[PATCH 2/2] bsp/atsam/i2c: Add error return and fix edge cases
Christian Mauderer
christian.mauderer at embedded-brains.de
Tue Feb 8 10:04:00 UTC 2022
The driver didn't return with an error on (for example) a NACK on the
bus. This adds the expected error return. Due to the new case that a
transfer can be interrupted on an error, there were some new edge cases.
This patch therefore also fixes these edge cases by removing the
transfer_state that more or less duplicated the interrupt states.
Fixes #4591
bsps/arm/atsam/i2c/atsam_i2c_bus.c | 94 ++++++++++++--------------
bsps/arm/atsam/include/bsp/atsam-i2c.h | 12 +---
2 files changed, 47 insertions(+), 59 deletions(-)
diff --git a/bsps/arm/atsam/i2c/atsam_i2c_bus.c b/bsps/arm/atsam/i2c/atsam_i2c_bus.c
index 22c63fca89..3451d15bed 100644
--- a/bsps/arm/atsam/i2c/atsam_i2c_bus.c
+++ b/bsps/arm/atsam/i2c/atsam_i2c_bus.c
@@ -33,18 +33,18 @@
static void
atsam_i2c_disable_interrupts(Twihs *regs)
- regs->TWIHS_IDR = 0xFFFFFFFF;
+ TWI_DisableIt(regs, 0xFFFFFFFF);
-static void
-atsam_i2c_set_transfer_status(atsam_i2c_bus *bus, transfer_state state)
- bus->trans_state = state;
-static void
+ * Return true if the message is done right after this. That is the case if all
+ * bytes are received but no stop is requested.
+static bool
atsam_i2c_continue_read(Twihs *regs, atsam_i2c_bus *bus)
+ bool done = false;
*bus->current_msg_byte = TWI_ReadByte(regs);
++bus->current_msg_byte;
--bus->current_msg_todo;
@@ -54,35 +54,35 @@ atsam_i2c_continue_read(Twihs *regs, atsam_i2c_bus *bus)
if (bus->stop_request){
TWI_DisableIt(regs, TWIHS_IDR_RXRDY);
TWI_EnableIt(regs, TWIHS_IER_TXCOMP);
- atsam_i2c_set_transfer_status(bus, TX_RX_STOP_SENT);
} else {
- atsam_i2c_set_transfer_status(bus, RX_CONT_MESSAGE_NEEDED);
+ done = true;
/* Last byte? */
else if (bus->current_msg_todo == 1 && bus->stop_request) {
TWI_Stop(regs);
-static bool
-atsam_i2c_is_state(atsam_i2c_bus *bus, transfer_state state)
- return (bus->trans_state == state);
+ return done;
-static void
+ * bytes are sent but no stop is requested.
+static bool
atsam_i2c_continue_write(Twihs *regs, atsam_i2c_bus *bus)
/* Transfer finished ? */
if (bus->current_msg_todo == 0) {
TWI_DisableIt(regs, TWIHS_IDR_TXRDY);
TWI_SendSTOPCondition(regs);
} else {
- atsam_i2c_set_transfer_status(bus, TX_CONT_MESSAGE_NEEDED);
+ done = true;
/* Bytes remaining */
@@ -91,13 +91,7 @@ atsam_i2c_continue_write(Twihs *regs, atsam_i2c_bus *bus)
-static void
-atsam_i2c_finish_write_transfer(Twihs *regs)
- TWI_ReadByte(regs);
- TWI_DisableIt(regs, TWIHS_IDR_TXCOMP);
+ return done;
static void
@@ -202,11 +196,9 @@ atsam_i2c_setup_transfer(atsam_i2c_bus *bus, Twihs *regs)
if (bus->current_msg_todo == 1){
send_stop = true;
- atsam_i2c_set_transfer_status(bus, RX_SEND_DATA);
atsam_i2c_setup_read_transfer(regs, ten_bit_addr,
slave_addr, send_stop);
} else {
- atsam_i2c_set_transfer_status(bus, TX_SEND_DATA);
atsam_i2c_setup_write_transfer(bus, regs, ten_bit_addr,
slave_addr);
@@ -222,33 +214,24 @@ atsam_i2c_interrupt(void *arg)
Twihs *regs = bus->regs;
/* read interrupts */
