[PATCH] bsps/zynqmp: Fix and update device trees
Chris Johns
chrisj at rtems.org
Tue Dec 6 03:48:46 UTC 2022
I am still seeing issues with this change. The interface is `cgem0` and not
`cgem3`. I have confirmed I have the same RTEMS hash in the build. Is there
anything I need to set up to have the FDT be seem by libbsd?
On 6/12/2022 10:27 am, Kinsey Moore wrote:
> Add ref-clock-num identifiers to the device tree to ensure that
> interfaces use the correct clocks even when some are not used due to
> unconnected MII busses. This also adjusts the default ZynqMP PHY
> attachment to RGMII-ID which was the default before device trees were
> introduced.
> bsps/aarch64/xilinx-zynqmp/fdt/cfc400x.dts | 4 +
> bsps/aarch64/xilinx-zynqmp/fdt/cfc400x_dtb.c | 132 ++++++++++---------
> bsps/aarch64/xilinx-zynqmp/fdt/zynqmp.dts | 12 +-
> bsps/aarch64/xilinx-zynqmp/fdt/zynqmp_dtb.c | 104 ++++++++-------
> 4 files changed, 137 insertions(+), 115 deletions(-)
> diff --git a/bsps/aarch64/xilinx-zynqmp/fdt/cfc400x.dts b/bsps/aarch64/xilinx-zynqmp/fdt/cfc400x.dts
> index 763a668a5c..05647e0848 100644
> --- a/bsps/aarch64/xilinx-zynqmp/fdt/cfc400x.dts
> +++ b/bsps/aarch64/xilinx-zynqmp/fdt/cfc400x.dts
> @@ -62,6 +62,7 @@
> interrupts = <0x00 0x39 0x04>;
> reg = <0x00 0xff0b0000 0x00 0x1000>;
> phy-mode = "sgmii";
> + ref-clock-num = <0>;
> ethernet at ff0c0000 {
> @@ -71,6 +72,7 @@
> interrupts = <0x00 0x3b 0x04>;
> reg = <0x00 0xff0c0000 0x00 0x1000>;
> phy-mode = "sgmii";
> + ref-clock-num = <1>;
> ethernet at ff0d0000 {
> @@ -80,6 +82,7 @@
> interrupts = <0x00 0x3d 0x04>;
> reg = <0x00 0xff0d0000 0x00 0x1000>;
> phy-mode = "sgmii";
> + ref-clock-num = <2>;
> ethernet at ff0e0000 {
> @@ -89,6 +92,7 @@
> interrupts = <0x00 0x3f 0x04>;
> reg = <0x00 0xff0e0000 0x00 0x1000>;
> phy-mode = "sgmii";
> + ref-clock-num = <3>;
> serial at 800a0000 {
> diff --git a/bsps/aarch64/xilinx-zynqmp/fdt/cfc400x_dtb.c b/bsps/aarch64/xilinx-zynqmp/fdt/cfc400x_dtb.c
> index 2d0078678e..7a45b4f7dd 100644
> --- a/bsps/aarch64/xilinx-zynqmp/fdt/cfc400x_dtb.c
> +++ b/bsps/aarch64/xilinx-zynqmp/fdt/cfc400x_dtb.c
> @@ -1,8 +1,8 @@
> unsigned char zynqmp_dtb[] = {
> - 0xd0, 0x0d, 0xfe, 0xed, 0x00, 0x00, 0x05, 0xa3, 0x00, 0x00, 0x00, 0x38,
> - 0x00, 0x00, 0x04, 0xd0, 0x00, 0x00, 0x00, 0x28, 0x00, 0x00, 0x00, 0x11,
> - 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xd3,
> - 0x00, 0x00, 0x04, 0x98, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
> + 0xd0, 0x0d, 0xfe, 0xed, 0x00, 0x00, 0x05, 0xf1, 0x00, 0x00, 0x00, 0x38,
> + 0x00, 0x00, 0x05, 0x10, 0x00, 0x00, 0x00, 0x28, 0x00, 0x00, 0x00, 0x11,
> + 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xe1,
> + 0x00, 0x00, 0x04, 0xd8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
> 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
> 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
> 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x03,
> @@ -39,33 +39,37 @@ unsigned char zynqmp_dtb[] = {
