[PATCH 1/3] bsps/irq: Rename handler in dispatch table
Sebastian Huber
Thu Dec 1 12:10:56 UTC 2022
The name handler table was a bit misleading after the last rework.
Rename it in distach table. Update the documentation accordingly.
Update #4769.
bsps/include/bsp/irq-generic.h | 68 +++++++++----------
bsps/powerpc/mpc55xxevb/include/bsp/irq.h | 2 +-
bsps/riscv/riscv/include/tm27.h | 4 +-
bsps/shared/irq/irq-entry-remove.c | 6 +-
bsps/shared/irq/irq-generic.c | 32 ++++-----
bsps/shared/irq/irq-handler-iterate.c | 4 +-
.../validation/tc-bsp-interrupt-spurious.c | 4 +-
testsuites/validation/tc-intr-entry-install.c | 4 +-
testsuites/validation/tc-intr-entry-remove.c | 8 +--
.../validation/tc-intr-handler-iterate.c | 4 +-
10 files changed, 67 insertions(+), 69 deletions(-)
diff --git a/bsps/include/bsp/irq-generic.h b/bsps/include/bsp/irq-generic.h
index f605da9803..4a3dd75e7d 100644
--- a/bsps/include/bsp/irq-generic.h
+++ b/bsps/include/bsp/irq-generic.h
@@ -62,12 +62,12 @@ extern "C" {
#error "BSP_INTERRUPT_VECTOR_COUNT shall be defined"
#endif
-#if defined(BSP_INTERRUPT_USE_INDEX_TABLE) && !defined(BSP_INTERRUPT_HANDLER_TABLE_SIZE)
- #error "if you define BSP_INTERRUPT_USE_INDEX_TABLE, you have to define BSP_INTERRUPT_HANDLER_TABLE_SIZE etc. as well"
+#if defined(BSP_INTERRUPT_USE_INDEX_TABLE) && !defined(BSP_INTERRUPT_DISPATCH_TABLE_SIZE)
+ #error "if you define BSP_INTERRUPT_USE_INDEX_TABLE, you have to define BSP_INTERRUPT_DISPATCH_TABLE_SIZE etc. as well"
#endif
-#ifndef BSP_INTERRUPT_HANDLER_TABLE_SIZE
- #define BSP_INTERRUPT_HANDLER_TABLE_SIZE BSP_INTERRUPT_VECTOR_COUNT
+#ifndef BSP_INTERRUPT_DISPATCH_TABLE_SIZE
+ #define BSP_INTERRUPT_DISPATCH_TABLE_SIZE BSP_INTERRUPT_VECTOR_COUNT
#endif
#define bsp_interrupt_assert(e) _Assert(e)
@@ -76,25 +76,25 @@ extern "C" {
* @brief Each member of this table references the first installed entry at the
* corresponding interrupt vector or is NULL.
-extern rtems_interrupt_entry *bsp_interrupt_handler_table[];
+extern rtems_interrupt_entry *bsp_interrupt_dispatch_table[];
#ifdef BSP_INTERRUPT_USE_INDEX_TABLE
- #if BSP_INTERRUPT_HANDLER_TABLE_SIZE < 0x100
- typedef uint8_t bsp_interrupt_handler_index_type;
- #elif BSP_INTERRUPT_HANDLER_TABLE_SIZE < 0x10000
- typedef uint16_t bsp_interrupt_handler_index_type;
+ #if BSP_INTERRUPT_DISPATCH_TABLE_SIZE < 0x100
+ typedef uint8_t bsp_interrupt_dispatch_index_type;
+ #elif BSP_INTERRUPT_DISPATCH_TABLE_SIZE < 0x10000
+ typedef uint16_t bsp_interrupt_dispatch_index_type;
#else
- typedef uint32_t bsp_interrupt_handler_index_type;
+ typedef uint32_t bsp_interrupt_dispatch_index_type;
#endif
- extern bsp_interrupt_handler_index_type bsp_interrupt_handler_index_table [];
+ extern bsp_interrupt_dispatch_index_type bsp_interrupt_dispatch_index_table [];
#endif
-static inline rtems_vector_number bsp_interrupt_handler_index(
+static inline rtems_vector_number bsp_interrupt_dispatch_index(
rtems_vector_number vector
- return bsp_interrupt_handler_index_table [vector];
+ return bsp_interrupt_dispatch_index_table [vector];
#else
return vector;
#endif
@@ -109,23 +109,21 @@ static inline rtems_vector_number bsp_interrupt_handler_index(
* The BSP interrupt support manages a sequence of interrupt vector numbers
* greater than or equal to zero and less than @ref BSP_INTERRUPT_VECTOR_COUNT
- * It provides methods to
- * @ref bsp_interrupt_handler_install() "install",
- * @ref bsp_interrupt_handler_remove() "remove" and
- * @ref bsp_interrupt_handler_dispatch() "dispatch" interrupt handlers for each
+ * It provides methods to install, remove, and @ref
+ * bsp_interrupt_handler_dispatch() "dispatch" interrupt entries for each
* vector number. It implements parts of the RTEMS interrupt manager.
