[rtems commit] schedulerpriority.h: Fix gcc 12 warning
Mon Aug 29 07:41:07 UTC 2022
On 29/08/2022 09:30, Chris Johns wrote:
> On 29/8/22 5:07 pm, Sebastian Huber wrote:
>> On 19/08/2022 22:46, Joel Sherrill wrote:
>>> Module:    rtems
>>> Branch:    master
>>> Commit:    5b875915152a248079855bcb98e871f70ac314cc
>>> Changeset:
>>> http://git.rtems.org/rtems/commit/?id=5b875915152a248079855bcb98e871f70ac314cc
>>> Author:    Ryan Long<ryan.long at oarcorp.com>
>>> Date:      Tue Aug 16 12:00:26 2022 -0500
>>> Changed the size of the array to 1 to get rid of the warning.
>>> Updates #4662
>>>    cpukit/include/rtems/score/schedulerpriority.h | 2 +-
>>>    1 file changed, 1 insertion(+), 1 deletion(-)
>>> diff --git a/cpukit/include/rtems/score/schedulerpriority.h
>>> b/cpukit/include/rtems/score/schedulerpriority.h
>>> index cf5d0762a9..e485e97c60 100644
>>> --- a/cpukit/include/rtems/score/schedulerpriority.h
>>> +++ b/cpukit/include/rtems/score/schedulerpriority.h
>>> @@ -94,7 +94,7 @@ typedef struct {
>>>       * @brief One ready queue per priority level.
>>> -  Chain_Control Ready[ 0 ];
>>> +  Chain_Control Ready[ 1 ];
>>>    } Scheduler_priority_Context;
>> Increasing the storage size to fix a warning is the wrong approach.  The warning
>> should be suppressed in the application configuration header or the
>> configuration should be changed to account for the new chain control.
> Why do you say this is right or a better approach?
A warning fix should not increase the storage size on the target. The
Ready member is a flexible array those size is defined by the
application configuration. This approach is used in several places. The
declaration should be actually:
Chain_Control Ready[ RTEMS_ZERO_LENGTH_ARRAY ];
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
