[PATCH] bsps/zynqmp: Fix and update device trees
Kinsey Moore
kinsey.moore at oarcorp.com
Mon Dec 5 23:27:28 UTC 2022
Add ref-clock-num identifiers to the device tree to ensure that
interfaces use the correct clocks even when some are not used due to
unconnected MII busses. This also adjusts the default ZynqMP PHY
attachment to RGMII-ID which was the default before device trees were
introduced.
bsps/aarch64/xilinx-zynqmp/fdt/cfc400x.dts | 4 +
bsps/aarch64/xilinx-zynqmp/fdt/cfc400x_dtb.c | 132 ++++++++++---------
bsps/aarch64/xilinx-zynqmp/fdt/zynqmp.dts | 12 +-
bsps/aarch64/xilinx-zynqmp/fdt/zynqmp_dtb.c | 104 ++++++++-------
4 files changed, 137 insertions(+), 115 deletions(-)
diff --git a/bsps/aarch64/xilinx-zynqmp/fdt/cfc400x.dts b/bsps/aarch64/xilinx-zynqmp/fdt/cfc400x.dts
index 763a668a5c..05647e0848 100644
--- a/bsps/aarch64/xilinx-zynqmp/fdt/cfc400x.dts
+++ b/bsps/aarch64/xilinx-zynqmp/fdt/cfc400x.dts
@@ -62,6 +62,7 @@
interrupts = <0x00 0x39 0x04>;
reg = <0x00 0xff0b0000 0x00 0x1000>;
phy-mode = "sgmii";
+ ref-clock-num = <0>;
ethernet at ff0c0000 {
@@ -71,6 +72,7 @@
interrupts = <0x00 0x3b 0x04>;
reg = <0x00 0xff0c0000 0x00 0x1000>;
phy-mode = "sgmii";
+ ref-clock-num = <1>;
ethernet at ff0d0000 {
@@ -80,6 +82,7 @@
interrupts = <0x00 0x3d 0x04>;
reg = <0x00 0xff0d0000 0x00 0x1000>;
phy-mode = "sgmii";
+ ref-clock-num = <2>;
ethernet at ff0e0000 {
@@ -89,6 +92,7 @@
interrupts = <0x00 0x3f 0x04>;
reg = <0x00 0xff0e0000 0x00 0x1000>;
phy-mode = "sgmii";
+ ref-clock-num = <3>;
serial at 800a0000 {
diff --git a/bsps/aarch64/xilinx-zynqmp/fdt/cfc400x_dtb.c b/bsps/aarch64/xilinx-zynqmp/fdt/cfc400x_dtb.c
index 2d0078678e..7a45b4f7dd 100644
--- a/bsps/aarch64/xilinx-zynqmp/fdt/cfc400x_dtb.c
+++ b/bsps/aarch64/xilinx-zynqmp/fdt/cfc400x_dtb.c
@@ -1,8 +1,8 @@
unsigned char zynqmp_dtb[] = {
- 0xd0, 0x0d, 0xfe, 0xed, 0x00, 0x00, 0x05, 0xa3, 0x00, 0x00, 0x00, 0x38,
- 0x00, 0x00, 0x04, 0xd0, 0x00, 0x00, 0x00, 0x28, 0x00, 0x00, 0x00, 0x11,
- 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xd3,
- 0x00, 0x00, 0x04, 0x98, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
+ 0xd0, 0x0d, 0xfe, 0xed, 0x00, 0x00, 0x05, 0xf1, 0x00, 0x00, 0x00, 0x38,
+ 0x00, 0x00, 0x05, 0x10, 0x00, 0x00, 0x00, 0x28, 0x00, 0x00, 0x00, 0x11,
+ 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xe1,
+ 0x00, 0x00, 0x04, 0xd8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x03,
@@ -39,33 +39,37 @@ unsigned char zynqmp_dtb[] = {
0x00, 0x00, 0x00, 0x3e, 0x00, 0x00, 0x00, 0x00, 0xff, 0x0b, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x03,
0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x82, 0x73, 0x67, 0x6d, 0x69,
- 0x69, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