- * The entry points to a list of interrupt handlers are stored in a table
- * (= handler table).
+ * The entry points to a list of interrupt entries are stored in a table
+ * (= dispatch table).
* You have to configure the BSP interrupt support in the <bsp/irq.h> file
* for each BSP. For a minimum configuration you have to provide
* @ref BSP_INTERRUPT_VECTOR_COUNT.
* For boards with small memory requirements you can define
- * @ref BSP_INTERRUPT_USE_INDEX_TABLE. With an enabled index table the handler
- * table will be accessed via a small index table. You can define the size of
- * the handler table with @ref BSP_INTERRUPT_HANDLER_TABLE_SIZE.
+ * @ref BSP_INTERRUPT_USE_INDEX_TABLE. With an enabled index table the
+ * dispatch table will be accessed via a small index table. You can define the
+ * size of the dispatch table with @ref BSP_INTERRUPT_DISPATCH_TABLE_SIZE.
* You have to provide some special routines in your BSP (follow the links for
* the details):
@@ -180,7 +178,7 @@ void bsp_interrupt_handler_default(rtems_vector_number vector);
* @brief Initialize BSP interrupt support.
* You must call this function before you can install, remove and dispatch
- * interrupt handlers. There is no protection against concurrent
+ * interrupt entries. There is no protection against concurrent
* initialization. This function must be called at most once. The BSP
* specific bsp_interrupt_facility_initialize() function will be called after
* all internals are initialized. If the BSP specific initialization fails,
@@ -249,8 +247,8 @@ rtems_status_code bsp_interrupt_vector_is_enabled(
* @brief Enables the interrupt vector.
* This function shall enable the vector at the corresponding facility (in most
- * cases the interrupt controller). It will be called then the first handler
- * is installed for the vector in bsp_interrupt_handler_install() for example.
+ * cases the interrupt controller). It will be called then the first entry
+ * is installed for the vector in rtems_interrupt_entry_install() for example.
* @note The implementation should use
* bsp_interrupt_assert( bsp_interrupt_is_valid_vector( vector ) ) to validate
@@ -270,7 +268,7 @@ rtems_status_code bsp_interrupt_vector_enable( rtems_vector_number vector );
* This function shall disable the vector at the corresponding facility (in
* most cases the interrupt controller). It will be called then the last
- * handler is removed for the vector in bsp_interrupt_handler_remove() for
+ * entry is removed for the vector in rtems_interrupt_entry_remove() for
* example.
@@ -429,10 +427,10 @@ static inline rtems_interrupt_entry *bsp_interrupt_entry_load_first(
rtems_vector_number index;
- index = bsp_interrupt_handler_index( vector );
+ index = bsp_interrupt_dispatch_index( vector );
return bsp_interrupt_entry_load_acquire(
- &bsp_interrupt_handler_table[ index ]
+ &bsp_interrupt_dispatch_table[ index ]
@@ -463,8 +461,8 @@ static inline void bsp_interrupt_dispatch_entries(
* This function does not validate the vector number. If the vector number is
* out of range, then the behaviour is undefined.
