[PATCH rtems-libbsd v2 0/3] MicroBlaze AXI Ethernet Support
Sebastian Huber
Mon Feb 14 13:40:04 UTC 2022
On 10/02/2022 23:12, Alex White wrote:
> v2:
> - Reworked patches to follow CONTRIBUTING.md guide
> - Excluded unneeded vmem calls
> - Moved ethernet frame alignment handling to the network interface driver
> This patch set adds support for Xilinx's AXI Ethernet IP core. It has
> been tested both in QEMU and on the KCU105 board using the default
> FPGA implementation from the Xilinx's KCU105 PetaLinux BSP.
The patch set in general looks good. For which libbsd branch is this
import? From which FreeBSD commit did you import the driver code?
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
