[PATCH 3/3] config: Add CONFIGURE_RECORD_INTERRUPTS_ENABLED
Thu Dec 1 12:10:58 UTC 2022
Update #4769.
 bsps/shared/irq/irq-record.c               | 97 ++++++++++++++++++++++
 cpukit/doxygen/appl-config.h               | 23 +++++
 cpukit/include/rtems/confdefs/extensions.h |  8 ++
 cpukit/include/rtems/record.h              |  2 +
 spec/build/bsps/objirq.yml                 |  1 +
 spec/build/bsps/powerpc/ss555/bspss555.yml |  1 +
 6 files changed, 132 insertions(+)
 create mode 100644 bsps/shared/irq/irq-record.c
diff --git a/bsps/shared/irq/irq-record.c b/bsps/shared/irq/irq-record.c
new file mode 100644
index 0000000000..9f0a008d84
--- /dev/null
+++ b/bsps/shared/irq/irq-record.c
@@ -0,0 +1,97 @@
+ * @file
+ * @ingroup bsp_interrupt
+ * @brief This source file contains the implementation of the interrupt event
+ *   recording support.
+ * Copyright (C) 2022 embedded brains GmbH
+ * are met:
+#include <bsp/irq-generic.h>
+#include <rtems/record.h>
+/* The regular interrupt entries are registered in this table */
+static rtems_interrupt_entry *
+_Record_Interrupt_dispatch_table[ BSP_INTERRUPT_DISPATCH_TABLE_SIZE ];
+ * Provide one interrupt entry for the _Record_Interrupt_handler() interrupt
+ * dispatch wrapper for each interrupt vector.
+_Record_Interrupt_entry_table[ BSP_INTERRUPT_DISPATCH_TABLE_SIZE ];
+rtems_interrupt_entry **bsp_interrupt_get_dispatch_table_slot(
+  rtems_vector_number index
+  return &_Record_Interrupt_dispatch_table[ index ];
+static void _Record_Interrupt_handler( void *arg )
+  uintptr_t              vector;
+  rtems_interrupt_entry *entry;
+  vector = (uintptr_t) arg;
+  rtems_record_produce( RTEMS_RECORD_INTERRUPT_ENTRY, vector );
+  entry = bsp_interrupt_entry_load_acquire(
+    &_Record_Interrupt_dispatch_table[ vector ]
+  if ( RTEMS_PREDICT_TRUE( entry != NULL ) ) {
+    bsp_interrupt_dispatch_entries( entry );
+  } else {
+#if defined(RTEMS_SMP)
+    bsp_interrupt_spurious( vector );
+#else
+    bsp_interrupt_handler_default( vector );
+#endif
+  rtems_record_produce( RTEMS_RECORD_INTERRUPT_EXIT, vector );
+void _Record_Interrupt_initialize( void )
+  uintptr_t i;
+   * Let each interrupt dispatch table slot reference the
+   * _Record_Interrupt_handler() interrupt dispatch wrapper.
+  for ( i = 0; i < BSP_INTERRUPT_DISPATCH_TABLE_SIZE; ++i ) {
+    _Record_Interrupt_entry_table[ i ].handler = _Record_Interrupt_handler;
+    _Record_Interrupt_entry_table[ i ].arg = (void *) i;
+    bsp_interrupt_dispatch_table[ i ] = &_Record_Interrupt_entry_table[ i ];
diff --git a/cpukit/doxygen/appl-config.h b/cpukit/doxygen/appl-config.h
index 88cd03d328..964f8d0616 100644
--- a/cpukit/doxygen/appl-config.h
+++ b/cpukit/doxygen/appl-config.h
@@ -1911,6 +1911,29 @@
 #define CONFIGURE_RECORD_FATAL_DUMP_BASE64_ZLIB
+/* Generated from spec:/acfg/if/record-interrupts-enabled */
+ * @brief This configuration option is a boolean feature define.
+ * In case
+ * * this configuration option is defined
+ * * and #CONFIGURE_RECORD_PER_PROCESSOR_ITEMS is properly defined,
+ * then the interrupt event recording is enabled.
+ * @par Default Configuration
+ * If this configuration option is undefined, then the described feature is not
+ * enabled.
+ * @par Notes
+ * The interrupt event recording generates interrupt entry and exit events when
+ * interrupt entries are dispatched.
+#define CONFIGURE_RECORD_INTERRUPTS_ENABLED
 /* Generated from spec:/acfg/if/record-per-processor-items */
diff --git a/cpukit/include/rtems/confdefs/extensions.h b/cpukit/include/rtems/confdefs/extensions.h
index 118ad29484..a369ef1f61 100644
--- a/cpukit/include/rtems/confdefs/extensions.h
+++ b/cpukit/include/rtems/confdefs/extensions.h
@@ -188,6 +188,14 @@ extern "C" {
     RTEMS_SYSINIT_RECORD,
     RTEMS_SYSINIT_ORDER_MIDDLE
+  #ifdef CONFIGURE_RECORD_INTERRUPTS_ENABLED
+    RTEMS_SYSINIT_ITEM(
+      _Record_Interrupt_initialize,
+      RTEMS_SYSINIT_LAST,
+      RTEMS_SYSINIT_ORDER_MIDDLE
+  #endif
 #endif
 #ifdef CONFIGURE_VERBOSE_SYSTEM_INITIALIZATION
diff --git a/cpukit/include/rtems/record.h b/cpukit/include/rtems/record.h
index a8e115ad44..8a84c22bdc 100644
--- a/cpukit/include/rtems/record.h
+++ b/cpukit/include/rtems/record.h
@@ -67,6 +67,8 @@ extern const Record_Configuration _Record_Configuration;
 void _Record_Initialize( void );
+void _Record_Interrupt_initialize( void );
 bool _Record_Thread_create(
   struct _Thread_Control *executing,
   struct _Thread_Control *created
diff --git a/spec/build/bsps/objirq.yml b/spec/build/bsps/objirq.yml
index 0766c1ea58..553065e97b 100644
--- a/spec/build/bsps/objirq.yml
+++ b/spec/build/bsps/objirq.yml
@@ -21,6 +21,7 @@ source:
 - bsps/shared/irq/irq-info.c
 - bsps/shared/irq/irq-legacy.c
 - bsps/shared/irq/irq-lock.c
+- bsps/shared/irq/irq-record.c
 - bsps/shared/irq/irq-server.c
 - bsps/shared/irq/irq-shell.c
 type: build
diff --git a/spec/build/bsps/powerpc/ss555/bspss555.yml b/spec/build/bsps/powerpc/ss555/bspss555.yml
index 1f3d962e77..c0c9bbfb03 100644
--- a/spec/build/bsps/powerpc/ss555/bspss555.yml
+++ b/spec/build/bsps/powerpc/ss555/bspss555.yml
@@ -80,6 +80,7 @@ source:
 - bsps/shared/irq/irq-handler-remove.c
 - bsps/shared/start/bspfatal-default.c
2.35.3