- * The function assumes that no handlers are installed at the vector. In this
- * case, no operation is performed.
+ * The function assumes that no interrupt entries are installed at the vector.
+ * In this case, no operation is performed.
* In uniprocessor configurations, you can call this function within every
* context which can be disabled via rtems_interrupt_local_disable().
@@ -521,9 +519,9 @@ static inline void bsp_interrupt_handler_dispatch_unchecked(
* @brief Sequentially calls all interrupt handlers installed at the vector.
- * If the vector number is out of range or the handler list is empty
- * bsp_interrupt_handler_default() will be called with the vector number as
- * argument.
+ * If the vector number is out of range or the interrupt entry list is empty,
+ * then bsp_interrupt_handler_default() will be called with the vector number
+ * as argument.
@@ -604,7 +602,7 @@ void bsp_interrupt_entry_remove(
* If the bit associated with a vector is set, then the entry is unique,
* otherwise it may be shared. If the bit with index
- * #BSP_INTERRUPT_HANDLER_TABLE_SIZE is set, then the interrupt support is
+ * #BSP_INTERRUPT_DISPATCH_TABLE_SIZE is set, then the interrupt support is
* initialized, otherwise it is not initialized.
extern uint8_t bsp_interrupt_handler_unique_table[];
@@ -662,7 +660,7 @@ static inline void bsp_interrupt_set_handler_unique(
static inline bool bsp_interrupt_is_initialized( void )
- return bsp_interrupt_is_handler_unique( BSP_INTERRUPT_HANDLER_TABLE_SIZE );
+ return bsp_interrupt_is_handler_unique( BSP_INTERRUPT_DISPATCH_TABLE_SIZE );
#ifdef __cplusplus
diff --git a/bsps/powerpc/mpc55xxevb/include/bsp/irq.h b/bsps/powerpc/mpc55xxevb/include/bsp/irq.h
index ae2d20f7bd..1bedd3a65a 100644
--- a/bsps/powerpc/mpc55xxevb/include/bsp/irq.h
+++ b/bsps/powerpc/mpc55xxevb/include/bsp/irq.h
@@ -492,7 +492,7 @@ rtems_status_code mpc55xx_intc_clear_software_irq(rtems_vector_number vector);
#define BSP_INTERRUPT_VECTOR_COUNT (MPC55XX_IRQ_MAX + 1)
-#ifdef BSP_INTERRUPT_HANDLER_TABLE_SIZE
+#ifdef BSP_INTERRUPT_DISPATCH_TABLE_SIZE
#define BSP_INTERRUPT_USE_INDEX_TABLE
#endif
diff --git a/bsps/riscv/riscv/include/tm27.h b/bsps/riscv/riscv/include/tm27.h
index 3e092214e5..1226fc8667 100644
--- a/bsps/riscv/riscv/include/tm27.h
+++ b/bsps/riscv/riscv/include/tm27.h
@@ -123,9 +123,9 @@ static inline void Lower_tm27_intr( void )
irq = RISCV_INTERRUPT_VECTOR_SOFTWARE;
- if ( bsp_interrupt_handler_table[ irq ] == NULL ) {
+ if ( bsp_interrupt_dispatch_table[ irq ] == NULL ) {
_Assert( riscv_tm27_can_use_mtime );
- bsp_interrupt_handler_table[ irq ] = &riscv_tm27_interrupt_entry;
+ bsp_interrupt_dispatch_table[ irq ] = &riscv_tm27_interrupt_entry;
(void) rtems_interrupt_vector_enable( irq );
diff --git a/bsps/shared/irq/irq-entry-remove.c b/bsps/shared/irq/irq-entry-remove.c
index 3e5fd33fbe..e970b80455 100644
--- a/bsps/shared/irq/irq-entry-remove.c
+++ b/bsps/shared/irq/irq-entry-remove.c
@@ -46,8 +46,8 @@ void bsp_interrupt_entry_remove(
rtems_interrupt_entry *first;
rtems_interrupt_entry *entry_next;
- first = bsp_interrupt_handler_table[ index ];
+ first = bsp_interrupt_dispatch_table[ index ];
entry_next = entry->next;
if ( entry == first && entry_next == NULL ) {
@@ -60,7 +60,7 @@ void bsp_interrupt_entry_remove(
#endif
bsp_interrupt_set_handler_unique( index, false );
- bsp_interrupt_handler_index_table[ vector ] = 0;
+ bsp_interrupt_dispatch_index_table[ vector ] = 0;
