[PATCH 1/2] bsp/atsam/i2c: Simplify driver
Christian Mauderer
christian.mauderer at embedded-brains.de
Tue Feb 8 10:03:59 UTC 2022
Do some clean ups. Remove superfluous variables. Eliminate some overly
complex logic (information about transfer and remaining bytes has been
tracked redundantly in multiple variables).
This patch doesn't change the behavior of the driver.
Update #4591
bsps/arm/atsam/i2c/atsam_i2c_bus.c | 92 +++++++++++---------------
bsps/arm/atsam/include/bsp/atsam-i2c.h | 22 +++---
2 files changed, 45 insertions(+), 69 deletions(-)
diff --git a/bsps/arm/atsam/i2c/atsam_i2c_bus.c b/bsps/arm/atsam/i2c/atsam_i2c_bus.c
index 4425975de8..22c63fca89 100644
--- a/bsps/arm/atsam/i2c/atsam_i2c_bus.c
+++ b/bsps/arm/atsam/i2c/atsam_i2c_bus.c
@@ -37,68 +37,67 @@ atsam_i2c_disable_interrupts(Twihs *regs)
static void
-atsam_i2c_set_transfer_status(transfer_desc *trans_desc, transfer_state state)
+atsam_i2c_set_transfer_status(atsam_i2c_bus *bus, transfer_state state)
- trans_desc->trans_state = state;
+ bus->trans_state = state;
static void
-atsam_i2c_continue_read(Twihs *regs, transfer_desc *trans_desc)
+atsam_i2c_continue_read(Twihs *regs, atsam_i2c_bus *bus)
- trans_desc->data[trans_desc->already_transferred] = TWI_ReadByte(regs);
- trans_desc->already_transferred++;
+ *bus->current_msg_byte = TWI_ReadByte(regs);
+ ++bus->current_msg_byte;
+ --bus->current_msg_todo;
/* check for transfer finish */
- if (trans_desc->already_transferred == trans_desc->data_size) {
- if (trans_desc->stop_request){
+ if (bus->current_msg_todo == 0) {
+ if (bus->stop_request){
TWI_DisableIt(regs, TWIHS_IDR_RXRDY);
TWI_EnableIt(regs, TWIHS_IER_TXCOMP);
- atsam_i2c_set_transfer_status(trans_desc, TX_RX_STOP_SENT);
+ atsam_i2c_set_transfer_status(bus, TX_RX_STOP_SENT);
} else {
- atsam_i2c_set_transfer_status(trans_desc, RX_CONT_MESSAGE_NEEDED);
+ atsam_i2c_set_transfer_status(bus, RX_CONT_MESSAGE_NEEDED);
/* Last byte? */
- else if ((trans_desc->already_transferred == (trans_desc->data_size - 1))
- && (trans_desc->stop_request)){
+ else if (bus->current_msg_todo == 1 && bus->stop_request) {
TWI_Stop(regs);
static bool
-atsam_i2c_is_state(transfer_desc *trans_desc, transfer_state state)
+atsam_i2c_is_state(atsam_i2c_bus *bus, transfer_state state)
- return (trans_desc->trans_state == state);
+ return (bus->trans_state == state);
static void
-atsam_i2c_continue_write(Twihs *regs, transfer_desc *trans_desc)
+atsam_i2c_continue_write(Twihs *regs, atsam_i2c_bus *bus)
/* Transfer finished ? */
TWI_DisableIt(regs, TWIHS_IDR_TXRDY);
TWI_SendSTOPCondition(regs);
} else {
- atsam_i2c_set_transfer_status(trans_desc, TX_CONT_MESSAGE_NEEDED);
+ atsam_i2c_set_transfer_status(bus, TX_CONT_MESSAGE_NEEDED);
/* Bytes remaining */
else {
- TWI_WriteByte(regs,
- trans_desc->data[trans_desc->already_transferred]);
+ TWI_WriteByte(regs, *bus->current_msg_byte);
static void
-atsam_i2c_finish_write_transfer(Twihs *regs, transfer_desc *trans_desc)
+atsam_i2c_finish_write_transfer(Twihs *regs)
TWI_ReadByte(regs);
TWI_DisableIt(regs, TWIHS_IDR_TXCOMP);
- trans_desc->status = 0;
static void
@@ -115,19 +114,6 @@ atsam_i2c_next_packet(atsam_i2c_bus *bus)
bus->current_msg_byte = msg->buf;
-static void
-atsam_i2c_set_td(atsam_i2c_bus *bus, uint32_t already_transferred,
- bool stop_needed)
- transfer_desc *trans_desc = &bus->trans_desc;
- trans_desc->status = ASYNC_STATUS_PENDING;
- trans_desc->data = bus->current_msg_byte;
- trans_desc->data_size = bus->current_msg_todo;
- trans_desc->already_transferred = already_transferred;