- irqstatus = regs->TWIHS_SR;
+ irqstatus = TWI_GetMaskedStatus(regs);
- if((irqstatus & (TWIHS_SR_ARBLST | TWIHS_SR_NACK)) != 0) {
+ if((irqstatus & ATSAMV_I2C_IRQ_ERROR) != 0) {
done = true;
- if (((irqstatus & TWIHS_SR_RXRDY) != 0) &&
- (atsam_i2c_is_state(bus, RX_SEND_DATA))){
- /* carry on read transfer */
- atsam_i2c_continue_read(regs, bus);
- } else if (((irqstatus & TWIHS_SR_TXCOMP) != 0) &&
- (atsam_i2c_is_state(bus, TX_RX_STOP_SENT))){
- atsam_i2c_finish_write_transfer(regs);
+ } else if ((irqstatus & TWIHS_SR_RXRDY) != 0) {
+ done = atsam_i2c_continue_read(regs, bus);
+ } else if ((irqstatus & TWIHS_SR_TXCOMP) != 0) {
+ TWI_DisableIt(regs, TWIHS_IDR_TXCOMP);
done = true;
- } else if (((irqstatus & TWIHS_SR_TXRDY) != 0) &&
- (atsam_i2c_is_state(bus, TX_SEND_DATA))){
- atsam_i2c_continue_write(regs, bus);
- if (atsam_i2c_is_state(bus, TX_CONT_MESSAGE_NEEDED)){
- done = true;
+ } else if ((irqstatus & TWIHS_SR_TXRDY) != 0) {
+ done = atsam_i2c_continue_write(regs, bus);
if(done){
- uint32_t err = irqstatus & ATSAMV_I2C_IRQ_ERROR;
+ bus->err = irqstatus & ATSAMV_I2C_IRQ_ERROR;
atsam_i2c_next_packet(bus);
- if (bus->msg_todo == 0 || err != 0) {
+ if (bus->msg_todo == 0 || bus->err != 0) {
atsam_i2c_disable_interrupts(regs);
rtems_binary_semaphore_post(&bus->sem);
} else {
@@ -273,27 +256,38 @@ atsam_i2c_transfer(i2c_bus *base, i2c_msg *msgs, uint32_t msg_count)
if ((msgs[i].flags & I2C_M_RECV_LEN) != 0) {
return -EINVAL;
+ if (msgs[i].len == 0) {
+ /* Hardware doesn't support zero length messages */
+ return -EINVAL;
bus->msgs = &msgs[0];
bus->msg_todo = msg_count;
bus->current_msg_todo = msgs[0].len;
bus->current_msg_byte = msgs[0].buf;
+ bus->err = 0;
regs = bus->regs;
- atsam_i2c_setup_transfer(bus, regs);
+ /* Start with a clean start. Enable error interrupts. */
+ TWI_ConfigureMaster(bus->regs, bus->output_clock, BOARD_MCK);
+ TWI_EnableIt(regs, ATSAMV_I2C_IRQ_ERROR);
- regs->TWIHS_IER = ATSAMV_I2C_IRQ_ERROR;
+ atsam_i2c_setup_transfer(bus, regs);
eno = rtems_binary_semaphore_wait_timed_ticks(
&bus->sem,
bus->base.timeout
- if (eno != 0) {
+ if (eno != 0 || bus->err != 0) {
rtems_binary_semaphore_try_wait(&bus->sem);
- return -ETIMEDOUT;
+ if (bus->err != 0) {
+ return -EIO;
+ } else {
+ return -ETIMEDOUT;
return 0;
diff --git a/bsps/arm/atsam/include/bsp/atsam-i2c.h b/bsps/arm/atsam/include/bsp/atsam-i2c.h
index 532be1dae5..a6a9c27d48 100644
--- a/bsps/arm/atsam/include/bsp/atsam-i2c.h
+++ b/bsps/arm/atsam/include/bsp/atsam-i2c.h
@@ -28,14 +28,6 @@ extern "C" {
#define TWI_AMOUNT_PINS 2
-typedef enum {
- TX_SEND_DATA,
- TX_CONT_MESSAGE_NEEDED,
- RX_SEND_DATA,
- RX_CONT_MESSAGE_NEEDED,
- TX_RX_STOP_SENT
-}transfer_state;
typedef struct {
i2c_bus base;
Twihs *regs;
@@ -46,10 +38,12 @@ typedef struct {
/* Information about the current transfer. */
bool stop_request;
- transfer_state trans_state;
uint32_t current_msg_todo;
uint8_t *current_msg_byte;
+ /* Error information that can be returned to the task */
+ uint32_t err;
uint32_t output_clock;
rtems_binary_semaphore sem;
rtems_vector_number irq;
2.31.1