> 0x00, 0x00, 0x00, 0x3e, 0x00, 0x00, 0x00, 0x00, 0xff, 0x0b, 0x00, 0x00,
> 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x03,
> 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x82, 0x73, 0x67, 0x6d, 0x69,
> - 0x69, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
> - 0x65, 0x74, 0x68, 0x65, 0x72, 0x6e, 0x65, 0x74, 0x40, 0x66, 0x66, 0x30,
> - 0x63, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
> - 0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0x1b, 0x63, 0x64, 0x6e, 0x73,
> - 0x2c, 0x67, 0x65, 0x6d, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
> - 0x00, 0x00, 0x00, 0x05, 0x00, 0x00, 0x00, 0x5f, 0x6f, 0x6b, 0x61, 0x79,
> - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
> - 0x00, 0x00, 0x00, 0x66, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03,
> - 0x00, 0x00, 0x00, 0x0c, 0x00, 0x00, 0x00, 0x77, 0x00, 0x00, 0x00, 0x00,
> - 0x00, 0x00, 0x00, 0x3b, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x03,
> - 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x3e, 0x00, 0x00, 0x00, 0x00,
> - 0xff, 0x0c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x00,
> - 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x82,
> - 0x73, 0x67, 0x6d, 0x69, 0x69, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02,
> + 0x69, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
> + 0x00, 0x00, 0x00, 0x8b, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02,
> 0x00, 0x00, 0x00, 0x01, 0x65, 0x74, 0x68, 0x65, 0x72, 0x6e, 0x65, 0x74,
> - 0x40, 0x66, 0x66, 0x30, 0x64, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00,
> + 0x40, 0x66, 0x66, 0x30, 0x63, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00,
> 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0x1b,
> 0x63, 0x64, 0x6e, 0x73, 0x2c, 0x67, 0x65, 0x6d, 0x00, 0x00, 0x00, 0x00,
> 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x05, 0x00, 0x00, 0x00, 0x5f,
> 0x6f, 0x6b, 0x61, 0x79, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
> 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x66, 0x00, 0x00, 0x00, 0x01,
> 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x0c, 0x00, 0x00, 0x00, 0x77,
> - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3d, 0x00, 0x00, 0x00, 0x04,
> + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3b, 0x00, 0x00, 0x00, 0x04,
> 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x3e,
> - 0x00, 0x00, 0x00, 0x00, 0xff, 0x0d, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
> + 0x00, 0x00, 0x00, 0x00, 0xff, 0x0c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
> 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x06,
> 0x00, 0x00, 0x00, 0x82, 0x73, 0x67, 0x6d, 0x69, 0x69, 0x00, 0x00, 0x00,
> + 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x8b,
> + 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
> + 0x65, 0x74, 0x68, 0x65, 0x72, 0x6e, 0x65, 0x74, 0x40, 0x66, 0x66, 0x30,
> + 0x64, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