#endif
diff --git a/bsps/shared/irq/irq-generic.c b/bsps/shared/irq/irq-generic.c
index dac1ca4209..ffd820730e 100644
--- a/bsps/shared/irq/irq-generic.c
+++ b/bsps/shared/irq/irq-generic.c
@@ -42,20 +42,20 @@
#include <rtems/malloc.h>
- bsp_interrupt_handler_index_type bsp_interrupt_handler_index_table
+ bsp_interrupt_dispatch_index_type bsp_interrupt_dispatch_index_table
[BSP_INTERRUPT_VECTOR_COUNT];
#endif
-bsp_interrupt_handler_table[ BSP_INTERRUPT_HANDLER_TABLE_SIZE ];
+bsp_interrupt_dispatch_table[ BSP_INTERRUPT_DISPATCH_TABLE_SIZE ];
/* The last entry indicates if everything is initialized */
- [ ( BSP_INTERRUPT_HANDLER_TABLE_SIZE + 7 + 1 ) / 8 ];
+ [ ( BSP_INTERRUPT_DISPATCH_TABLE_SIZE + 7 + 1 ) / 8 ];
static inline void bsp_interrupt_set_initialized(void)
- bsp_interrupt_set_handler_unique(BSP_INTERRUPT_HANDLER_TABLE_SIZE, true);
+ bsp_interrupt_set_handler_unique(BSP_INTERRUPT_DISPATCH_TABLE_SIZE, true);
@@ -66,8 +66,8 @@ static inline rtems_vector_number bsp_interrupt_allocate_handler_index(
rtems_vector_number i;
/* The first entry will remain empty */
- for ( i = 1; i < BSP_INTERRUPT_HANDLER_TABLE_SIZE; ++i ) {
- if ( bsp_interrupt_handler_table[ i ] == NULL ) {
+ for ( i = 1; i < BSP_INTERRUPT_DISPATCH_TABLE_SIZE; ++i ) {
+ if ( bsp_interrupt_dispatch_table[ i ] == NULL ) {
break;
@@ -91,8 +91,8 @@ void bsp_interrupt_spurious( rtems_vector_number vector )
* In order to get the last written pointer value to the first entry, we have
* to carry out an atomic read-modify-write operation.
- ptr = (Atomic_Uintptr *) &bsp_interrupt_handler_table[
- bsp_interrupt_handler_index( vector )
+ ptr = (Atomic_Uintptr *) &bsp_interrupt_dispatch_table[
+ bsp_interrupt_dispatch_index( vector )
first = (rtems_interrupt_entry *)
_Atomic_Fetch_add_uintptr( ptr, 0, ATOMIC_ORDER_ACQUIRE );
@@ -142,9 +142,9 @@ rtems_interrupt_entry *bsp_interrupt_entry_find(
rtems_interrupt_entry *entry;
bsp_interrupt_assert( bsp_interrupt_is_valid_vector( vector ) );
- *previous_next = &bsp_interrupt_handler_table[ index ];
- entry = bsp_interrupt_handler_table[ index ];
+ *previous_next = &bsp_interrupt_dispatch_table[ index ];
+ entry = bsp_interrupt_dispatch_table[ index ];
while ( entry != NULL ) {
if ( entry->handler == routine && entry->arg == arg ) {
@@ -175,7 +175,7 @@ static rtems_status_code bsp_interrupt_entry_install_first(
index = bsp_interrupt_allocate_handler_index( vector );
- if ( index == BSP_INTERRUPT_HANDLER_TABLE_SIZE ) {
+ if ( index == BSP_INTERRUPT_DISPATCH_TABLE_SIZE ) {
/* Handler table is full */
return RTEMS_NO_MEMORY;
@@ -184,10 +184,10 @@ static rtems_status_code bsp_interrupt_entry_install_first(
#endif
- bsp_interrupt_handler_index_table[ vector ] = index;
+ bsp_interrupt_dispatch_index_table[ vector ] = index;
#endif
bsp_interrupt_entry_store_release(
- &bsp_interrupt_handler_table[ index ],
+ &bsp_interrupt_dispatch_table[ index ],
entry
@@ -219,8 +219,8 @@ static rtems_status_code bsp_interrupt_entry_install(
return RTEMS_INVALID_NUMBER;
if ( first == NULL ) {
return bsp_interrupt_entry_install_first( vector, options, entry );
diff --git a/bsps/shared/irq/irq-handler-iterate.c b/bsps/shared/irq/irq-handler-iterate.c
index 8bb29191fd..0aa890e6fd 100644
--- a/bsps/shared/irq/irq-handler-iterate.c
+++ b/bsps/shared/irq/irq-handler-iterate.c
@@ -56,10 +56,10 @@ rtems_status_code rtems_interrupt_handler_iterate(
return sc;
options = bsp_interrupt_is_handler_unique( index ) ?