- 0x65, 0x74, 0x68, 0x65, 0x72, 0x6e, 0x65, 0x74, 0x40, 0x66, 0x66, 0x30,
- 0x63, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
- 0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0x1b, 0x63, 0x64, 0x6e, 0x73,
- 0x2c, 0x67, 0x65, 0x6d, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
- 0x00, 0x00, 0x00, 0x05, 0x00, 0x00, 0x00, 0x5f, 0x6f, 0x6b, 0x61, 0x79,
- 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
- 0x00, 0x00, 0x00, 0x66, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03,
- 0x00, 0x00, 0x00, 0x0c, 0x00, 0x00, 0x00, 0x77, 0x00, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0x3b, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x03,
- 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x3e, 0x00, 0x00, 0x00, 0x00,
- 0xff, 0x0c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x00,
- 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x82,
- 0x73, 0x67, 0x6d, 0x69, 0x69, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02,
+ 0x69, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+ 0x00, 0x00, 0x00, 0x8b, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02,
0x00, 0x00, 0x00, 0x01, 0x65, 0x74, 0x68, 0x65, 0x72, 0x6e, 0x65, 0x74,
- 0x40, 0x66, 0x66, 0x30, 0x64, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00,
+ 0x40, 0x66, 0x66, 0x30, 0x63, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0x1b,
0x63, 0x64, 0x6e, 0x73, 0x2c, 0x67, 0x65, 0x6d, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x05, 0x00, 0x00, 0x00, 0x5f,
0x6f, 0x6b, 0x61, 0x79, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x66, 0x00, 0x00, 0x00, 0x01,
0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x0c, 0x00, 0x00, 0x00, 0x77,
- 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3d, 0x00, 0x00, 0x00, 0x04,
+ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3b, 0x00, 0x00, 0x00, 0x04,
0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x3e,
- 0x00, 0x00, 0x00, 0x00, 0xff, 0x0d, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
+ 0x00, 0x00, 0x00, 0x00, 0xff, 0x0c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x06,
0x00, 0x00, 0x00, 0x82, 0x73, 0x67, 0x6d, 0x69, 0x69, 0x00, 0x00, 0x00,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x8b,
+ 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
+ 0x65, 0x74, 0x68, 0x65, 0x72, 0x6e, 0x65, 0x74, 0x40, 0x66, 0x66, 0x30,
+ 0x64, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0x1b, 0x63, 0x64, 0x6e, 0x73,
+ 0x2c, 0x67, 0x65, 0x6d, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x05, 0x00, 0x00, 0x00, 0x5f, 0x6f, 0x6b, 0x61, 0x79,
+ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+ 0x00, 0x00, 0x00, 0x66, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x0c, 0x00, 0x00, 0x00, 0x77, 0x00, 0x00, 0x00, 0x00,
