1.yml
> index 0000000000..4f67f3ee95
> --- /dev/null
> +++ b/spec/build/bsps/aarch64/xilinx-versal/optclki2c1.yml
> @@ -0,0 +1,17 @@
> +actions:
> +- define: null
> +build-type: option
> +copyrights:
> +default: 99999001
> +description: |
> +  Versal i2c1 clock frequency in Hz. This is the frequency after the signal
> +  has been processed using the values passed to the I2C1_REF_CTRL register.
> +enabled-by: true
> +format: '{}'
> +links: []
> +name: VERSAL_CLOCK_I2C1
> +type: build
