Update #4769.
bsps/include/bsp/irq-generic.h | 11 +++++++++++
bsps/shared/irq/irq-entry-remove.c | 2 +-
bsps/shared/irq/irq-generic.c | 19 +++++++++++++------
bsps/shared/irq/irq-handler-iterate.c | 2 +-
4 files changed, 26 insertions(+), 8 deletions(-)
diff --git a/bsps/include/bsp/irq-generic.h b/bsps/include/bsp/irq-generic.h
index 4a3dd75e7d..1ff84ee7cd 100644
--- a/bsps/include/bsp/irq-generic.h
+++ b/bsps/include/bsp/irq-generic.h
@@ -663,6 +663,17 @@ static inline bool bsp_interrupt_is_initialized( void )
return bsp_interrupt_is_handler_unique( BSP_INTERRUPT_DISPATCH_TABLE_SIZE );
+ * @brief Gets a reference to the interrupt handler table slot associated with
+ * the index.
+ * @return Returns a reference to the interrupt handler table slot associated
+ * with the index.
+rtems_interrupt_entry **bsp_interrupt_get_dispatch_table_slot(
+ rtems_vector_number index
#ifdef __cplusplus
#endif /* __cplusplus */
diff --git a/bsps/shared/irq/irq-entry-remove.c b/bsps/shared/irq/irq-entry-remove.c
index e970b80455..6b43134a0c 100644
--- a/bsps/shared/irq/irq-entry-remove.c
+++ b/bsps/shared/irq/irq-entry-remove.c
@@ -47,7 +47,7 @@ void bsp_interrupt_entry_remove(
rtems_interrupt_entry *entry_next;
index = bsp_interrupt_dispatch_index( vector );
- first = bsp_interrupt_dispatch_table[ index ];
+ first = *bsp_interrupt_get_dispatch_table_slot( index );
entry_next = entry->next;
if ( entry == first && entry_next == NULL ) {
diff --git a/bsps/shared/irq/irq-generic.c b/bsps/shared/irq/irq-generic.c
index ffd820730e..e899731a54 100644
--- a/bsps/shared/irq/irq-generic.c
+++ b/bsps/shared/irq/irq-generic.c
@@ -49,6 +49,13 @@
bsp_interrupt_dispatch_table[ BSP_INTERRUPT_DISPATCH_TABLE_SIZE ];
+RTEMS_WEAK rtems_interrupt_entry **bsp_interrupt_get_dispatch_table_slot(
+ return &bsp_interrupt_dispatch_table[ index ];
/* The last entry indicates if everything is initialized */
uint8_t bsp_interrupt_handler_unique_table
[ ( BSP_INTERRUPT_DISPATCH_TABLE_SIZE + 7 + 1 ) / 8 ];
@@ -91,9 +98,9 @@ void bsp_interrupt_spurious( rtems_vector_number vector )
* In order to get the last written pointer value to the first entry, we have
* to carry out an atomic read-modify-write operation.
- ptr = (Atomic_Uintptr *) &bsp_interrupt_dispatch_table[
+ ptr = (Atomic_Uintptr *) bsp_interrupt_get_dispatch_table_slot(
first = (rtems_interrupt_entry *)
_Atomic_Fetch_add_uintptr( ptr, 0, ATOMIC_ORDER_ACQUIRE );
@@ -143,8 +150,8 @@ rtems_interrupt_entry *bsp_interrupt_entry_find(
bsp_interrupt_assert( bsp_interrupt_is_valid_vector( vector ) );
- *previous_next = &bsp_interrupt_dispatch_table[ index ];
- entry = bsp_interrupt_dispatch_table[ index ];
+ *previous_next = bsp_interrupt_get_dispatch_table_slot( index );
+ entry = **previous_next;
while ( entry != NULL ) {
if ( entry->handler == routine && entry->arg == arg ) {
@@ -187,7 +194,7 @@ static rtems_status_code bsp_interrupt_entry_install_first(
bsp_interrupt_dispatch_index_table[ vector ] = index;
#endif
bsp_interrupt_entry_store_release(
- &bsp_interrupt_dispatch_table[ index ],
+ bsp_interrupt_get_dispatch_table_slot( index ),
entry
@@ -220,7 +227,7 @@ static rtems_status_code bsp_interrupt_entry_install(
if ( first == NULL ) {
return bsp_interrupt_entry_install_first( vector, options, entry );
diff --git a/bsps/shared/irq/irq-handler-iterate.c b/bsps/shared/irq/irq-handler-iterate.c
index 0aa890e6fd..7437e8a43e 100644
--- a/bsps/shared/irq/irq-handler-iterate.c
+++ b/bsps/shared/irq/irq-handler-iterate.c
@@ -57,9 +57,9 @@ rtems_status_code rtems_interrupt_handler_iterate(
+ entry = *bsp_interrupt_get_dispatch_table_slot( index );
options = bsp_interrupt_is_handler_unique( index ) ?
RTEMS_INTERRUPT_UNIQUE : RTEMS_INTERRUPT_SHARED;
( *routine )( arg, entry->info, options, entry->handler, entry->arg );
2.35.3