+ 0x00, 0x00, 0x00, 0x3d, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x3e, 0x00, 0x00, 0x00, 0x00,
+ 0xff, 0x0d, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x00,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x82,
+ 0x73, 0x67, 0x6d, 0x69, 0x69, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x8b, 0x00, 0x00, 0x00, 0x02,
0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x65, 0x74, 0x68, 0x65,
0x72, 0x6e, 0x65, 0x74, 0x40, 0x66, 0x66, 0x30, 0x65, 0x30, 0x30, 0x30,
0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x09,
@@ -79,46 +83,48 @@ unsigned char zynqmp_dtb[] = {
0x00, 0x00, 0x00, 0x3e, 0x00, 0x00, 0x00, 0x00, 0xff, 0x0e, 0x00, 0x00,
- 0x73, 0x65, 0x72, 0x69, 0x61, 0x6c, 0x40, 0x38, 0x30, 0x30, 0x61, 0x30,
- 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
- 0x00, 0x00, 0x00, 0x8b, 0x01, 0x89, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x03,
- 0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0x1b, 0x6e, 0x73, 0x31, 0x36,
- 0x35, 0x35, 0x30, 0x61, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
- 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x9b, 0x00, 0x01, 0xc2, 0x00,
- 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0xa9,
- 0x73, 0x65, 0x72, 0x69, 0x61, 0x6c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
- 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x66, 0x00, 0x00, 0x00, 0x01,
- 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x0c, 0x00, 0x00, 0x00, 0x77,
- 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x6e, 0x00, 0x00, 0x00, 0x04,
- 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x3e,
- 0x00, 0x00, 0x00, 0x00, 0x80, 0x0a, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
- 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
- 0x00, 0x00, 0x00, 0xb5, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x03,
- 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xc0, 0x00, 0x00, 0x00, 0x02,
- 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
- 0x61, 0x6c, 0x69, 0x61, 0x73, 0x65, 0x73, 0x00, 0x00, 0x00, 0x00, 0x03,
- 0x00, 0x00, 0x00, 0x16, 0x00, 0x00, 0x00, 0xca, 0x2f, 0x61, 0x6d, 0x62,
- 0x61, 0x2f, 0x73, 0x65, 0x72, 0x69, 0x61, 0x6c, 0x40, 0x38, 0x30, 0x30,
- 0x61, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02,
- 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x09, 0x23, 0x61, 0x64, 0x64,
- 0x72, 0x65, 0x73, 0x73, 0x2d, 0x63, 0x65, 0x6c, 0x6c, 0x73, 0x00, 0x23,
- 0x73, 0x69, 0x7a, 0x65, 0x2d, 0x63, 0x65, 0x6c, 0x6c, 0x73, 0x00, 0x63,
- 0x6f, 0x6d, 0x70, 0x61, 0x74, 0x69, 0x62, 0x6c, 0x65, 0x00, 0x72, 0x61,
- 0x6e, 0x67, 0x65, 0x73, 0x00, 0x23, 0x69, 0x6e, 0x74, 0x65, 0x72, 0x72,
