[PATCH v5 0/1] NOEL-V BSP
Daniel Cederman cederman at gaisler.com
Thu Aug 25 08:33:21 UTC 2022
v5
Made RISCV_CONSOLE_MAX_APBUART_DEVICES an option
bsp_fatal if no uart clock frequency is found
Changed CONSOLE_USE_INTERRUPTS to BSP_CONSOLE_USE_INTERRUPTS
Added error codes for APBUART
Get work area size from /memory node
Martin Aberg (1):
  bsp/riscv: Add NOEL-V BSP
 bsps/include/bsp/fatal.h                      |   3 +
 bsps/riscv/noel/console/console-config.c      | 208 ++++++++++++++++++
 bsps/riscv/noel/include/bsp.h                 |  76 +++++++
 bsps/riscv/noel/include/bsp/irq.h             |  75 +++++++
 bsps/riscv/noel/include/tm27.h                |   1 +
 bsps/riscv/noel/start/bsp_fatal_halt.c        |  46 ++++
 bsps/riscv/riscv/include/bsp.h                |   2 +
 bsps/riscv/riscv/include/bsp/irq.h            |   2 +
 spec/build/bsps/riscv/noel/abi.yml            |  48 ++++
 spec/build/bsps/riscv/noel/bspnoel32im.yml    |  19 ++
 spec/build/bsps/riscv/noel/bspnoel32imafd.yml |  19 ++
 spec/build/bsps/riscv/noel/bspnoel64imac.yml  |  19 ++
 spec/build/bsps/riscv/noel/bspnoel64imafd.yml |  19 ++
 .../build/bsps/riscv/noel/bspnoel64imafdc.yml |  19 ++
 spec/build/bsps/riscv/noel/grp.yml            |  61 +++++
 spec/build/bsps/riscv/noel/obj.yml            |  38 ++++
 spec/build/bsps/riscv/noel/objsmp.yml         |  15 ++
 spec/build/bsps/riscv/noel/optapbuartmax.yml  |  16 ++
 spec/build/bsps/riscv/optrambegin.yml         |   3 +
 spec/build/cpukit/optarchbits.yml             |   2 +
 spec/build/cpukit/optsmp.yml                  |   4 +
 21 files changed, 695 insertions(+)
 create mode 100644 bsps/riscv/noel/console/console-config.c
 create mode 100644 bsps/riscv/noel/include/bsp.h
 create mode 100644 bsps/riscv/noel/include/bsp/irq.h
 create mode 100644 bsps/riscv/noel/include/tm27.h
 create mode 100644 bsps/riscv/noel/start/bsp_fatal_halt.c
 create mode 100644 spec/build/bsps/riscv/noel/abi.yml
 create mode 100644 spec/build/bsps/riscv/noel/bspnoel32im.yml
 create mode 100644 spec/build/bsps/riscv/noel/bspnoel32imafd.yml
 create mode 100644 spec/build/bsps/riscv/noel/bspnoel64imac.yml
 create mode 100644 spec/build/bsps/riscv/noel/bspnoel64imafd.yml
 create mode 100644 spec/build/bsps/riscv/noel/bspnoel64imafdc.yml
 create mode 100644 spec/build/bsps/riscv/noel/grp.yml
 create mode 100644 spec/build/bsps/riscv/noel/obj.yml
 create mode 100644 spec/build/bsps/riscv/noel/objsmp.yml
 create mode 100644 spec/build/bsps/riscv/noel/optapbuartmax.yml
2.34.1
