[PATCH rtems-lwip] lwip.py: Track includes as lists
Chris Johns
chrisj at rtems.org
Wed Aug 31 00:32:49 UTC 2022
OK
Thanks
On 31/8/2022 3:21 am, Kinsey Moore wrote:
> The original work for rtems-lwip tracked include directories as raw
> strings to be passed into the build infrastructure. This reformulates
> include directory management as lists to reduce errors in future
> changes.
> lwip.py | 130 +++++++++++++++++++++++++++++++++-----------------------
> 1 file changed, 78 insertions(+), 52 deletions(-)
> diff --git a/lwip.py b/lwip.py
> index 2e12957..84eef2c 100644
> --- a/lwip.py
> +++ b/lwip.py
> @@ -36,52 +36,67 @@ def removeprefix(data, prefix):
> return data
> -xilinx_lwip_prefix = 'embeddedsw/ThirdParty/sw_services/lwip211/'
> -xilinx_drv_incl = ''
> -xilinx_drv_incl += xilinx_lwip_prefix + 'src/contrib/ports/xilinx/include '
> -xilinx_drv_incl += 'embeddedsw/lib/bsp/standalone/src/common '
> -xilinx_drv_incl += 'embeddedsw/XilinxProcessorIPLib/drivers/common/src/ '
> -xilinx_drv_incl += 'embeddedsw/XilinxProcessorIPLib/drivers/scugic/src '
> -xilinx_drv_incl += 'embeddedsw/XilinxProcessorIPLib/drivers/emacps/src '
> -xilinx_drv_incl += 'rtemslwip/xilinx '
> -xilinx_aarch64_drv_incl = ''
> -xilinx_aarch64_drv_incl += 'rtemslwip/zynqmp '
> -xilinx_aarch64_drv_incl += 'embeddedsw/lib/bsp/standalone/src/arm/ARMv8/64bit '
> -xilinx_aarch64_drv_incl += 'embeddedsw/lib/bsp/standalone/src/arm/common/gcc '
> -xilinx_aarch64_drv_incl += 'embeddedsw/lib/bsp/standalone/src/arm/common '
> +xilinx_lwip_prefix = 'embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/'
> +xilinx_standalone_prefix = 'embeddedsw/lib/bsp/standalone/src/'
> +xilinx_drv_incl = [
> + xilinx_lwip_prefix + 'ports/xilinx/include',
> + xilinx_standalone_prefix + 'common',
> + 'embeddedsw/XilinxProcessorIPLib/drivers/common/src/',
> + 'embeddedsw/XilinxProcessorIPLib/drivers/scugic/src',
> + 'embeddedsw/XilinxProcessorIPLib/drivers/emacps/src',
> + 'rtemslwip/xilinx'
> +xilinx_aarch64_drv_incl = [
> + 'rtemslwip/zynqmp',
> + xilinx_standalone_prefix + 'arm/ARMv8/64bit',
> + xilinx_standalone_prefix + 'arm/common/gcc',
> + xilinx_standalone_prefix + 'arm/common'
> # These sources are explicitly listed instead of using walk_sources below
> # because multiple BSPs of varying architecture are expected to use code from
> # the embeddedsw repository.
> xilinx_aarch64_driver_source = [
> - xilinx_lwip_prefix + 'src/contrib/ports/xilinx/netif/xadapter.c',
> - xilinx_lwip_prefix + 'src/contrib/ports/xilinx/netif/xpqueue.c',
> - xilinx_lwip_prefix + 'src/contrib/ports/xilinx/netif/xemacpsif.c',
> - xilinx_lwip_prefix + 'src/contrib/ports/xilinx/netif/xemacpsif_dma.c',
> - xilinx_lwip_prefix + 'src/contrib/ports/xilinx/netif/xemacpsif_hw.c',
> - xilinx_lwip_prefix + 'src/contrib/ports/xilinx/netif/xemacpsif_physpeed.c',
> + xilinx_lwip_prefix + 'ports/xilinx/netif/xadapter.c',
> + xilinx_lwip_prefix + 'ports/xilinx/netif/xpqueue.c',
> + xilinx_lwip_prefix + 'ports/xilinx/netif/xemacpsif.c',
> + xilinx_lwip_prefix + 'ports/xilinx/netif/xemacpsif_dma.c',
> + xilinx_lwip_prefix + 'ports/xilinx/netif/xemacpsif_hw.c',
> + xilinx_lwip_prefix + 'ports/xilinx/netif/xemacpsif_physpeed.c',
> 'embeddedsw/XilinxProcessorIPLib/drivers/emacps/src/xemacps_bdring.c',
> 'embeddedsw/XilinxProcessorIPLib/drivers/emacps/src/xemacps.c',
> 'embeddedsw/XilinxProcessorIPLib/drivers/emacps/src/xemacps_control.c',
> 'embeddedsw/XilinxProcessorIPLib/drivers/emacps/src/xemacps_intr.c',
> - 'embeddedsw/lib/bsp/standalone/src/common/xil_assert.c'
> + xilinx_standalone_prefix + 'common/xil_assert.c'
> +common_includes = [
> + 'lwip/src/include',
> + 'uLan/ports/os/rtems',
> + 'rtemslwip/include'
> +bsd_compat_incl = [
> + 'rtemslwip/bsd_compat_include'
> +common_source_files = [
> + 'uLan/ports/os/rtems/arch/sys_arch.c',
> + 'rtemslwip/common/syslog.c',
> + 'rtemslwip/common/rtems_lwip_io.c',
> + 'rtemslwip/common/network_compat.c',
> + 'rtemslwip/bsd_compat/netdb.c',
> + 'rtemslwip/bsd_compat/ifaddrs.c',
> + 'rtemslwip/bsd_compat/rtems-kernel-program.c'
> def build(bld):
> source_files = []
> - common_includes = 'lwip/src/include uLan/ports/os/rtems rtemslwip/include '