- 0x75, 0x70, 0x74, 0x2d, 0x63, 0x65, 0x6c, 0x6c, 0x73, 0x00, 0x72, 0x65,
- 0x67, 0x00, 0x69, 0x6e, 0x74, 0x65, 0x72, 0x72, 0x75, 0x70, 0x74, 0x2d,
- 0x63, 0x6f, 0x6e, 0x74, 0x72, 0x6f, 0x6c, 0x6c, 0x65, 0x72, 0x00, 0x70,
- 0x68, 0x61, 0x6e, 0x64, 0x6c, 0x65, 0x00, 0x73, 0x74, 0x61, 0x74, 0x75,
- 0x73, 0x00, 0x69, 0x6e, 0x74, 0x65, 0x72, 0x72, 0x75, 0x70, 0x74, 0x2d,
- 0x70, 0x61, 0x72, 0x65, 0x6e, 0x74, 0x00, 0x69, 0x6e, 0x74, 0x65, 0x72,
- 0x72, 0x75, 0x70, 0x74, 0x73, 0x00, 0x70, 0x68, 0x79, 0x2d, 0x6d, 0x6f,
- 0x64, 0x65, 0x00, 0x63, 0x6c, 0x6f, 0x63, 0x6b, 0x2d, 0x66, 0x72, 0x65,
- 0x71, 0x75, 0x65, 0x6e, 0x63, 0x79, 0x00, 0x63, 0x75, 0x72, 0x72, 0x65,
- 0x6e, 0x74, 0x2d, 0x73, 0x70, 0x65, 0x65, 0x64, 0x00, 0x64, 0x65, 0x76,
- 0x69, 0x63, 0x65, 0x5f, 0x74, 0x79, 0x70, 0x65, 0x00, 0x72, 0x65, 0x67,
- 0x2d, 0x6f, 0x66, 0x66, 0x73, 0x65, 0x74, 0x00, 0x72, 0x65, 0x67, 0x2d,
- 0x73, 0x68, 0x69, 0x66, 0x74, 0x00, 0x6d, 0x67, 0x6d, 0x74, 0x70, 0x6f,
- 0x72, 0x74, 0x00
+ 0x00, 0x00, 0x00, 0x8b, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x02,
+ 0x00, 0x00, 0x00, 0x01, 0x73, 0x65, 0x72, 0x69, 0x61, 0x6c, 0x40, 0x38,
+ 0x30, 0x30, 0x61, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x99, 0x01, 0x89, 0xc0, 0x00,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0x1b,
+ 0x6e, 0x73, 0x31, 0x36, 0x35, 0x35, 0x30, 0x61, 0x00, 0x00, 0x00, 0x00,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xa9,
+ 0x00, 0x01, 0xc2, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x07,
+ 0x00, 0x00, 0x00, 0xb7, 0x73, 0x65, 0x72, 0x69, 0x61, 0x6c, 0x00, 0x00,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x66,
+ 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x0c,
+ 0x00, 0x00, 0x00, 0x77, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x6e,
+ 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x10,
+ 0x00, 0x00, 0x00, 0x3e, 0x00, 0x00, 0x00, 0x00, 0x80, 0x0a, 0x00, 0x00,
+ 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xc3, 0x00, 0x00, 0x10, 0x00,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xce,
+ 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x02,
+ 0x00, 0x00, 0x00, 0x01, 0x61, 0x6c, 0x69, 0x61, 0x73, 0x65, 0x73, 0x00,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x16, 0x00, 0x00, 0x00, 0xd8,
+ 0x2f, 0x61, 0x6d, 0x62, 0x61, 0x2f, 0x73, 0x65, 0x72, 0x69, 0x61, 0x6c,
+ 0x40, 0x38, 0x30, 0x30, 0x61, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00,
+ 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x09,
+ 0x23, 0x61, 0x64, 0x64, 0x72, 0x65, 0x73, 0x73, 0x2d, 0x63, 0x65, 0x6c,
+ 0x6c, 0x73, 0x00, 0x23, 0x73, 0x69, 0x7a, 0x65, 0x2d, 0x63, 0x65, 0x6c,
+ 0x6c, 0x73, 0x00, 0x63, 0x6f, 0x6d, 0x70, 0x61, 0x74, 0x69, 0x62, 0x6c,
