Where can I get the kernel sources?
Thu Feb 3 07:05:18 UTC 2022
Hello Heinz,
On 03/02/2022 06:57, Heinz Junkes wrote:
> I think I slept through the latest development. Sorry about that.
> I wanted to integrate a pull request from Till (https://github.com/RTEMS/rtems/pull/41)
> into rtems6. But unfortunately I can no longer find the sources.
> $: git clone git://git.rtems.org/rtems.git kernel
> $: cd kernel
> $: ls c
> ACKNOWLEDGEMENTS
> I am used to this:
> $: git checkout 5
> Switched to branch '5'
> Your branch is up to date with 'origin/5’.
> $: ls c
> acinclude.m4  ACKNOWLEDGEMENTS  configure.ac  Makefile.am  src
> I also saw this ticket (https://devel.rtems.org/ticket/4046):
> Bootstrapping is going away with the new build system and until then the command in rtems.git should be used.
> Unfortunately, I'm not getting anywhere with it.
> How must/should I proceed?
the BSP sources are in "bsps" since RTEMS 5. In "c" is mostly the old
build system in RTEMS 5 which was removed in RTEMS 6.
I tried to rebase the pull request to RTEMS 6 (master), however, then I
noticed that the old network stack and all the network interface drivers
are not longer included in the RTEMS sources. The old network stack is
now in a separate repository:
https://git.rtems.org/rtems-net-legacy/
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
