Weird Cygwin Build Failure
Fri Aug 26 14:13:22 UTC 2022
Hi
https://lists.rtems.org/pipermail/build/2022-August/035493.html -- m68k on
Cygwin fails with this weird error.
rm gcc.pod
make[2]: Leaving directory
'/home/rtems-tester/rtems-cron-5/rtems-source-builder/rtems/build/m68k-rtems5-gcc-7.5.0-newlib-7947581-x86_64-pc-cygwin-1/build/gcc'
make[2]: write error: stdout
make[1]: *** [Makefile:4238: all-gcc] Error 1
make[1]: Leaving directory
'/home/rtems-tester/rtems-cron-5/rtems-source-builder/rtems/build/m68k-rtems5-gcc-7.5.0-newlib-7947581-x86_64-pc-cygwin-1/build'
make: *** [Makefile:903: all] Error 2
shell cmd failed: sh -ex
/home/rtems-tester/rtems-cron-5/rtems-source-builder/rtems/build/m68k-rtems5-gcc-7.5.0-newlib-7947581-x86_64-pc-cygwin-1/do-build
error: building m68k-rtems5-gcc-7.5.0-newlib-7947581-x86_64-pc-cygwin-1
  See error report:
rsb-report-m68k-rtems5-gcc-7.5.0-newlib-7947581-x86_64-pc-cygwin-1.txt
At least the arm fails with this also. Any ideas?
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220826/4f53a18f/attachment.htm>
