[PATCH v5 0/1] NOEL-V BSP
Joel Sherrill
joel at rtems.org
Tue Aug 30 19:11:44 UTC 2022
And then Sebastian replies while I was typing that.
Address his concerns. :)
On Tue, Aug 30, 2022 at 2:10 PM Joel Sherrill <joel at rtems.org> wrote:
> I think it's OK to push after this long.
> Also be sure to add some to the RTEMS Users Guide for this BSP.
> Does this work on any simulator?
> --joel
> On Tue, Aug 30, 2022 at 6:39 AM Daniel Cederman <cederman at gaisler.com>
> wrote:
>> Hi,
>> Is it OK to push this or should I wait for additional comments?
>> On 2022-08-25 10:33, Daniel Cederman wrote:
>> v5
>> Made RISCV_CONSOLE_MAX_APBUART_DEVICES an option
>> bsp_fatal if no uart clock frequency is found
>> Changed CONSOLE_USE_INTERRUPTS to BSP_CONSOLE_USE_INTERRUPTS
>> Added error codes for APBUART
>> Get work area size from /memory node
>> Martin Aberg (1):
>> bsp/riscv: Add NOEL-V BSP
>> bsps/include/bsp/fatal.h | 3 +
>> bsps/riscv/noel/console/console-config.c | 208 ++++++++++++++++++
>> bsps/riscv/noel/include/bsp.h | 76 +++++++
>> bsps/riscv/noel/include/bsp/irq.h | 75 +++++++
>> bsps/riscv/noel/include/tm27.h | 1 +
>> bsps/riscv/noel/start/bsp_fatal_halt.c | 46 ++++
>> bsps/riscv/riscv/include/bsp.h | 2 +
>> bsps/riscv/riscv/include/bsp/irq.h | 2 +
>> spec/build/bsps/riscv/noel/abi.yml | 48 ++++
>> spec/build/bsps/riscv/noel/bspnoel32im.yml | 19 ++
>> spec/build/bsps/riscv/noel/bspnoel32imafd.yml | 19 ++
>> spec/build/bsps/riscv/noel/bspnoel64imac.yml | 19 ++
>> spec/build/bsps/riscv/noel/bspnoel64imafd.yml | 19 ++
>> .../build/bsps/riscv/noel/bspnoel64imafdc.yml | 19 ++
>> spec/build/bsps/riscv/noel/grp.yml | 61 +++++
>> spec/build/bsps/riscv/noel/obj.yml | 38 ++++
>> spec/build/bsps/riscv/noel/objsmp.yml | 15 ++
>> spec/build/bsps/riscv/noel/optapbuartmax.yml | 16 ++
>> spec/build/bsps/riscv/optrambegin.yml | 3 +
>> spec/build/cpukit/optarchbits.yml | 2 +
>> spec/build/cpukit/optsmp.yml | 4 +
>> 21 files changed, 695 insertions(+)
>> create mode 100644 bsps/riscv/noel/console/console-config.c
>> create mode 100644 bsps/riscv/noel/include/bsp.h
>> create mode 100644 bsps/riscv/noel/include/bsp/irq.h
>> create mode 100644 bsps/riscv/noel/include/tm27.h
>> create mode 100644 bsps/riscv/noel/start/bsp_fatal_halt.c
>> create mode 100644 spec/build/bsps/riscv/noel/abi.yml
>> create mode 100644 spec/build/bsps/riscv/noel/bspnoel32im.yml
>> create mode 100644 spec/build/bsps/riscv/noel/bspnoel32imafd.yml
>> create mode 100644 spec/build/bsps/riscv/noel/bspnoel64imac.yml
>> create mode 100644 spec/build/bsps/riscv/noel/bspnoel64imafd.yml
>> create mode 100644 spec/build/bsps/riscv/noel/bspnoel64imafdc.yml
>> create mode 100644 spec/build/bsps/riscv/noel/grp.yml
>> create mode 100644 spec/build/bsps/riscv/noel/obj.yml
>> create mode 100644 spec/build/bsps/riscv/noel/objsmp.yml
>> create mode 100644 spec/build/bsps/riscv/noel/optapbuartmax.yml
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220830/a5df66ac/attachment.htm>