> + 0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0x1b, 0x63, 0x64, 0x6e, 0x73,
> + 0x2c, 0x67, 0x65, 0x6d, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
> + 0x00, 0x00, 0x00, 0x05, 0x00, 0x00, 0x00, 0x5f, 0x6f, 0x6b, 0x61, 0x79,
> + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
> + 0x00, 0x00, 0x00, 0x66, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03,
> + 0x00, 0x00, 0x00, 0x0c, 0x00, 0x00, 0x00, 0x77, 0x00, 0x00, 0x00, 0x00,
> + 0x00, 0x00, 0x00, 0x3d, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x03,
> + 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x3e, 0x00, 0x00, 0x00, 0x00,
> + 0xff, 0x0d, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x00,
> + 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x82,
> + 0x73, 0x67, 0x6d, 0x69, 0x69, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
> + 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x8b, 0x00, 0x00, 0x00, 0x02,
> 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x65, 0x74, 0x68, 0x65,
> 0x72, 0x6e, 0x65, 0x74, 0x40, 0x66, 0x66, 0x30, 0x65, 0x30, 0x30, 0x30,
> 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x09,
> @@ -79,46 +83,48 @@ unsigned char zynqmp_dtb[] = {
> 0x00, 0x00, 0x00, 0x3e, 0x00, 0x00, 0x00, 0x00, 0xff, 0x0e, 0x00, 0x00,
> - 0x73, 0x65, 0x72, 0x69, 0x61, 0x6c, 0x40, 0x38, 0x30, 0x30, 0x61, 0x30,
> - 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
> - 0x00, 0x00, 0x00, 0x8b, 0x01, 0x89, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x03,
> - 0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0x1b, 0x6e, 0x73, 0x31, 0x36,
> - 0x35, 0x35, 0x30, 0x61, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
> - 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x9b, 0x00, 0x01, 0xc2, 0x00,
> - 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0xa9,
> - 0x73, 0x65, 0x72, 0x69, 0x61, 0x6c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
> - 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x66, 0x00, 0x00, 0x00, 0x01,
> - 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x0c, 0x00, 0x00, 0x00, 0x77,
> - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x6e, 0x00, 0x00, 0x00, 0x04,
> - 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x3e,
> - 0x00, 0x00, 0x00, 0x00, 0x80, 0x0a, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
> - 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
> - 0x00, 0x00, 0x00, 0xb5, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x03,
> - 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xc0, 0x00, 0x00, 0x00, 0x02,
> - 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
> - 0x61, 0x6c, 0x69, 0x61, 0x73, 0x65, 0x73, 0x00, 0x00, 0x00, 0x00, 0x03,
> - 0x00, 0x00, 0x00, 0x16, 0x00, 0x00, 0x00, 0xca, 0x2f, 0x61, 0x6d, 0x62,
> - 0x61, 0x2f, 0x73, 0x65, 0x72, 0x69, 0x61, 0x6c, 0x40, 0x38, 0x30, 0x30,
> - 0x61, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02,
> - 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x09, 0x23, 0x61, 0x64, 0x64,
