Weird Cygwin Build Failure
Sat Aug 27 01:15:28 UTC 2022
On Fri, Aug 26, 2022, 8:14 PM Chris Johns <chrisj at rtems.org> wrote:
> On 27/8/2022 12:13 am, Joel Sherrill wrote:
> > Hi
> > https://lists.rtems.org/pipermail/build/2022-August/035493.html
> > <https://lists.rtems.org/pipermail/build/2022-August/035493.html> --
> m68k on
> > Cygwin fails with this weird error.
> > rm gcc.pod
> > make[2]: Leaving directory
> '/home/rtems-tester/rtems-cron-5/rtems-source-builder/rtems/build/m68k-rtems5-gcc-7.5.0-newlib-7947581-x86_64-pc-cygwin-1/build/gcc'
> > make[2]: write error: stdout
> > make[1]: *** [Makefile:4238: all-gcc] Error 1
> > make[1]: Leaving directory
> '/home/rtems-tester/rtems-cron-5/rtems-source-builder/rtems/build/m68k-rtems5-gcc-7.5.0-newlib-7947581-x86_64-pc-cygwin-1/build'
> > make: *** [Makefile:903: all] Error 2
> > shell cmd failed: sh -ex
> /home/rtems-tester/rtems-cron-5/rtems-source-builder/rtems/build/m68k-rtems5-gcc-7.5.0-newlib-7947581-x86_64-pc-cygwin-1/do-build
> > error: building m68k-rtems5-gcc-7.5.0-newlib-7947581-x86_64-pc-cygwin-1
> >   See error report:
> rsb-report-m68k-rtems5-gcc-7.5.0-newlib-7947581-x86_64-pc-cygwin-1.txt
> > At least the arm fails with this also. Any ideas?
> Do the RTEMS 6 tools build?
That would be in the build list archive. But I doubt it .. at least
reliably. It seems like a cygwin fault
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220826/f07cd8a9/attachment.htm>