+ 0x65, 0x00, 0x72, 0x61, 0x6e, 0x67, 0x65, 0x73, 0x00, 0x23, 0x69, 0x6e,
+ 0x74, 0x65, 0x72, 0x72, 0x75, 0x70, 0x74, 0x2d, 0x63, 0x65, 0x6c, 0x6c,
+ 0x73, 0x00, 0x72, 0x65, 0x67, 0x00, 0x69, 0x6e, 0x74, 0x65, 0x72, 0x72,
+ 0x75, 0x70, 0x74, 0x2d, 0x63, 0x6f, 0x6e, 0x74, 0x72, 0x6f, 0x6c, 0x6c,
+ 0x65, 0x72, 0x00, 0x70, 0x68, 0x61, 0x6e, 0x64, 0x6c, 0x65, 0x00, 0x73,
+ 0x74, 0x61, 0x74, 0x75, 0x73, 0x00, 0x69, 0x6e, 0x74, 0x65, 0x72, 0x72,
+ 0x75, 0x70, 0x74, 0x2d, 0x70, 0x61, 0x72, 0x65, 0x6e, 0x74, 0x00, 0x69,
+ 0x6e, 0x74, 0x65, 0x72, 0x72, 0x75, 0x70, 0x74, 0x73, 0x00, 0x70, 0x68,
+ 0x79, 0x2d, 0x6d, 0x6f, 0x64, 0x65, 0x00, 0x72, 0x65, 0x66, 0x2d, 0x63,
+ 0x6c, 0x6f, 0x63, 0x6b, 0x2d, 0x6e, 0x75, 0x6d, 0x00, 0x63, 0x6c, 0x6f,
+ 0x63, 0x6b, 0x2d, 0x66, 0x72, 0x65, 0x71, 0x75, 0x65, 0x6e, 0x63, 0x79,
+ 0x00, 0x63, 0x75, 0x72, 0x72, 0x65, 0x6e, 0x74, 0x2d, 0x73, 0x70, 0x65,
+ 0x65, 0x64, 0x00, 0x64, 0x65, 0x76, 0x69, 0x63, 0x65, 0x5f, 0x74, 0x79,
+ 0x70, 0x65, 0x00, 0x72, 0x65, 0x67, 0x2d, 0x6f, 0x66, 0x66, 0x73, 0x65,
+ 0x74, 0x00, 0x72, 0x65, 0x67, 0x2d, 0x73, 0x68, 0x69, 0x66, 0x74, 0x00,
+ 0x6d, 0x67, 0x6d, 0x74, 0x70, 0x6f, 0x72, 0x74, 0x00
-unsigned int zynqmp_dtb_len = 1443;
+unsigned int zynqmp_dtb_len = 1521;
diff --git a/bsps/aarch64/xilinx-zynqmp/fdt/zynqmp.dts b/bsps/aarch64/xilinx-zynqmp/fdt/zynqmp.dts
index 65c7dcbba8..ec13563072 100644
--- a/bsps/aarch64/xilinx-zynqmp/fdt/zynqmp.dts
+++ b/bsps/aarch64/xilinx-zynqmp/fdt/zynqmp.dts
@@ -61,7 +61,8 @@
interrupt-parent = <0x01>;
- phy-mode = "sgmii";
+ phy-mode = "rgmii-id";
@@ -70,7 +71,8 @@
@@ -79,7 +81,8 @@
@@ -88,7 +91,8 @@
diff --git a/bsps/aarch64/xilinx-zynqmp/fdt/zynqmp_dtb.c b/bsps/aarch64/xilinx-zynqmp/fdt/zynqmp_dtb.c
index 955bc5f154..677dca3ea4 100644
--- a/bsps/aarch64/xilinx-zynqmp/fdt/zynqmp_dtb.c
+++ b/bsps/aarch64/xilinx-zynqmp/fdt/zynqmp_dtb.c
@@ -1,8 +1,8 @@
- 0xd0, 0x0d, 0xfe, 0xed, 0x00, 0x00, 0x04, 0x5f, 0x00, 0x00, 0x00, 0x38,
- 0x00, 0x00, 0x03, 0xd4, 0x00, 0x00, 0x00, 0x28, 0x00, 0x00, 0x00, 0x11,
- 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x8b,
- 0x00, 0x00, 0x03, 0x9c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
+ 0xd0, 0x0d, 0xfe, 0xed, 0x00, 0x00, 0x04, 0xbd, 0x00, 0x00, 0x00, 0x38,
+ 0x00, 0x00, 0x04, 0x24, 0x00, 0x00, 0x00, 0x28, 0x00, 0x00, 0x00, 0x11,
+ 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x99,
+ 0x00, 0x00, 0x03, 0xec, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
@@ -38,34 +38,39 @@ unsigned char zynqmp_dtb[] = {
- 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x82, 0x73, 0x67, 0x6d, 0x69,
- 0x00, 0x00, 0x00, 0x01, 0x65, 0x74, 0x68, 0x65, 0x72, 0x6e, 0x65, 0x74,
- 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0x1b,