> - 0x72, 0x65, 0x73, 0x73, 0x2d, 0x63, 0x65, 0x6c, 0x6c, 0x73, 0x00, 0x23,
> - 0x73, 0x69, 0x7a, 0x65, 0x2d, 0x63, 0x65, 0x6c, 0x6c, 0x73, 0x00, 0x63,
> - 0x6f, 0x6d, 0x70, 0x61, 0x74, 0x69, 0x62, 0x6c, 0x65, 0x00, 0x72, 0x61,
> - 0x6e, 0x67, 0x65, 0x73, 0x00, 0x23, 0x69, 0x6e, 0x74, 0x65, 0x72, 0x72,
> - 0x75, 0x70, 0x74, 0x2d, 0x63, 0x65, 0x6c, 0x6c, 0x73, 0x00, 0x72, 0x65,
> - 0x67, 0x00, 0x69, 0x6e, 0x74, 0x65, 0x72, 0x72, 0x75, 0x70, 0x74, 0x2d,
> - 0x63, 0x6f, 0x6e, 0x74, 0x72, 0x6f, 0x6c, 0x6c, 0x65, 0x72, 0x00, 0x70,
> - 0x68, 0x61, 0x6e, 0x64, 0x6c, 0x65, 0x00, 0x73, 0x74, 0x61, 0x74, 0x75,
> - 0x73, 0x00, 0x69, 0x6e, 0x74, 0x65, 0x72, 0x72, 0x75, 0x70, 0x74, 0x2d,
> - 0x70, 0x61, 0x72, 0x65, 0x6e, 0x74, 0x00, 0x69, 0x6e, 0x74, 0x65, 0x72,
> - 0x72, 0x75, 0x70, 0x74, 0x73, 0x00, 0x70, 0x68, 0x79, 0x2d, 0x6d, 0x6f,
> - 0x64, 0x65, 0x00, 0x63, 0x6c, 0x6f, 0x63, 0x6b, 0x2d, 0x66, 0x72, 0x65,
> - 0x71, 0x75, 0x65, 0x6e, 0x63, 0x79, 0x00, 0x63, 0x75, 0x72, 0x72, 0x65,
> - 0x6e, 0x74, 0x2d, 0x73, 0x70, 0x65, 0x65, 0x64, 0x00, 0x64, 0x65, 0x76,
> - 0x69, 0x63, 0x65, 0x5f, 0x74, 0x79, 0x70, 0x65, 0x00, 0x72, 0x65, 0x67,
> - 0x2d, 0x6f, 0x66, 0x66, 0x73, 0x65, 0x74, 0x00, 0x72, 0x65, 0x67, 0x2d,
> - 0x73, 0x68, 0x69, 0x66, 0x74, 0x00, 0x6d, 0x67, 0x6d, 0x74, 0x70, 0x6f,
> - 0x72, 0x74, 0x00
> + 0x00, 0x00, 0x00, 0x8b, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x02,
> + 0x00, 0x00, 0x00, 0x01, 0x73, 0x65, 0x72, 0x69, 0x61, 0x6c, 0x40, 0x38,
> + 0x30, 0x30, 0x61, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x03,
> + 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x99, 0x01, 0x89, 0xc0, 0x00,
> + 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0x1b,
> + 0x6e, 0x73, 0x31, 0x36, 0x35, 0x35, 0x30, 0x61, 0x00, 0x00, 0x00, 0x00,
> + 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xa9,
> + 0x00, 0x01, 0xc2, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x07,
> + 0x00, 0x00, 0x00, 0xb7, 0x73, 0x65, 0x72, 0x69, 0x61, 0x6c, 0x00, 0x00,
> + 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x66,
> + 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x0c,
> + 0x00, 0x00, 0x00, 0x77, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x6e,
> + 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x10,
> + 0x00, 0x00, 0x00, 0x3e, 0x00, 0x00, 0x00, 0x00, 0x80, 0x0a, 0x00, 0x00,
> + 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
> + 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xc3, 0x00, 0x00, 0x10, 0x00,
> + 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xce,
> + 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x02,
> + 0x00, 0x00, 0x00, 0x01, 0x61, 0x6c, 0x69, 0x61, 0x73, 0x65, 0x73, 0x00,
> + 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x16, 0x00, 0x00, 0x00, 0xd8,
> + 0x2f, 0x61, 0x6d, 0x62, 0x61, 0x2f, 0x73, 0x65, 0x72, 0x69, 0x61, 0x6c,
> + 0x40, 0x38, 0x30, 0x30, 0x61, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00,
> + 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x09,
