Weird Cygwin Build Failure
Sat Aug 27 01:13:54 UTC 2022
On 27/8/2022 12:13 am, Joel Sherrill wrote:
> Hi
> https://lists.rtems.org/pipermail/build/2022-August/035493.html
> <https://lists.rtems.org/pipermail/build/2022-August/035493.html> -- m68k on
> Cygwin fails with this weird error.
> rm gcc.pod
> make[2]: Leaving directory '/home/rtems-tester/rtems-cron-5/rtems-source-builder/rtems/build/m68k-rtems5-gcc-7.5.0-newlib-7947581-x86_64-pc-cygwin-1/build/gcc'
> make[2]: write error: stdout
> make[1]: *** [Makefile:4238: all-gcc] Error 1
> make[1]: Leaving directory '/home/rtems-tester/rtems-cron-5/rtems-source-builder/rtems/build/m68k-rtems5-gcc-7.5.0-newlib-7947581-x86_64-pc-cygwin-1/build'
> make: *** [Makefile:903: all] Error 2
> shell cmd failed: sh -ex  /home/rtems-tester/rtems-cron-5/rtems-source-builder/rtems/build/m68k-rtems5-gcc-7.5.0-newlib-7947581-x86_64-pc-cygwin-1/do-build
> error: building m68k-rtems5-gcc-7.5.0-newlib-7947581-x86_64-pc-cygwin-1
>   See error report: rsb-report-m68k-rtems5-gcc-7.5.0-newlib-7947581-x86_64-pc-cygwin-1.txt
> At least the arm fails with this also. Any ideas?
Do the RTEMS 6 tools build?