- trans_desc->stop_request = stop_needed;
static bool
atsam_i2c_set_address_size(const i2c_msg *msg)
@@ -186,6 +172,8 @@ atsam_i2c_setup_write_transfer(atsam_i2c_bus *bus, Twihs *regs, bool ctrl,
atsam_i2c_set_address_regs(regs, slave_addr, ctrl, false);
TWI_EnableIt(regs, TWIHS_IER_TXRDY);
@@ -197,8 +185,8 @@ atsam_i2c_setup_transfer(atsam_i2c_bus *bus, Twihs *regs)
uint32_t msg_todo = bus->msg_todo;
uint16_t slave_addr;
bool ten_bit_addr = false;
- uint32_t already_transferred;
bool stop_needed = true;
+ bool read;
ten_bit_addr = atsam_i2c_set_address_size(msgs);
@@ -206,22 +194,19 @@ atsam_i2c_setup_transfer(atsam_i2c_bus *bus, Twihs *regs)
stop_needed = false;
- bus->read = (msgs->flags & I2C_M_RD) != 0;
+ read = (msgs->flags & I2C_M_RD) != 0;
slave_addr = msgs->addr;
- already_transferred = (bus->read == true) ? 0 : 1;
- atsam_i2c_set_td(bus, already_transferred, stop_needed);
+ bus->stop_request = stop_needed;
- if (bus->read){
+ if (read){
if (bus->current_msg_todo == 1){
send_stop = true;
- atsam_i2c_set_transfer_status(trans_desc, RX_SEND_DATA);
+ atsam_i2c_set_transfer_status(bus, RX_SEND_DATA);
atsam_i2c_setup_read_transfer(regs, ten_bit_addr,
slave_addr, send_stop);
} else {
- atsam_i2c_set_transfer_status(trans_desc, TX_SEND_DATA);
+ atsam_i2c_set_transfer_status(bus, TX_SEND_DATA);
atsam_i2c_setup_write_transfer(bus, regs, ten_bit_addr,
slave_addr);
@@ -233,7 +218,6 @@ atsam_i2c_interrupt(void *arg)
atsam_i2c_bus *bus = arg;
uint32_t irqstatus;
bool done = false;
- transfer_desc *trans_desc;
Twihs *regs = bus->regs;
@@ -244,20 +228,18 @@ atsam_i2c_interrupt(void *arg)
done = true;
- trans_desc = &bus->trans_desc;
if (((irqstatus & TWIHS_SR_RXRDY) != 0) &&
- (atsam_i2c_is_state(trans_desc, RX_SEND_DATA))){
+ (atsam_i2c_is_state(bus, RX_SEND_DATA))){
/* carry on read transfer */
- atsam_i2c_continue_read(regs, trans_desc);
+ atsam_i2c_continue_read(regs, bus);
} else if (((irqstatus & TWIHS_SR_TXCOMP) != 0) &&
- (atsam_i2c_is_state(trans_desc, TX_RX_STOP_SENT))){
- atsam_i2c_finish_write_transfer(regs, trans_desc);
+ (atsam_i2c_is_state(bus, TX_RX_STOP_SENT))){
+ atsam_i2c_finish_write_transfer(regs);
done = true;
} else if (((irqstatus & TWIHS_SR_TXRDY) != 0) &&
- (atsam_i2c_is_state(trans_desc, TX_SEND_DATA))){
- atsam_i2c_continue_write(regs, trans_desc);
- if (trans_desc->trans_state == TX_CONT_MESSAGE_NEEDED){
+ (atsam_i2c_is_state(bus, TX_SEND_DATA))){
+ atsam_i2c_continue_write(regs, bus);
+ if (atsam_i2c_is_state(bus, TX_CONT_MESSAGE_NEEDED)){
done = true;
diff --git a/bsps/arm/atsam/include/bsp/atsam-i2c.h b/bsps/arm/atsam/include/bsp/atsam-i2c.h
index ae0fe97584..532be1dae5 100644
--- a/bsps/arm/atsam/include/bsp/atsam-i2c.h
+++ b/bsps/arm/atsam/include/bsp/atsam-i2c.h
@@ -30,33 +30,27 @@ extern "C" {
typedef enum {
TX_SEND_DATA,
- TX_SEND_STOP,
TX_CONT_MESSAGE_NEEDED,
RX_SEND_DATA,
- RX_SEND_STOP,
RX_CONT_MESSAGE_NEEDED,
TX_RX_STOP_SENT
}transfer_state;
-typedef struct {
- uint8_t status;
- uint8_t *data;
- bool stop_request;
- uint32_t data_size;
- transfer_state trans_state;
-} transfer_desc;
typedef struct {
i2c_bus base;
- i2c_msg *msgs;
Twihs *regs;
- transfer_desc trans_desc;
+ /* First message and number of messages that have to be processed. */
+ i2c_msg *msgs;
uint32_t msg_todo;
+ /* Information about the current transfer. */
+ bool stop_request;
+ transfer_state trans_state;
uint32_t current_msg_todo;
uint8_t *current_msg_byte;
uint32_t output_clock;
- bool read;
rtems_binary_semaphore sem;
rtems_vector_number irq;
} atsam_i2c_bus;
2.31.1