- 0x63, 0x64, 0x6e, 0x73, 0x2c, 0x67, 0x65, 0x6d, 0x00, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x05, 0x00, 0x00, 0x00, 0x5f,
- 0x6f, 0x6b, 0x61, 0x79, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
- 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x06,
- 0x00, 0x00, 0x00, 0x82, 0x73, 0x67, 0x6d, 0x69, 0x69, 0x00, 0x00, 0x00,
+ 0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0x82, 0x72, 0x67, 0x6d, 0x69,
+ 0x69, 0x2d, 0x69, 0x64, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x8b, 0x00, 0x00, 0x00, 0x00,
+ 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x65, 0x74, 0x68, 0x65,
+ 0x72, 0x6e, 0x65, 0x74, 0x40, 0x66, 0x66, 0x30, 0x63, 0x30, 0x30, 0x30,
+ 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x09,
+ 0x00, 0x00, 0x00, 0x1b, 0x63, 0x64, 0x6e, 0x73, 0x2c, 0x67, 0x65, 0x6d,
+ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x05,
+ 0x00, 0x00, 0x00, 0x5f, 0x6f, 0x6b, 0x61, 0x79, 0x00, 0x00, 0x00, 0x00,
+ 0x00, 0x00, 0x00, 0x77, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3b,
+ 0x00, 0x00, 0x00, 0x3e, 0x00, 0x00, 0x00, 0x00, 0xff, 0x0c, 0x00, 0x00,
+ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x8b, 0x00, 0x00, 0x00, 0x01,
+ 0x72, 0x6e, 0x65, 0x74, 0x40, 0x66, 0x66, 0x30, 0x64, 0x30, 0x30, 0x30,
+ 0x00, 0x00, 0x00, 0x77, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3d,
+ 0x00, 0x00, 0x00, 0x3e, 0x00, 0x00, 0x00, 0x00, 0xff, 0x0d, 0x00, 0x00,
@@ -78,20 +83,23 @@ unsigned char zynqmp_dtb[] = {
- 0x69, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x02,
- 0x64, 0x65, 0x00
+ 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x8b, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x09, 0x23, 0x61, 0x64, 0x64, 0x72, 0x65, 0x73, 0x73,
+ 0x2d, 0x63, 0x65, 0x6c, 0x6c, 0x73, 0x00, 0x23, 0x73, 0x69, 0x7a, 0x65,
+ 0x2d, 0x63, 0x65, 0x6c, 0x6c, 0x73, 0x00, 0x63, 0x6f, 0x6d, 0x70, 0x61,
+ 0x74, 0x69, 0x62, 0x6c, 0x65, 0x00, 0x72, 0x61, 0x6e, 0x67, 0x65, 0x73,
+ 0x00, 0x23, 0x69, 0x6e, 0x74, 0x65, 0x72, 0x72, 0x75, 0x70, 0x74, 0x2d,
+ 0x63, 0x65, 0x6c, 0x6c, 0x73, 0x00, 0x72, 0x65, 0x67, 0x00, 0x69, 0x6e,
+ 0x74, 0x65, 0x72, 0x72, 0x75, 0x70, 0x74, 0x2d, 0x63, 0x6f, 0x6e, 0x74,
+ 0x72, 0x6f, 0x6c, 0x6c, 0x65, 0x72, 0x00, 0x70, 0x68, 0x61, 0x6e, 0x64,
+ 0x6c, 0x65, 0x00, 0x73, 0x74, 0x61, 0x74, 0x75, 0x73, 0x00, 0x69, 0x6e,
+ 0x74, 0x65, 0x72, 0x72, 0x75, 0x70, 0x74, 0x2d, 0x70, 0x61, 0x72, 0x65,
+ 0x6e, 0x74, 0x00, 0x69, 0x6e, 0x74, 0x65, 0x72, 0x72, 0x75, 0x70, 0x74,
+ 0x73, 0x00, 0x70, 0x68, 0x79, 0x2d, 0x6d, 0x6f, 0x64, 0x65, 0x00, 0x72,
+ 0x65, 0x66, 0x2d, 0x63, 0x6c, 0x6f, 0x63, 0x6b, 0x2d, 0x6e, 0x75, 0x6d,
+ 0x00
-unsigned int zynqmp_dtb_len = 1119;
+unsigned int zynqmp_dtb_len = 1213;
2.30.2
