[PATCH v5 0/1] NOEL-V BSP
Daniel Cederman cederman at gaisler.com
Tue Aug 30 11:39:08 UTC 2022
Hi,
Is it OK to push this or should I wait for additional comments?
On 2022-08-25 10:33, Daniel Cederman wrote:
> v5
> Made RISCV_CONSOLE_MAX_APBUART_DEVICES an option
> bsp_fatal if no uart clock frequency is found
> Changed CONSOLE_USE_INTERRUPTS to BSP_CONSOLE_USE_INTERRUPTS
> Added error codes for APBUART
> Get work area size from /memory node
> Martin Aberg (1):
>    bsp/riscv: Add NOEL-V BSP
>   bsps/include/bsp/fatal.h                      |   3 +
>   bsps/riscv/noel/console/console-config.c      | 208 ++++++++++++++++++
>   bsps/riscv/noel/include/bsp.h                 |  76 +++++++
>   bsps/riscv/noel/include/bsp/irq.h             |  75 +++++++
>   bsps/riscv/noel/include/tm27.h                |   1 +
>   bsps/riscv/noel/start/bsp_fatal_halt.c        |  46 ++++
>   bsps/riscv/riscv/include/bsp.h                |   2 +
>   bsps/riscv/riscv/include/bsp/irq.h            |   2 +
>   spec/build/bsps/riscv/noel/abi.yml            |  48 ++++
>   spec/build/bsps/riscv/noel/bspnoel32im.yml    |  19 ++
>   spec/build/bsps/riscv/noel/bspnoel32imafd.yml |  19 ++
>   spec/build/bsps/riscv/noel/bspnoel64imac.yml  |  19 ++
>   spec/build/bsps/riscv/noel/bspnoel64imafd.yml |  19 ++
>   .../build/bsps/riscv/noel/bspnoel64imafdc.yml |  19 ++
>   spec/build/bsps/riscv/noel/grp.yml            |  61 +++++
>   spec/build/bsps/riscv/noel/obj.yml            |  38 ++++
>   spec/build/bsps/riscv/noel/objsmp.yml         |  15 ++
>   spec/build/bsps/riscv/noel/optapbuartmax.yml  |  16 ++
>   spec/build/bsps/riscv/optrambegin.yml         |   3 +
>   spec/build/cpukit/optarchbits.yml             |   2 +
>   spec/build/cpukit/optsmp.yml                  |   4 +
>   21 files changed, 695 insertions(+)
>   create mode 100644 bsps/riscv/noel/console/console-config.c
>   create mode 100644 bsps/riscv/noel/include/bsp.h
>   create mode 100644 bsps/riscv/noel/include/bsp/irq.h
>   create mode 100644 bsps/riscv/noel/include/tm27.h
>   create mode 100644 bsps/riscv/noel/start/bsp_fatal_halt.c
>   create mode 100644 spec/build/bsps/riscv/noel/abi.yml
>   create mode 100644 spec/build/bsps/riscv/noel/bspnoel32im.yml
>   create mode 100644 spec/build/bsps/riscv/noel/bspnoel32imafd.yml
>   create mode 100644 spec/build/bsps/riscv/noel/bspnoel64imac.yml
>   create mode 100644 spec/build/bsps/riscv/noel/bspnoel64imafd.yml
>   create mode 100644 spec/build/bsps/riscv/noel/bspnoel64imafdc.yml
>   create mode 100644 spec/build/bsps/riscv/noel/grp.yml
>   create mode 100644 spec/build/bsps/riscv/noel/obj.yml
>   create mode 100644 spec/build/bsps/riscv/noel/objsmp.yml
>   create mode 100644 spec/build/bsps/riscv/noel/optapbuartmax.yml
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220830/fa770b92/attachment.htm>
