[PATCH 0/2] Add NTP support
Sebastian Huber
Tue Feb 8 15:16:20 UTC 2022
This is a draft patch set which imports the FreeBSD NTP support and ports it to
RTEMS. The PPS synchronization support is disabled.
Sebastian Huber (2):
kern_ntptime.c: Import form FreeBSD
kern_ntptime.c: Port to RTEMS
cpukit/include/rtems/score/timecounter.h | 9 +
cpukit/include/sys/timex.h | 4 +-
cpukit/posix/src/adjtime.c | 93 --
cpukit/score/src/kern_ntptime.c | 1191 +++++++++++++++++++++
cpukit/score/src/kern_tc.c | 6 +-
spec/build/cpukit/librtemscpu.yml | 2 +-
spec/build/testsuites/sptests/grp.yml | 2 +
spec/build/testsuites/sptests/spntp01.yml | 19 +
testsuites/psxtests/psxtime/test.c | 10 +-
testsuites/sptests/spntp01/init.c | 111 ++
10 files changed, 1342 insertions(+), 105 deletions(-)
delete mode 100644 cpukit/posix/src/adjtime.c
create mode 100644 cpukit/score/src/kern_ntptime.c
create mode 100644 spec/build/testsuites/sptests/spntp01.yml
create mode 100644 testsuites/sptests/spntp01/init.c
2.26.2