RTEMS_INTERRUPT_UNIQUE : RTEMS_INTERRUPT_SHARED;
( *routine )( arg, entry->info, options, entry->handler, entry->arg );
diff --git a/testsuites/validation/tc-bsp-interrupt-spurious.c b/testsuites/validation/tc-bsp-interrupt-spurious.c
index 5d6149307a..f1230cb7e0 100644
--- a/testsuites/validation/tc-bsp-interrupt-spurious.c
+++ b/testsuites/validation/tc-bsp-interrupt-spurious.c
@@ -421,8 +421,8 @@ static void BspReqInterruptSpurious_Setup(
ctx->first = NULL;
ctx->test_vector = CallWithinISRGetVector();
T_assert_lt_u32( ctx->test_vector, BSP_INTERRUPT_VECTOR_COUNT );
- ctx->first = &bsp_interrupt_handler_table[
- bsp_interrupt_handler_index( ctx->test_vector )
+ ctx->first = &bsp_interrupt_dispatch_table[
+ bsp_interrupt_dispatch_index( ctx->test_vector )
ctx->entry_to_restore = *ctx->first;
diff --git a/testsuites/validation/tc-intr-entry-install.c b/testsuites/validation/tc-intr-entry-install.c
index 152963828c..40f91ca510 100644
--- a/testsuites/validation/tc-intr-entry-install.c
+++ b/testsuites/validation/tc-intr-entry-install.c
@@ -523,7 +523,7 @@ static void Action( void *arg )
T_rsc_success( sc );
- BSP_INTERRUPT_HANDLER_TABLE_SIZE,
+ BSP_INTERRUPT_DISPATCH_TABLE_SIZE,
ctx->initialized
@@ -534,7 +534,7 @@ static void Action( void *arg )
ctx->initialized_during_setup
diff --git a/testsuites/validation/tc-intr-entry-remove.c b/testsuites/validation/tc-intr-entry-remove.c
index 9807251dc6..b9960618c6 100644
--- a/testsuites/validation/tc-intr-entry-remove.c
+++ b/testsuites/validation/tc-intr-entry-remove.c
@@ -479,14 +479,14 @@ static void Action( void *arg )
ctx->initialized
ctx->status = rtems_interrupt_entry_remove( ctx->vector, ctx->entry );
@@ -1040,8 +1040,8 @@ static void RtemsIntrReqEntryRemove_Post_Installed_Check(
} else {
T_null( first );
diff --git a/testsuites/validation/tc-intr-handler-iterate.c b/testsuites/validation/tc-intr-handler-iterate.c
index 66259318c8..dae9a0cce1 100644
--- a/testsuites/validation/tc-intr-handler-iterate.c
+++ b/testsuites/validation/tc-intr-handler-iterate.c
@@ -288,7 +288,7 @@ static void Action( void *arg )
ctx->visited_entries = 0;
ctx->initialized
@@ -299,7 +299,7 @@ static void Action( void *arg )
2.35.3
