[PATCH RTEMS] Add i2c command
Christian MAUDERER
christian.mauderer at embedded-brains.de
Thu Aug 25 07:17:09 UTC 2022
Am 25.08.22 um 07:45 schrieb chrisj at rtems.org:
> The patch adds the i2c command. It is a single command to test and
> explore I2C buses on hardware. The command lets you string together
> reads and writes on a single command line to access a number of devices
> so you can script basic functionality simply.
> This ocommand adds to the existing i2cdetect, i2cset and i2cget however
> those commands did not work cleanly on the vck-190 or did not read and
> write directly at the bus level.
> Chris
Hello Chris,
like said on Discord: Thanks for adding that tool. It has nearly all and
a lot more functionallity than the i2cset, i2cget and i2cdetect that I
added a while back. Only thing missing is the functionallity to scan the
bus using zero length writes like the current i2cdetect does.
For reference I copied the discord thread to the mail below like we
agreed so that it is archived. I hope the line breaks added by the
mailing list system doesn't make it too unreadable.
Best regards
Christian
7:02 AM] kiwichris: I am adding a new command to RTEMS: i2c
vck190 [/] # i2c help
Usage:: i2c <command> ...
where <command> is:
help : this help
det <-b bus> : detect devices on bus(es)
rd <-8> <-16> bus:addr len : read of data from slave
wr <-8> <-16> bus:addr data.. : write of data to slave
rda bus:addr addr len : write address then read data from slave
wra bus:addr addr data.. : write address then write data to slave
bus:addr: decimal bus number and hex address, eg 0:74
data: even length hex data string, eg 001122334455
vck190 [/] # i2c det
0 20 74
1 74 75
vck190 [/] # i2c wr 0:74 01
0 0c 16 17 1c 1d 1e 1f 20 46 47 4c 4d 4e 4f 50 74
1 74 75
vck190 [/] # i2c wr 1:74 01
1 52 54 5d 74 75
The test detects the available devices and them selects channel 1 on the
8 channel I2C multiplexer on bus-0 followed by a detect. This is
repeated on bus-1.
[8:12 AM] c-mauderer: You are aware of the i2cdetect i2cget and i2cset
that I added a bit back?
https://docs.rtems.org/branches/master/shell/general_commands.html#i2cdetect
[8:13 AM] c-mauderer: The interface is similar to the commands from
Linux i2c tools.
[8:13 AM] c-mauderer: I think it would cover the det, rda and wra of
your command.
[8:14 AM] c-mauderer: I don't have a problem if you want to replace my
commands. But I don't think that we should have both.
[8:15 AM] c-mauderer: Except if there is a relevant difference
[8:16 AM] kiwichris: It did not work on the versal.
[8:16 AM] kiwichris: Also I did not know they existed before I did these.
[8:17 AM] kiwichris:
vck190 [/] # i2cdetect /dev/i2c-0
x0 x1 x2 x3 x4 x5 x6 x7 x8 x9 xA xB xC xD xE xF
0x -- -- -- -- -- -- -- -- -- -- --ioctl failed: Connection timed out
1x -- -- -- -- -- --ioctl failed: Connection timed out
2x ioctl failed: Connection timed out
3x -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
4x -- -- -- -- -- --ioctl failed: Connection timed out
5x ioctl failed: Connection timed out
6x -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
7x -- -- -- --ioctl failed: Connection timed out
[8:18 AM] kiwichris: Yes I saw it was like the i2c-tools command but
they also do some strange things on the bus.
[8:18 AM] kiwichris: I am fine if they all exists if there are needs. My
concern fixing or playing with the those commands was them then not
working for some
[8:19 AM] c-mauderer: The connection timeout is normally a problem with
the driver. The detect only addresses a device without data.
[8:19 AM] c-mauderer: That's an edge case that isn't handled in every
driver.
[8:20 AM] kiwichris: It is not a problem with the detect I have and no
timeouts. Also writing breaks multiplexers which the vck-190 has
[8:20 AM] c-mauderer: How did you implement the detect?
[8:21 AM] kiwichris: The Linux i2c-tool has some selected groups of
addresses it does different things, ie to handle write-only devices but
I do not like that.
[8:21 AM] kiwichris: The driver is the cadence one and it is the same
the zynqmp hardware and it seems to be working as expected.
[8:22 AM] kiwichris: From the patch 🙂 ...
+ for (addr = MIN_ADDR; addr <= MAX_ADDR; ++addr) {
+ if (!i2c_set_slave(i2c, bus, addr, false)) {
+ state[addr] = 'E';
+ } else {
+ uint8_t buf;
+ ssize_t r = read(i2c->bus[bus], &buf, 1);
+ if (r == 1) {
+ state[addr] = 'X';
+ } else {
+ buf = I2C_SMBUS_WRITE;
+ ssize_t r = write(i2c->bus[bus], &buf, 1);
+ if (r == 1) {
[8:23 AM] kiwichris: It is finding all the devices and also the ones on
the multiplexed bus when it is switched
[8:25 AM] c-mauderer: But that means that an actual read access of one
byte is done to the device.
[8:26 AM] c-mauderer: Can mess up some status registers or other stuff.
[8:27 AM] kiwichris: Yes but it is a detect and not designed for live
probing for production.
[8:27 AM] c-mauderer: Hm. You should add at least a big warning about that.
