[PATCH rtems-lwip] lwip.py: Track includes as lists
Kinsey Moore
kinsey.moore at oarcorp.com
Tue Aug 30 17:21:34 UTC 2022
The original work for rtems-lwip tracked include directories as raw
strings to be passed into the build infrastructure. This reformulates
include directory management as lists to reduce errors in future
changes.
lwip.py | 130 +++++++++++++++++++++++++++++++++-----------------------
1 file changed, 78 insertions(+), 52 deletions(-)
diff --git a/lwip.py b/lwip.py
index 2e12957..84eef2c 100644
--- a/lwip.py
+++ b/lwip.py
@@ -36,52 +36,67 @@ def removeprefix(data, prefix):
return data
-xilinx_lwip_prefix = 'embeddedsw/ThirdParty/sw_services/lwip211/'
-xilinx_drv_incl = ''
-xilinx_drv_incl += xilinx_lwip_prefix + 'src/contrib/ports/xilinx/include '
-xilinx_drv_incl += 'embeddedsw/lib/bsp/standalone/src/common '
-xilinx_drv_incl += 'embeddedsw/XilinxProcessorIPLib/drivers/common/src/ '
-xilinx_drv_incl += 'embeddedsw/XilinxProcessorIPLib/drivers/scugic/src '
-xilinx_drv_incl += 'embeddedsw/XilinxProcessorIPLib/drivers/emacps/src '
-xilinx_drv_incl += 'rtemslwip/xilinx '
-xilinx_aarch64_drv_incl = ''
-xilinx_aarch64_drv_incl += 'rtemslwip/zynqmp '
-xilinx_aarch64_drv_incl += 'embeddedsw/lib/bsp/standalone/src/arm/ARMv8/64bit '
-xilinx_aarch64_drv_incl += 'embeddedsw/lib/bsp/standalone/src/arm/common/gcc '
-xilinx_aarch64_drv_incl += 'embeddedsw/lib/bsp/standalone/src/arm/common '
+xilinx_lwip_prefix = 'embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/'
+xilinx_standalone_prefix = 'embeddedsw/lib/bsp/standalone/src/'
+xilinx_drv_incl = [
+ xilinx_lwip_prefix + 'ports/xilinx/include',
+ xilinx_standalone_prefix + 'common',
+ 'embeddedsw/XilinxProcessorIPLib/drivers/common/src/',
+ 'embeddedsw/XilinxProcessorIPLib/drivers/scugic/src',
+ 'embeddedsw/XilinxProcessorIPLib/drivers/emacps/src',
+ 'rtemslwip/xilinx'
+xilinx_aarch64_drv_incl = [
+ 'rtemslwip/zynqmp',
+ xilinx_standalone_prefix + 'arm/ARMv8/64bit',
+ xilinx_standalone_prefix + 'arm/common/gcc',
+ xilinx_standalone_prefix + 'arm/common'
# These sources are explicitly listed instead of using walk_sources below
# because multiple BSPs of varying architecture are expected to use code from
# the embeddedsw repository.
xilinx_aarch64_driver_source = [
- xilinx_lwip_prefix + 'src/contrib/ports/xilinx/netif/xadapter.c',
- xilinx_lwip_prefix + 'src/contrib/ports/xilinx/netif/xpqueue.c',
- xilinx_lwip_prefix + 'src/contrib/ports/xilinx/netif/xemacpsif.c',
- xilinx_lwip_prefix + 'src/contrib/ports/xilinx/netif/xemacpsif_dma.c',
- xilinx_lwip_prefix + 'src/contrib/ports/xilinx/netif/xemacpsif_hw.c',
- xilinx_lwip_prefix + 'src/contrib/ports/xilinx/netif/xemacpsif_physpeed.c',
+ xilinx_lwip_prefix + 'ports/xilinx/netif/xadapter.c',
+ xilinx_lwip_prefix + 'ports/xilinx/netif/xpqueue.c',
+ xilinx_lwip_prefix + 'ports/xilinx/netif/xemacpsif.c',
+ xilinx_lwip_prefix + 'ports/xilinx/netif/xemacpsif_dma.c',
+ xilinx_lwip_prefix + 'ports/xilinx/netif/xemacpsif_hw.c',
+ xilinx_lwip_prefix + 'ports/xilinx/netif/xemacpsif_physpeed.c',
'embeddedsw/XilinxProcessorIPLib/drivers/emacps/src/xemacps_bdring.c',
'embeddedsw/XilinxProcessorIPLib/drivers/emacps/src/xemacps.c',
'embeddedsw/XilinxProcessorIPLib/drivers/emacps/src/xemacps_control.c',
'embeddedsw/XilinxProcessorIPLib/drivers/emacps/src/xemacps_intr.c',
- 'embeddedsw/lib/bsp/standalone/src/common/xil_assert.c'
+ xilinx_standalone_prefix + 'common/xil_assert.c'
+common_includes = [
+ 'lwip/src/include',
+ 'uLan/ports/os/rtems',
+ 'rtemslwip/include'
+bsd_compat_incl = [
+ 'rtemslwip/bsd_compat_include'
+common_source_files = [
+ 'uLan/ports/os/rtems/arch/sys_arch.c',
+ 'rtemslwip/common/syslog.c',
+ 'rtemslwip/common/rtems_lwip_io.c',
+ 'rtemslwip/common/network_compat.c',
+ 'rtemslwip/bsd_compat/netdb.c',
+ 'rtemslwip/bsd_compat/ifaddrs.c',
+ 'rtemslwip/bsd_compat/rtems-kernel-program.c'
def build(bld):
source_files = []
- common_includes = 'lwip/src/include uLan/ports/os/rtems rtemslwip/include '