> + 0x23, 0x61, 0x64, 0x64, 0x72, 0x65, 0x73, 0x73, 0x2d, 0x63, 0x65, 0x6c,
> + 0x6c, 0x73, 0x00, 0x23, 0x73, 0x69, 0x7a, 0x65, 0x2d, 0x63, 0x65, 0x6c,
> + 0x6c, 0x73, 0x00, 0x63, 0x6f, 0x6d, 0x70, 0x61, 0x74, 0x69, 0x62, 0x6c,
> + 0x65, 0x00, 0x72, 0x61, 0x6e, 0x67, 0x65, 0x73, 0x00, 0x23, 0x69, 0x6e,
> + 0x74, 0x65, 0x72, 0x72, 0x75, 0x70, 0x74, 0x2d, 0x63, 0x65, 0x6c, 0x6c,
> + 0x73, 0x00, 0x72, 0x65, 0x67, 0x00, 0x69, 0x6e, 0x74, 0x65, 0x72, 0x72,
> + 0x75, 0x70, 0x74, 0x2d, 0x63, 0x6f, 0x6e, 0x74, 0x72, 0x6f, 0x6c, 0x6c,
> + 0x65, 0x72, 0x00, 0x70, 0x68, 0x61, 0x6e, 0x64, 0x6c, 0x65, 0x00, 0x73,
> + 0x74, 0x61, 0x74, 0x75, 0x73, 0x00, 0x69, 0x6e, 0x74, 0x65, 0x72, 0x72,
> + 0x75, 0x70, 0x74, 0x2d, 0x70, 0x61, 0x72, 0x65, 0x6e, 0x74, 0x00, 0x69,
> + 0x6e, 0x74, 0x65, 0x72, 0x72, 0x75, 0x70, 0x74, 0x73, 0x00, 0x70, 0x68,
> + 0x79, 0x2d, 0x6d, 0x6f, 0x64, 0x65, 0x00, 0x72, 0x65, 0x66, 0x2d, 0x63,
> + 0x6c, 0x6f, 0x63, 0x6b, 0x2d, 0x6e, 0x75, 0x6d, 0x00, 0x63, 0x6c, 0x6f,
> + 0x63, 0x6b, 0x2d, 0x66, 0x72, 0x65, 0x71, 0x75, 0x65, 0x6e, 0x63, 0x79,
> + 0x00, 0x63, 0x75, 0x72, 0x72, 0x65, 0x6e, 0x74, 0x2d, 0x73, 0x70, 0x65,
> + 0x65, 0x64, 0x00, 0x64, 0x65, 0x76, 0x69, 0x63, 0x65, 0x5f, 0x74, 0x79,
> + 0x70, 0x65, 0x00, 0x72, 0x65, 0x67, 0x2d, 0x6f, 0x66, 0x66, 0x73, 0x65,
> + 0x74, 0x00, 0x72, 0x65, 0x67, 0x2d, 0x73, 0x68, 0x69, 0x66, 0x74, 0x00,
> + 0x6d, 0x67, 0x6d, 0x74, 0x70, 0x6f, 0x72, 0x74, 0x00
> -unsigned int zynqmp_dtb_len = 1443;
> +unsigned int zynqmp_dtb_len = 1521;
> diff --git a/bsps/aarch64/xilinx-zynqmp/fdt/zynqmp.dts b/bsps/aarch64/xilinx-zynqmp/fdt/zynqmp.dts
> index 65c7dcbba8..ec13563072 100644
> --- a/bsps/aarch64/xilinx-zynqmp/fdt/zynqmp.dts
> +++ b/bsps/aarch64/xilinx-zynqmp/fdt/zynqmp.dts
> @@ -61,7 +61,8 @@
> interrupt-parent = <0x01>;
> - phy-mode = "sgmii";
> + phy-mode = "rgmii-id";
> @@ -70,7 +71,8 @@
> @@ -79,7 +81,8 @@
> @@ -88,7 +91,8 @@
> diff --git a/bsps/aarch64/xilinx-zynqmp/fdt/zynqmp_dtb.c b/bsps/aarch64/xilinx-zynqmp/fdt/zynqmp_dtb.c
> index 955bc5f154..677dca3ea4 100644
> --- a/bsps/aarch64/xilinx-zynqmp/fdt/zynqmp_dtb.c
> +++ b/bsps/aarch64/xilinx-zynqmp/fdt/zynqmp_dtb.c
> @@ -1,8 +1,8 @@
> - 0xd0, 0x0d, 0xfe, 0xed, 0x00, 0x00, 0x04, 0x5f, 0x00, 0x00, 0x00, 0x38,
> - 0x00, 0x00, 0x03, 0xd4, 0x00, 0x00, 0x00, 0x28, 0x00, 0x00, 0x00, 0x11,
> - 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x8b,
> - 0x00, 0x00, 0x03, 0x9c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
> + 0xd0, 0x0d, 0xfe, 0xed, 0x00, 0x00, 0x04, 0xbd, 0x00, 0x00, 0x00, 0x38,
> + 0x00, 0x00, 0x04, 0x24, 0x00, 0x00, 0x00, 0x28, 0x00, 0x00, 0x00, 0x11,
> + 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x99,
> + 0x00, 0x00, 0x03, 0xec, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
> @@ -38,34 +38,39 @@ unsigned char zynqmp_dtb[] = {
> - 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x82, 0x73, 0x67, 0x6d, 0x69,
> - 0x00, 0x00, 0x00, 0x01, 0x65, 0x74, 0x68, 0x65, 0x72, 0x6e, 0x65, 0x74,