[8:28 AM] c-mauderer: And I still think that it's a driver problem that
the i2cprobe doesn't work.
[8:29 AM] kiwichris: I am not sure issuing a start and no length is fine
for all devices. Linux does the read or write but yes the doco can
explain it.
[8:30 AM] c-mauderer: Yes, it's also not ideal for all devices. But it's
at least tested for a lot of devices that connect to Linux systems 😉
[8:30 AM] kiwichris: But Linux reads a byte?
[8:31 AM] c-mauderer: No. The Linux i2c-tools only address the devices.
[8:31 AM] c-mauderer: If an ACK is seen on the address, the device is there.
[8:32 AM] c-mauderer: It's also a nice test case for the drivers. Most
of the time it's more or less a bug that the driver doesn't support a
read / write with length 0.
[8:33 AM] kiwichris: Hmm the code I looked at did a i2c_smbus_read_byte
[8:33 AM] kiwichris: It could be the wrong code
[8:33 AM] c-mauderer:
https://git.rtems.org/rtems/tree/cpukit/libmisc/shell/main_i2cdetect.c#n46
[8:34 AM] kiwichris:
https://sources.debian.org/src/i2c-tools/4.3-2/tools/i2cdetect.c/#L105
[8:34 AM] c-mauderer: Ah, you mean the Linux code. Give me a moment. It
has been a while since I worked through that.
[8:35 AM] kiwichris: Yeah I do and that is what I said. They do have
lots of devices connected 🙂 🙂
[8:37 AM] kiwichris: The driver could have issues as you say but as it
is I can access the devices I need too
[8:43 AM] c-mauderer: Ah, yes: The read mode is only if you use a
special "-r" option. The default case is the i2c_smbus_write_quick()
which basically does exactly what I did in i2cdetect: Cause a write
addressing of a device with zero length and take a look whether the
device responds.
[8:44 AM] kiwichris: Thanks, I did not have the time to look deeper.
Interesting name for a write_quick when it is a null write.
[8:47 AM] kiwichris: I will raise the driver question with @opticron
tomorrow to see what he gets on the ZynqMP
[8:47 AM] c-mauderer: Yes, it uses this odd I2C_SMBUS_QUICK define that
is in the Linux i2c header:
https://git.kernel.org/pub/scm/utils/i2c-tools/i2c-tools.git/tree/lib/smbus.c#n30
[8:47 AM] c-mauderer: The define is just 0. We also have it in our i2c.h
[8:48 AM] c-mauderer:
https://git.rtems.org/rtems/tree/cpukit/include/linux/i2c.h#n266
[8:48 AM] kiwichris: Understood.
[8:49 AM] c-mauderer: Like I said: I don't have a problem if you want to
replace the i2cdetect. It was a very quick hacked together tool. I know
that I analyzed I2C tools back then already to see how they do the
detection. But I think we should support that "write zero bytes" method too.
[8:49 AM] c-mauderer: Like I said: Has been useful for me in the past to
detect driver bugs.
[8:50 AM] kiwichris: Yes I agree the 0 method is one that should be
there and maybe with the read as well. I need to do things like wr 0:74
01 wra 0:45 2 aa wra 0:45 3 55 etc
[8:51 AM] kiwichris: Where 74 is a selector and then a few writes
[8:52 AM] kiwichris: I can add the zero wait as a v2 change if the
change is something we want to add into RTEMS. Pretty relaxed about it.
[9:03 AM] c-mauderer: Regarding the I2C addresses: Do I see it correctly
that you allow addresses from 0 to 255 for 8 bit addresses. So that
would include the I2C read/write bit? So an address of 0x04 and 0x05
would address the same device but one time in read and one time in write
mode?
[9:04 AM] c-mauderer: ah, sorry. That is for the address for eeprom like
devices.
[9:04 AM] c-mauderer: Missed that.
[9:04 AM] kiwichris: Ah yes it was 127 as I knew that then changed it. I
also need to add ten bit address support
[9:05 AM] kiwichris: I have 8 or 16 addresses. I am actually not sure
the 16bit is byte ordered in the buffer the right way.
[9:06 AM] kiwichris: I would like to support ten bit addressing. This is
for drivers like the AXI I2C IP from Xilinx that have output ports the
driver can access for multiplexing
[9:07 AM] c-mauderer: All in all: Sounds like a great tool. That can do
quite a lot more than my i2c* commands and I think it should replace
them. Currently the only thing that I found missing is the detect using
a zero-length-write like discussed. Otherwise I think it can do more.
Thanks for adding that new tool.
[9:08 AM] kiwichris: Yes if it is going to replace those commands (which
I found after I had done this) it must cover what they do.
[9:09 AM] kiwichris: It is great being here to discuss this here and
sort if out. Way faster 🙂 So a big thanks
[9:09 AM] c-mauderer: Yes. Discord is great for discussions. I'm only
missing a public archive.
[9:09 AM] kiwichris: Yeap I agree.
[9:09 AM] c-mauderer: Should we copy the discussion into a mail and send
it as response to the patch?
[9:10 AM] kiwichris: Good idea 🙂
[9:10 AM] c-mauderer: OK. I'll send a mail.
embedded brains GmbH
Herr Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 18
mobile: +49-176-152 206 08
Registernummer: HRB 157899