> driver_source = []
> - drv_incl = ' '
> - bsd_compat_sources = [
> - "rtemslwip/bsd_compat/netdb.c",
> - "rtemslwip/bsd_compat/ifaddrs.c",
> - "rtemslwip/bsd_compat/rtems-kernel-program.c"
> - bsd_compat_incl = 'rtemslwip/bsd_compat_include '
> + drv_incl = []
> arch_lib_path = rtems.arch_bsp_lib_path(bld.env.RTEMS_VERSION,
> bld.env.RTEMS_ARCH_BSP)
> with open('file-import.json', 'r') as cf:
> @@ -90,11 +105,7 @@ def build(bld):
> if f[-2:] == '.c':
> source_files.append(os.path.join('lwip', f))
> - source_files.append('uLan/ports/os/rtems/arch/sys_arch.c')
> - source_files.append('rtemslwip/common/syslog.c')
> - source_files.append('rtemslwip/common/rtems_lwip_io.c')
> - source_files.append('rtemslwip/common/network_compat.c')
> - source_files.extend(bsd_compat_sources)
> + source_files.extend(common_source_files)
> def walk_sources(path):
> sources = []
> @@ -109,13 +120,15 @@ def build(bld):
> # These files will not compile for BSPs other than TMS570
> if bld.env.RTEMS_ARCH_BSP.startswith('arm-rtems6-tms570ls3137_hdk'):
> - drv_incl += 'uLan/ports/driver/tms570_emac uLan/ports/os '
> + drv_incl.append('uLan/ports/driver/tms570_emac')
> + drv_incl.append('uLan/ports/os')
> driver_source.extend(walk_sources('uLan/ports/driver/tms570_emac'))
> # These files will only compile for BeagleBone BSPs
> if bld.env.RTEMS_ARCH_BSP.startswith('arm-rtems6-beaglebone'):
> driver_source.extend(walk_sources('rtemslwip/beaglebone'))
> - drv_incl += 'rtemslwip/beaglebone cpsw/src/include '
> + drv_incl.append('rtemslwip/beaglebone')
> + drv_incl.append('cpsw/src/include')
> driver_source.extend(walk_sources('cpsw/src'))
> # These files will only compile for BSPs on Xilinx hardware
> @@ -128,7 +141,7 @@ def build(bld):
> if bld.env.RTEMS_ARCH_BSP.endswith('_qemu'):
> is_qemu = True
> if is_xilinx_bsp:
> - drv_incl += xilinx_drv_incl
> + drv_incl.extend(xilinx_drv_incl)
> if is_aarch64_bsp:
> driver_source.extend(walk_sources('rtemslwip/zynqmp'))
> if is_qemu:
> @@ -136,23 +149,31 @@ def build(bld):
> else:
> driver_source.extend(walk_sources('rtemslwip/zynqmp_hardware'))
> driver_source.extend(xilinx_aarch64_driver_source)
> - drv_incl += xilinx_aarch64_drv_incl
> + drv_incl.extend(xilinx_aarch64_drv_incl)
> + lwip_obj_incl = []
> + lwip_obj_incl.extend(drv_incl)
> + lwip_obj_incl.extend(bsd_compat_incl)
> + lwip_obj_incl.extend(common_includes)
> bld(features='c',
> target='lwip_obj',
> cflags='-g -Wall -O0',
> - includes=drv_incl + bsd_compat_incl + common_includes,
> + includes=' '.join(lwip_obj_incl),
> source=source_files,
> - drv_obj_incl = drv_incl + common_includes
> - drv_obj_incl += os.path.relpath(
> + drv_obj_incl = []
> + drv_obj_incl.extend(drv_incl)
> + drv_obj_incl.extend(common_includes)
> + drv_obj_incl.append(os.path.relpath(
> os.path.join(bld.env.PREFIX, arch_lib_path, 'include')
> bld(features='c',
> target='driver_obj',
> - includes=drv_obj_incl,
> + includes=' '.join(drv_obj_incl),
> source=driver_source,
> bld(features='c cstlib',
> @@ -174,19 +195,24 @@ def build(bld):
> os.path.join(path, name)
> - [install_headers(path) for path in common_includes.split(' ')[:-1]]
> - [install_headers(path) for path in drv_incl.split(' ')[:-1]]
> - [install_headers(path) for path in bsd_compat_incl.split(' ')[:-1]]
> + [install_headers(path) for path in common_includes]
> + [install_headers(path) for path in drv_incl]
> + [install_headers(path) for path in bsd_compat_incl]
> - test_app_incl = drv_incl + common_includes + 'rtemslwip/test/ '
> - test_app_incl += os.path.relpath(os.path.join(arch_lib_path, 'include'))
> + test_app_incl = []
> + test_app_incl.extend(drv_incl)
> + test_app_incl.extend(common_includes)
> + test_app_incl.append('rtemslwip/test/')
> + os.path.relpath(os.path.join(arch_lib_path, 'include'))
> bld.program(features='c',
> target='networking01.exe',
> source='rtemslwip/test/networking01/sample_app.c',
> use='lwip',
> lib=['rtemscpu', 'rtemsbsp', 'rtemstest', 'lwip'],
> - includes=test_app_incl)
> + includes=' '.join(test_app_incl))
> @@ -200,7 +226,7 @@ def build(bld):
> source='rtemslwip/test/telnetd01/init.c',
> use='telnetd lwip rtemstest ftpd',
> def add_flags(flags, new_flags):