> - 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0x1b,
> - 0x63, 0x64, 0x6e, 0x73, 0x2c, 0x67, 0x65, 0x6d, 0x00, 0x00, 0x00, 0x00,
> - 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x05, 0x00, 0x00, 0x00, 0x5f,
> - 0x6f, 0x6b, 0x61, 0x79, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
> - 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x06,
> - 0x00, 0x00, 0x00, 0x82, 0x73, 0x67, 0x6d, 0x69, 0x69, 0x00, 0x00, 0x00,
> + 0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0x82, 0x72, 0x67, 0x6d, 0x69,
> + 0x69, 0x2d, 0x69, 0x64, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
> + 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x8b, 0x00, 0x00, 0x00, 0x00,
> + 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x65, 0x74, 0x68, 0x65,
> + 0x72, 0x6e, 0x65, 0x74, 0x40, 0x66, 0x66, 0x30, 0x63, 0x30, 0x30, 0x30,
> + 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x09,
> + 0x00, 0x00, 0x00, 0x1b, 0x63, 0x64, 0x6e, 0x73, 0x2c, 0x67, 0x65, 0x6d,
> + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x05,
> + 0x00, 0x00, 0x00, 0x5f, 0x6f, 0x6b, 0x61, 0x79, 0x00, 0x00, 0x00, 0x00,
> + 0x00, 0x00, 0x00, 0x77, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3b,
> + 0x00, 0x00, 0x00, 0x3e, 0x00, 0x00, 0x00, 0x00, 0xff, 0x0c, 0x00, 0x00,
> + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x03,
> + 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x8b, 0x00, 0x00, 0x00, 0x01,
> + 0x72, 0x6e, 0x65, 0x74, 0x40, 0x66, 0x66, 0x30, 0x64, 0x30, 0x30, 0x30,
> + 0x00, 0x00, 0x00, 0x77, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3d,
> + 0x00, 0x00, 0x00, 0x3e, 0x00, 0x00, 0x00, 0x00, 0xff, 0x0d, 0x00, 0x00,
> @@ -78,20 +83,23 @@ unsigned char zynqmp_dtb[] = {
> - 0x69, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x02,
> - 0x64, 0x65, 0x00
> + 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x8b, 0x00, 0x00, 0x00, 0x03,
> + 0x00, 0x00, 0x00, 0x09, 0x23, 0x61, 0x64, 0x64, 0x72, 0x65, 0x73, 0x73,
> + 0x2d, 0x63, 0x65, 0x6c, 0x6c, 0x73, 0x00, 0x23, 0x73, 0x69, 0x7a, 0x65,
> + 0x2d, 0x63, 0x65, 0x6c, 0x6c, 0x73, 0x00, 0x63, 0x6f, 0x6d, 0x70, 0x61,
> + 0x74, 0x69, 0x62, 0x6c, 0x65, 0x00, 0x72, 0x61, 0x6e, 0x67, 0x65, 0x73,
> + 0x00, 0x23, 0x69, 0x6e, 0x74, 0x65, 0x72, 0x72, 0x75, 0x70, 0x74, 0x2d,
> + 0x63, 0x65, 0x6c, 0x6c, 0x73, 0x00, 0x72, 0x65, 0x67, 0x00, 0x69, 0x6e,
> + 0x74, 0x65, 0x72, 0x72, 0x75, 0x70, 0x74, 0x2d, 0x63, 0x6f, 0x6e, 0x74,
> + 0x72, 0x6f, 0x6c, 0x6c, 0x65, 0x72, 0x00, 0x70, 0x68, 0x61, 0x6e, 0x64,
> + 0x6c, 0x65, 0x00, 0x73, 0x74, 0x61, 0x74, 0x75, 0x73, 0x00, 0x69, 0x6e,
> + 0x74, 0x65, 0x72, 0x72, 0x75, 0x70, 0x74, 0x2d, 0x70, 0x61, 0x72, 0x65,
> + 0x6e, 0x74, 0x00, 0x69, 0x6e, 0x74, 0x65, 0x72, 0x72, 0x75, 0x70, 0x74,
> + 0x73, 0x00, 0x70, 0x68, 0x79, 0x2d, 0x6d, 0x6f, 0x64, 0x65, 0x00, 0x72,
> + 0x65, 0x66, 0x2d, 0x63, 0x6c, 0x6f, 0x63, 0x6b, 0x2d, 0x6e, 0x75, 0x6d,
> + 0x00
> -unsigned int zynqmp_dtb_len = 1119;
> +unsigned int zynqmp_dtb_len = 1213;
