Where can I get the kernel sources?
Heinz Junkes
junkes at fhi-berlin.mpg.de
Thu Feb 3 05:57:32 UTC 2022
I think I slept through the latest development. Sorry about that.
I wanted to integrate a pull request from Till (https://github.com/RTEMS/rtems/pull/41)
into rtems6. But unfortunately I can no longer find the sources.
$: git clone git://git.rtems.org/rtems.git kernel
$: cd kernel
$: ls c
ACKNOWLEDGEMENTS
I am used to this:
$: git checkout 5
Switched to branch '5'
Your branch is up to date with 'origin/5’.
$: ls c
acinclude.m4 ACKNOWLEDGEMENTS configure.ac Makefile.am src
I also saw this ticket (https://devel.rtems.org/ticket/4046):
Bootstrapping is going away with the new build system and until then the command in rtems.git should be used.
Unfortunately, I'm not getting anywhere with it.
How must/should I proceed?
Danke, Heinz
Fritz-Haber-Institut | Phone: (+49 30) 8413-4270
Heinz Junkes | Fax (G3+G4): (+49 30) 8413-5900
Faradayweg 4-6 | VC: 102220181216 at bjn.vc
D - 14195 Berlin | E-Mail: junkes at fhi-berlin.mpg.de
