[PATCH v5 0/1] NOEL-V BSP
Joel Sherrill
joel at rtems.org
Tue Aug 30 19:10:51 UTC 2022
I think it's OK to push after this long.
Also be sure to add some to the RTEMS Users Guide for this BSP.
Does this work on any simulator?
--joel
On Tue, Aug 30, 2022 at 6:39 AM Daniel Cederman <cederman at gaisler.com>
wrote:
> Hi,
> Is it OK to push this or should I wait for additional comments?
> On 2022-08-25 10:33, Daniel Cederman wrote:
> v5
> Made RISCV_CONSOLE_MAX_APBUART_DEVICES an option
> bsp_fatal if no uart clock frequency is found
> Changed CONSOLE_USE_INTERRUPTS to BSP_CONSOLE_USE_INTERRUPTS
> Added error codes for APBUART
> Get work area size from /memory node
> Martin Aberg (1):
> bsp/riscv: Add NOEL-V BSP
> bsps/include/bsp/fatal.h | 3 +
> bsps/riscv/noel/console/console-config.c | 208 ++++++++++++++++++
> bsps/riscv/noel/include/bsp.h | 76 +++++++
> bsps/riscv/noel/include/bsp/irq.h | 75 +++++++
> bsps/riscv/noel/include/tm27.h | 1 +
> bsps/riscv/noel/start/bsp_fatal_halt.c | 46 ++++
> bsps/riscv/riscv/include/bsp.h | 2 +
> bsps/riscv/riscv/include/bsp/irq.h | 2 +
> spec/build/bsps/riscv/noel/abi.yml | 48 ++++
> spec/build/bsps/riscv/noel/bspnoel32im.yml | 19 ++
> spec/build/bsps/riscv/noel/bspnoel32imafd.yml | 19 ++
> spec/build/bsps/riscv/noel/bspnoel64imac.yml | 19 ++
> spec/build/bsps/riscv/noel/bspnoel64imafd.yml | 19 ++
> .../build/bsps/riscv/noel/bspnoel64imafdc.yml | 19 ++
> spec/build/bsps/riscv/noel/grp.yml | 61 +++++
> spec/build/bsps/riscv/noel/obj.yml | 38 ++++
> spec/build/bsps/riscv/noel/objsmp.yml | 15 ++
> spec/build/bsps/riscv/noel/optapbuartmax.yml | 16 ++
> spec/build/bsps/riscv/optrambegin.yml | 3 +
> spec/build/cpukit/optarchbits.yml | 2 +
> spec/build/cpukit/optsmp.yml | 4 +
> 21 files changed, 695 insertions(+)
> create mode 100644 bsps/riscv/noel/console/console-config.c
> create mode 100644 bsps/riscv/noel/include/bsp.h
> create mode 100644 bsps/riscv/noel/include/bsp/irq.h
> create mode 100644 bsps/riscv/noel/include/tm27.h
> create mode 100644 bsps/riscv/noel/start/bsp_fatal_halt.c
> create mode 100644 spec/build/bsps/riscv/noel/abi.yml
> create mode 100644 spec/build/bsps/riscv/noel/bspnoel32im.yml
> create mode 100644 spec/build/bsps/riscv/noel/bspnoel32imafd.yml
> create mode 100644 spec/build/bsps/riscv/noel/bspnoel64imac.yml
> create mode 100644 spec/build/bsps/riscv/noel/bspnoel64imafd.yml
> create mode 100644 spec/build/bsps/riscv/noel/bspnoel64imafdc.yml
> create mode 100644 spec/build/bsps/riscv/noel/grp.yml
> create mode 100644 spec/build/bsps/riscv/noel/obj.yml
> create mode 100644 spec/build/bsps/riscv/noel/objsmp.yml
> create mode 100644 spec/build/bsps/riscv/noel/optapbuartmax.yml
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220830/e3f46754/attachment.htm>
