[PATCH v5 0/1] NOEL-V BSP
Daniel Cederman cederman at gaisler.com
Wed Aug 31 07:59:10 UTC 2022
On 2022-08-30 21:10, Joel Sherrill wrote:
> I think it's OK to push after this long.
> Also be sure to add some to the RTEMS Users Guide for this BSP.
Will do.
> Does this work on any simulator?
We have a modified version of QEMU that we run it on, but we have not
made it publicly available yet.
> --joel
> On Tue, Aug 30, 2022 at 6:39 AM Daniel Cederman <cederman at gaisler.com>
> wrote:
>     Hi,
>     Is it OK to push this or should I wait for additional comments?
>     On 2022-08-25 10:33, Daniel Cederman wrote:
>>     v5
>>     Made RISCV_CONSOLE_MAX_APBUART_DEVICES an option
>>     bsp_fatal if no uart clock frequency is found
>>     Changed CONSOLE_USE_INTERRUPTS to BSP_CONSOLE_USE_INTERRUPTS
>>     Added error codes for APBUART
>>     Get work area size from /memory node
>>     Martin Aberg (1):
>>        bsp/riscv: Add NOEL-V BSP
>>       bsps/include/bsp/fatal.h                      |   3 +
>>       bsps/riscv/noel/console/console-config.c      | 208 ++++++++++++++++++
>>       bsps/riscv/noel/include/bsp.h                 |  76 +++++++
>>       bsps/riscv/noel/include/bsp/irq.h             |  75 +++++++
>>       bsps/riscv/noel/include/tm27.h                |   1 +
>>       bsps/riscv/noel/start/bsp_fatal_halt.c        |  46 ++++
>>       bsps/riscv/riscv/include/bsp.h                |   2 +
>>       bsps/riscv/riscv/include/bsp/irq.h            |   2 +
>>       spec/build/bsps/riscv/noel/abi.yml            |  48 ++++
>>       spec/build/bsps/riscv/noel/bspnoel32im.yml    |  19 ++
>>       spec/build/bsps/riscv/noel/bspnoel32imafd.yml |  19 ++
>>       spec/build/bsps/riscv/noel/bspnoel64imac.yml  |  19 ++
>>       spec/build/bsps/riscv/noel/bspnoel64imafd.yml |  19 ++
>>       .../build/bsps/riscv/noel/bspnoel64imafdc.yml |  19 ++
>>       spec/build/bsps/riscv/noel/grp.yml            |  61 +++++
>>       spec/build/bsps/riscv/noel/obj.yml            |  38 ++++
>>       spec/build/bsps/riscv/noel/objsmp.yml         |  15 ++
>>       spec/build/bsps/riscv/noel/optapbuartmax.yml  |  16 ++
>>       spec/build/bsps/riscv/optrambegin.yml         |   3 +
>>       spec/build/cpukit/optarchbits.yml             |   2 +
>>       spec/build/cpukit/optsmp.yml                  |   4 +
>>       21 files changed, 695 insertions(+)
>>       create mode 100644 bsps/riscv/noel/console/console-config.c
>>       create mode 100644 bsps/riscv/noel/include/bsp.h
>>       create mode 100644 bsps/riscv/noel/include/bsp/irq.h
>>       create mode 100644 bsps/riscv/noel/include/tm27.h
>>       create mode 100644 bsps/riscv/noel/start/bsp_fatal_halt.c
>>       create mode 100644 spec/build/bsps/riscv/noel/abi.yml
>>       create mode 100644 spec/build/bsps/riscv/noel/bspnoel32im.yml
>>       create mode 100644 spec/build/bsps/riscv/noel/bspnoel32imafd.yml
>>       create mode 100644 spec/build/bsps/riscv/noel/bspnoel64imac.yml
>>       create mode 100644 spec/build/bsps/riscv/noel/bspnoel64imafd.yml
>>       create mode 100644 spec/build/bsps/riscv/noel/bspnoel64imafdc.yml
>>       create mode 100644 spec/build/bsps/riscv/noel/grp.yml
>>       create mode 100644 spec/build/bsps/riscv/noel/obj.yml
>>       create mode 100644 spec/build/bsps/riscv/noel/objsmp.yml
>>       create mode 100644 spec/build/bsps/riscv/noel/optapbuartmax.yml
>     _______________________________________________
>     devel mailing list
>     devel at rtems.org
>     http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220831/9c05e927/attachment-0001.htm>