driver_source = []
- drv_incl = ' '
- bsd_compat_sources = [
- "rtemslwip/bsd_compat/netdb.c",
- "rtemslwip/bsd_compat/ifaddrs.c",
- "rtemslwip/bsd_compat/rtems-kernel-program.c"
- bsd_compat_incl = 'rtemslwip/bsd_compat_include '
+ drv_incl = []
arch_lib_path = rtems.arch_bsp_lib_path(bld.env.RTEMS_VERSION,
bld.env.RTEMS_ARCH_BSP)
with open('file-import.json', 'r') as cf:
@@ -90,11 +105,7 @@ def build(bld):
if f[-2:] == '.c':
source_files.append(os.path.join('lwip', f))
- source_files.append('uLan/ports/os/rtems/arch/sys_arch.c')
- source_files.append('rtemslwip/common/syslog.c')
- source_files.append('rtemslwip/common/rtems_lwip_io.c')
- source_files.append('rtemslwip/common/network_compat.c')
- source_files.extend(bsd_compat_sources)
+ source_files.extend(common_source_files)
def walk_sources(path):
sources = []
@@ -109,13 +120,15 @@ def build(bld):
# These files will not compile for BSPs other than TMS570
if bld.env.RTEMS_ARCH_BSP.startswith('arm-rtems6-tms570ls3137_hdk'):
- drv_incl += 'uLan/ports/driver/tms570_emac uLan/ports/os '
+ drv_incl.append('uLan/ports/driver/tms570_emac')
+ drv_incl.append('uLan/ports/os')
driver_source.extend(walk_sources('uLan/ports/driver/tms570_emac'))
# These files will only compile for BeagleBone BSPs
if bld.env.RTEMS_ARCH_BSP.startswith('arm-rtems6-beaglebone'):
driver_source.extend(walk_sources('rtemslwip/beaglebone'))
- drv_incl += 'rtemslwip/beaglebone cpsw/src/include '
+ drv_incl.append('rtemslwip/beaglebone')
+ drv_incl.append('cpsw/src/include')
driver_source.extend(walk_sources('cpsw/src'))
# These files will only compile for BSPs on Xilinx hardware
@@ -128,7 +141,7 @@ def build(bld):
if bld.env.RTEMS_ARCH_BSP.endswith('_qemu'):
is_qemu = True
if is_xilinx_bsp:
- drv_incl += xilinx_drv_incl
+ drv_incl.extend(xilinx_drv_incl)
if is_aarch64_bsp:
driver_source.extend(walk_sources('rtemslwip/zynqmp'))
if is_qemu:
@@ -136,23 +149,31 @@ def build(bld):
else:
driver_source.extend(walk_sources('rtemslwip/zynqmp_hardware'))
driver_source.extend(xilinx_aarch64_driver_source)
- drv_incl += xilinx_aarch64_drv_incl
+ drv_incl.extend(xilinx_aarch64_drv_incl)
+ lwip_obj_incl = []
+ lwip_obj_incl.extend(drv_incl)
+ lwip_obj_incl.extend(bsd_compat_incl)
+ lwip_obj_incl.extend(common_includes)
bld(features='c',
target='lwip_obj',
cflags='-g -Wall -O0',
- includes=drv_incl + bsd_compat_incl + common_includes,
+ includes=' '.join(lwip_obj_incl),
source=source_files,
- drv_obj_incl = drv_incl + common_includes
- drv_obj_incl += os.path.relpath(
+ drv_obj_incl = []
+ drv_obj_incl.extend(drv_incl)
+ drv_obj_incl.extend(common_includes)
+ drv_obj_incl.append(os.path.relpath(
os.path.join(bld.env.PREFIX, arch_lib_path, 'include')
bld(features='c',
target='driver_obj',
- includes=drv_obj_incl,
+ includes=' '.join(drv_obj_incl),
source=driver_source,
bld(features='c cstlib',
@@ -174,19 +195,24 @@ def build(bld):
os.path.join(path, name)
- [install_headers(path) for path in common_includes.split(' ')[:-1]]
- [install_headers(path) for path in drv_incl.split(' ')[:-1]]
- [install_headers(path) for path in bsd_compat_incl.split(' ')[:-1]]
+ [install_headers(path) for path in common_includes]
+ [install_headers(path) for path in drv_incl]
+ [install_headers(path) for path in bsd_compat_incl]
- test_app_incl = drv_incl + common_includes + 'rtemslwip/test/ '
- test_app_incl += os.path.relpath(os.path.join(arch_lib_path, 'include'))
+ test_app_incl = []
+ test_app_incl.extend(drv_incl)
+ test_app_incl.extend(common_includes)
+ test_app_incl.append('rtemslwip/test/')
+ os.path.relpath(os.path.join(arch_lib_path, 'include'))
bld.program(features='c',
target='networking01.exe',
source='rtemslwip/test/networking01/sample_app.c',
use='lwip',
lib=['rtemscpu', 'rtemsbsp', 'rtemstest', 'lwip'],
- includes=test_app_incl)
+ includes=' '.join(test_app_incl))
@@ -200,7 +226,7 @@ def build(bld):
source='rtemslwip/test/telnetd01/init.c',
use='telnetd lwip rtemstest ftpd',
def add_flags(flags, new_flags):
2.30.2
